GB DS module
Re: GB DS module
Postby adekto » Wed Aug 05, 2015 1:04 pm
heres the hello world for the ds module
you will also need this library https://code.google.com/p/u8glib/
//imports the library's
#include <U8glib.h>
//creates the ds object for the oled sceen
U8GLIB_SSD1306_128X64 ds(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST);
//sprite 48,64
const byte sprite[] PROGMEM = {0x4,0x80,0x0,0x0,0x0,0x0,0xC,0x80,0x0,0x0,0xFC,0x0,0x8,0x80,0x0,0x3,0x84,0x0,0x8,0xC0,0x0,0x6,0x44,0x0,0x19,0x40,0x0,0x1D,0x84,0x0,0x11,0x40,0x0,0x33,0x4,0x0,0x31,0x40,0x0,0xEE,0x6,0x0,0x21,0x73,0xE1,0x9C,0xA,0x0,0x23,0x9E,0x3F,0x78,0x12,0x0,0x23,0xE9,0x8C,0xF0,0x2,0x0,0x23,0xEA,0xEB,0xF0,0x2,0x0,0x23,0xF1,0x57,0xF0,0x2,0x0,0x69,0xF0,0xA7,0xF0,0x16,0x0,0x5E,0xF0,0x7,0xF8,0x34,0x0,0x5F,0xF8,0xF,0xFC,0x74,0x0,0x5F,0xF8,0xF,0xFE,0xF4,0x0,0x5F,0xFE,0x3F,0xFF,0xEC,0x0,0x6F,0x1F,0xFC,0x3F,0xE8,0x0,0x36,0xEF,0xFB,0xDF,0xD8,0x0,0x1A,0xD7,0xF6,0x6F,0xB0,0x0,0xC,0x87,0xF4,0x2D,0x30,0x0,0x8,0x87,0xF4,0x22,0xD8,0x0,0xC,0x8F,0xF4,0x27,0xEC,0x0,0xA,0xDF,0xFE,0x6F,0xF6,0x0,0x3B,0xFF,0xFF,0xFF,0xF2,0x0,0xE7,0xFF,0xFF,0xFF,0xC2,0x0,0x9F,0xFF,0xDF,0xFF,0xDA,0x0,0x9F,0xF8,0x1F,0xFF,0xEE,0x0,0xC3,0xFC,0x9F,0xFE,0x8,0x0,0x78,0xFF,0xFF,0xFD,0x58,0x0,0x15,0x3F,0xFF,0xA1,0xF0,0x0,0x1F,0x9F,0xFF,0x4B,0x0,0x0,0x0,0xCF,0xF8,0x55,0x80,0x0,0x0,0x70,0xAA,0xAA,0xC0,0x0,0x0,0xE0,0x55,0x7F,0x60,0x0,0x1,0x9C,0xAA,0xFF,0xB0,0x0,0x3,0x79,0x57,0xD7,0xD0,0x0,0x2,0x7C,0xAF,0xEB,0xD8,0x0,0x2,0x3E,0x5F,0xF7,0xE8,0x0,0x3,0x1F,0xAF,0xFB,0xE8,0x0,0x1,0x8E,0x1F,0xF7,0xD8,0x0,0x0,0xE4,0x1F,0xE3,0xD0,0x0,0x0,0x40,0x1F,0xC1,0x30,0x0,0x0,0x40,0x3F,0xC0,0xE0,0x0,0x0,0xC8,0x3F,0xE0,0x80,0x0,0x0,0x9C,0x7F,0xB1,0x80,0x0,0x1,0xBF,0xFF,0xDE,0xC0,0x0,0x1,0x3F,0xFF,0xEF,0x70,0x0,0x3,0x3F,0xFF,0xEF,0x9C,0x0,0xE,0x7C,0x7F,0xF7,0x87,0x0,0x18,0xF8,0x37,0xF7,0xC9,0x80,0x11,0xF0,0x33,0xF7,0xC6,0xC0,0x33,0xEC,0x7F,0xF7,0xE7,0x60,0x23,0x2E,0xFF,0xF1,0xF7,0xA0,0x20,0xCE,0x1,0xEE,0xF7,0xA0,0x31,0xE6,0x0,0xE,0xEF,0xA0,0x18,0x6,0xFC,0x0,0x1F,0x60,0xF,0xE7,0x3F,0xFF,0x3E,0xC0,0x0,0x33,0xCF,0xE0,0xFD,0x80,0x0,0x19,0xF0,0x1F,0xF3,0x0,0x0,0xC,0x7F,0xFA,0x8E,0x0,0x0,0x7,0xA,0xA8,0x38,0x0,0x0,0x1,0xE0,0x7,0xE0,0x0,0x0,0x0,0x3F,0xFC,0x0,0x0,};
// sprite y position
byte y = 64;
  //display the main menu:
  gb.titleScreen(F("ds hello wold"));
  gb.popup(F("Let's go!"), 100);
void gbLoop(){
    gb.display.println(F("Hello ds module!"));
    //declare a variable named count of type integer :
    int count;
    //get the number of frames rendered and assign it to the "count" variable
    count = gb.frameCount;
    //prints the variable "count"
    gb.display.println(count);
    //move the sprite on the ds module
    if(y > 1){
      y = y - 1;
void dsDraw(){
  // set the font for the ds module
  ds.setFont(u8g_font_unifont);
  ds.drawStr( 0, 22, "hi gamebuino!");
  ds.drawBitmapP( 79, y, 6, 64, sprite);
  // normal gamebuino loop
  gbLoop();
 // picture loop for ds module
  ds.firstPage();
  do {
    dsDraw();
  } while( ds.nextPage() );
