GB DS module
GB DS module
Postby adekto » Fri Jun 05, 2015 11:43 am
yes you read that right gamebuino DS (dual screen) module
also yes my red gamebuino looks amazing
this needs the u8glib: https://code.google.com/p/u8glib/
helo world code:
//imports the library's
#include <U8glib.h>
//creates the ds object for the oled sceen
U8GLIB_SSD1306_128X64 ds(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST);
//sprite 48,64
const byte sprite[] PROGMEM = {0x4,0x80,0x0,0x0,0x0,0x0,0xC,0x80,0x0,0x0,0xFC,0x0,0x8,0x80,0x0,0x3,0x84,0x0,0x8,0xC0,0x0,0x6,0x44,0x0,0x19,0x40,0x0,0x1D,0x84,0x0,0x11,0x40,0x0,0x33,0x4,0x0,0x31,0x40,0x0,0xEE,0x6,0x0,0x21,0x73,0xE1,0x9C,0xA,0x0,0x23,0x9E,0x3F,0x78,0x12,0x0,0x23,0xE9,0x8C,0xF0,0x2,0x0,0x23,0xEA,0xEB,0xF0,0x2,0x0,0x23,0xF1,0x57,0xF0,0x2,0x0,0x69,0xF0,0xA7,0xF0,0x16,0x0,0x5E,0xF0,0x7,0xF8,0x34,0x0,0x5F,0xF8,0xF,0xFC,0x74,0x0,0x5F,0xF8,0xF,0xFE,0xF4,0x0,0x5F,0xFE,0x3F,0xFF,0xEC,0x0,0x6F,0x1F,0xFC,0x3F,0xE8,0x0,0x36,0xEF,0xFB,0xDF,0xD8,0x0,0x1A,0xD7,0xF6,0x6F,0xB0,0x0,0xC,0x87,0xF4,0x2D,0x30,0x0,0x8,0x87,0xF4,0x22,0xD8,0x0,0xC,0x8F,0xF4,0x27,0xEC,0x0,0xA,0xDF,0xFE,0x6F,0xF6,0x0,0x3B,0xFF,0xFF,0xFF,0xF2,0x0,0xE7,0xFF,0xFF,0xFF,0xC2,0x0,0x9F,0xFF,0xDF,0xFF,0xDA,0x0,0x9F,0xF8,0x1F,0xFF,0xEE,0x0,0xC3,0xFC,0x9F,0xFE,0x8,0x0,0x78,0xFF,0xFF,0xFD,0x58,0x0,0x15,0x3F,0xFF,0xA1,0xF0,0x0,0x1F,0x9F,0xFF,0x4B,0x0,0x0,0x0,0xCF,0xF8,0x55,0x80,0x0,0x0,0x70,0xAA,0xAA,0xC0,0x0,0x0,0xE0,0x55,0x7F,0x60,0x0,0x1,0x9C,0xAA,0xFF,0xB0,0x0,0x3,0x79,0x57,0xD7,0xD0,0x0,0x2,0x7C,0xAF,0xEB,0xD8,0x0,0x2,0x3E,0x5F,0xF7,0xE8,0x0,0x3,0x1F,0xAF,0xFB,0xE8,0x0,0x1,0x8E,0x1F,0xF7,0xD8,0x0,0x0,0xE4,0x1F,0xE3,0xD0,0x0,0x0,0x40,0x1F,0xC1,0x30,0x0,0x0,0x40,0x3F,0xC0,0xE0,0x0,0x0,0xC8,0x3F,0xE0,0x80,0x0,0x0,0x9C,0x7F,0xB1,0x80,0x0,0x1,0xBF,0xFF,0xDE,0xC0,0x0,0x1,0x3F,0xFF,0xEF,0x70,0x0,0x3,0x3F,0xFF,0xEF,0x9C,0x0,0xE,0x7C,0x7F,0xF7,0x87,0x0,0x18,0xF8,0x37,0xF7,0xC9,0x80,0x11,0xF0,0x33,0xF7,0xC6,0xC0,0x33,0xEC,0x7F,0xF7,0xE7,0x60,0x23,0x2E,0xFF,0xF1,0xF7,0xA0,0x20,0xCE,0x1,0xEE,0xF7,0xA0,0x31,0xE6,0x0,0xE,0xEF,0xA0,0x18,0x6,0xFC,0x0,0x1F,0x60,0xF,0xE7,0x3F,0xFF,0x3E,0xC0,0x0,0x33,0xCF,0xE0,0xFD,0x80,0x0,0x19,0xF0,0x1F,0xF3,0x0,0x0,0xC,0x7F,0xFA,0x8E,0x0,0x0,0x7,0xA,0xA8,0x38,0x0,0x0,0x1,0xE0,0x7,0xE0,0x0,0x0,0x0,0x3F,0xFC,0x0,0x0,};
// sprite y position
byte y = 64;
  //display the main menu:
  gb.titleScreen(F("ds hello wold"));
  gb.popup(F("Let's go!"), 100);
void gbLoop(){
    gb.display.println(F("Hello ds module!"));
    //declare a variable named count of type integer :
    int count;
    //get the number of frames rendered and assign it to the "count" variable
    count = gb.frameCount;
    //prints the variable "count"
