Page 1 of 1
SD card, does it poke out?
Posted:
Thu May 01, 2014 6:29 pm
by zerosimms
Out of curiosity, does anyone know if the SD card will poke out when it's inside the gamebuino or will it sit flush?
Re: SD card, does it poke out?
Posted:
Thu May 01, 2014 6:31 pm
by adekto
its micro sd it has to be flush
Posted:
Thu May 01, 2014 6:50 pm
by zerosimms
Thanks adekto
Makes getting it in and out of the pocket a lot easier
Posted:
Thu May 01, 2014 11:20 pm
by Myndale
Actually it's a spring-loaded socket so the card extends about 2 mm out, which it needs to do so that you can remove it by pressing down.
Posted:
Thu May 01, 2014 11:29 pm
by adekto
can you make a picture since now im not sure if its flush with the pcb or not
Posted:
Fri May 02, 2014 9:17 am
by Myndale
Posted:
Fri May 02, 2014 9:21 am
by zerosimms
That's not bad actually, I guess a case would allow you to streamline it more if you so wish.
Posted:
Fri May 02, 2014 12:05 pm
by rodot
Here are picture of gamebuino rev1 (early bird's version). The micro is protected by the acrylic case.
- gamebuino_rev1_front.jpg (77.11 KiB) Viewed 6296 times
- gamebuino_rev1_back.jpg (87.71 KiB) Viewed 6296 times
Posted:
Fri May 02, 2014 12:22 pm
by zerosimms
Perfect! Thanks for the screenies!
