Modules, cases, buttons...
by erico » Sat Apr 19, 2014 10:30 pm
Was a headphone jack/audio out mentioned as an expansion too?
On my own I can´t think of much as an expansion before I actually try the gamebuino.
The extra memory sounds like a nice thing.
by rodot » Sat Apr 19, 2014 10:52 pm
It's not really possible to add a headphone jack on the module because the sound output is not connected to the extension ports, sorry. But it's not really complicated to solder a headphone jack yourself directly on the sound output.
I will put the module on top of the Gamebuino, so that's not really possible to add a joystick there :/
- expansion.png (63.17 KiB) Viewed 44219 times
by rodot » Sun Apr 20, 2014 12:13 pm
I figured out a neat way to add a joystick... *suspens*
I ordered all the parts to make a prototype of the expansion board, so I'll be able to work on it if I have some free time (or if I want to take a break).
by adekto » Sun Apr 20, 2014 1:50 pm
great to hear, cant wait
adekto
by rodot » Sun Apr 20, 2014 4:58 pm
Good news: rev2 of the PCB will have a connector on the right to be able to easily add a headphone jack module.
Bad news: the first batch of 20 PCB won't have it
by adekto » Sun Apr 20, 2014 9:17 pm
il take a one of your hands than, i dont mind for the jack
adekto
by Hark0 » Sun Apr 20, 2014 9:23 pm
rodot wrote:Good news: rev2 of the PCB will have a connector on the right to be able to easily add a headphone jack module.
Hype!
Hark0
by DFX2KX » Mon Apr 21, 2014 7:06 pm
rodot wrote:It's not really possible to add a headphone jack on the module because the sound output is not connected to the extension ports, sorry. But it's not really complicated to solder a headphone jack yourself directly on the sound output.
You could do it, but it would need a ribbon cable going around to where you wanted to put the buttons/joystick.
A fancier option would be a set of l/r buttons that replace the whole backplate and give you some extra buttons at the bottom on either side of the charging/flashing jack. it'd be screwed in, so it shouldn't move too much.
DFX2KX
by rodot » Mon Apr 21, 2014 8:45 pm
The L/R buttons are going to be directly on the module, why would they need a ribbon cable? I'm not sure we talk about the same thing.
by DFX2KX » Tue Apr 22, 2014 4:34 pm
rodot wrote:The L/R buttons are going to be directly on the module, why would they need a ribbon cable? I'm not sure we talk about the same thing.
I was referring to sticking a joystick on it. or more buttons then just L/R. You'd have to connect to the I2C connector, then the fact it's attached with a cable would let you put it where you want it. If you just want to hook up an l/R buttons, putting them on the module itself would work fine.
DFX2KX