    gb.display.println(count);
    //move the sprite on the ds module
    if(y > 1){
      y = y - 1;
void dsDraw(){
  // set the font for the ds module
  ds.setFont(u8g_font_unifont);
  ds.drawStr( 0, 22, "hi gamebuino!");
  ds.drawBitmapP( 79, y, 6, 64, sprite);
  // normal gamebuino loop
  gbLoop();
 // picture loop for ds module
  ds.firstPage();
  do {
    dsDraw();
  } while( ds.nextPage() );
Re: GB DS module
Postby Sorunome » Fri Jun 05, 2015 1:06 pm
That is looking awesome!
Do you mind releasing some more technical details? :)
Re: GB DS module
Postby adekto » Fri Jun 05, 2015 1:30 pm
what do you want to know
its just ssd1306 oled display over I2C (from ebay) and 4 wires
im straight up using the u8glib in the pong example
only wierd thing im getting is on start up you will get noise on the oled screen
just tested some bitmaps, bit difrent format atm need to fix that
the display takes images as a byte array similar like the gb format exept for the W H at the bigining of the array
using u8g drawing with
u8g.drawBitmapP(x,y,w/8,h,imageArray);
Re: GB DS module
Postby Awesomemario128 » Mon Jun 08, 2015 11:43 pm
Cool
Awesomemario128
Re: GB DS module
Postby adekto » Tue Jun 09, 2015 7:46 am
so the pricing of the oled is resonable and you sude get one under €10
a solder iron, proto-board and 4 female header will help ofcource
pin out from left to right on gamebuino, will work on ether connector
0v --- gnd
3v3 --- vcc
da --- sda
ck --- scl
if you have intrest in this module and wish to have one maybe a bit more sleeker on a pcb, we can get some made if there is enugh interest
Re: GB DS module
Postby adekto » Thu Jul 09, 2015 2:09 pm
Did some soldering for probebly the easyest conection ever
Re: GB DS module
Postby Skyrunner65 » Mon Jul 13, 2015 1:54 pm
It might seem insane to say right now, but why not use the same kind of screen that the GB has?
Other than that, this is great!
Re: GB DS module
Postby adekto » Mon Jul 13, 2015 9:09 pm
wel mainly since the nokia 5110 screen is realy realy bad (i mean have you seen that ghosting?)
also hey u know that arduboy thing? yea you basicly play there games with some tweaking
and the higher resolution is realy nice to have
Re: GB DS module
Postby erico » Tue Jul 14, 2015 3:32 am
but but the ghosting is one of the charms of it :roll:
Re: GB DS module
Postby adekto » Tue Jul 14, 2015 12:14 pm
sure it has its scharms but not all games work well with its
anything with fast movement becoms a mess
this little thing is just an option for you to add
anyway plz tell me if you guys are interested in more of this
other i2c sceens work aswel btw
Users browsing this forum: No registered users and 24 guests
