Page 1 of 1
MLF / PLCC Socket
PostPosted: Tue Apr 08, 2014 8:32 am
by ripper121
If a new releas will made from the Gamebuino, can we use a MLF Socket?
So we can change the Atmega328P, if there become problems by massive sd card load and resulting read write errors on ram.
Re: MLF Socket
PostPosted: Tue Apr 08, 2014 8:38 am
by rodot
These SMD chip socket are pretty expensive, and takes a lot of space, I'm afraid it won't fit neither in the budget nor on the PCB :(
But anybody with some soldering skills could change the atmega328. And seriously, 10000 rewrite cycles will last you years.
Re: MLF / PLCC Socket
PostPosted: Tue Apr 08, 2014 8:43 am
by ripper121
Yes i have no Problem with the write cycles :D
But i have sometimes Problems with the fuesbits xD
https://www.youtube.com/watch?v=t8X0zip7TvU here a test for readwrite cycles >1 Mil
PostPosted: Tue Apr 08, 2014 8:53 am
by rodot
The fuse bits are only going to be set once, I don't really get what you mean?
PostPosted: Tue Apr 08, 2014 1:18 pm
by ripper121
when i like to replace the crystal i need to set the fueses again.
Its no problem, so when i defuse it i solder in a new chip ;)
PostPosted: Tue Apr 08, 2014 1:21 pm
by rodot
I'm not sure to get what you mean.
If you change the crystal for one with a different frequency (to overclock you Gamebuino for example) you won't have to change the fuses.
PostPosted: Tue Apr 08, 2014 2:11 pm
by ripper121
ok no problem ^^
