Talk about (almost) anything
by zerosimms » Thu May 01, 2014 6:29 pm
Out of curiosity, does anyone know if the SD card will poke out when it's inside the gamebuino or will it sit flush?
zerosimms
by adekto » Thu May 01, 2014 6:31 pm
its micro sd it has to be flush
adekto
by zerosimms » Thu May 01, 2014 6:50 pm
Thanks adekto
Makes getting it in and out of the pocket a lot easier
zerosimms
by Myndale » Thu May 01, 2014 11:20 pm
Actually it's a spring-loaded socket so the card extends about 2 mm out, which it needs to do so that you can remove it by pressing down.
by adekto » Thu May 01, 2014 11:29 pm
can you make a picture since now im not sure if its flush with the pcb or not
adekto
by Myndale » Fri May 02, 2014 9:17 am
by zerosimms » Fri May 02, 2014 9:21 am
That's not bad actually, I guess a case would allow you to streamline it more if you so wish.
zerosimms
by zerosimms » Fri May 02, 2014 12:22 pm
Perfect! Thanks for the screenies!
zerosimms
Return to General forum
