Modules, cases, buttons...
by Tobi » Wed Apr 02, 2014 11:12 pm
Is it somehow (a mod?) possible to play online against other?
Tobi
by Myndale » Thu Apr 03, 2014 12:51 am
Using a Wifi shield (or some variant thereof) probably isn't an option, the only way to connect to the SPI interface is via the ICSP port and Rodot's already noted that the header pins won't fit under the front plate. Personally I think the easiest way to give Gamebuino Wifi capability is probably going to to be an i2C-to-UART chip connected to a UART-to-Wifi module i.e. one of these:
http://www.thanksbuyer.com/image/cache/ ... 00x600.jpg...and one of these...
http://img.dxcdn.com/productimages/sku_219910_1.jpg(You could probably get away with replace that bulky antenna with something smaller). Another option might be to replace the Wifi adapter with a bluetooth adapter and set up your mobile phone as a portable hotspot:
http://www.wvshare.com/img/devkit/accBo ... oard-2.jpg
by rodot » Thu Apr 03, 2014 9:07 am
Just a not about the ICSP header: you can use a right angle header for it to fit under the acrlic case.
- gamebuino_old.jpg (66.16 KiB) Viewed 8212 times
by Myndale » Thu Apr 03, 2014 10:34 am
Right, but you won't be shipping them with that, will you? So it may as well not exist
Interesting photo, based on the file name this was an earlier version of Gamebuino, yes? The acrylic face plate that you posted on Indiegogo the other day had holes drilled to match the components on this version i.e. the speaker on the left and the C button on the right. I also notice that this version had an earphone jack, which presumably would have muted speaker sound when they were plugged in?
by rodot » Thu Apr 03, 2014 11:15 am
Yep, that's a previous version of Gamebuino. But the earphone jack was used for... I2C! Jack cables are really common and cheap. But it was too confusing, so I abandoned the idea.
Actually I realize that it would be really cool to have access to the ICSP port for SPI modules... let me look into that, it might be possible. But you would need a CS pin, so you module should be connected on both ICSP and I2C ports. as they are right angled, that seem difficult. Moreover, it will look ugly to have a module on the left of the Gamebuino, and won't be really ergonomic.
by Skyrunner65 » Thu Apr 03, 2014 5:51 pm
Maybe someone could use the I2C for a earphone jack
Please let it be possible *fingers crossed*!
Skyrunner65
by inversesandwich » Wed Apr 23, 2014 6:22 pm
Have a look at the TI CC3000 SoC. Adafruit sells a breakout board for it.
inversesandwich
by ripper121 » Wed Apr 23, 2014 7:43 pm
Bluetooth to UART is the easiest way and with this you can add games from your pc over Bluetooth
ripper121
by adekto » Wed Apr 23, 2014 7:54 pm
not allot of people have Bluetooth on pc's (unless its a mac) but mostly everyone has wifi in there home
adekto
