Greyscale
Greyscale
Postby Sorunome » Tue Mar 24, 2015 6:18 pm
I guess I'll just tease you guys with four levels of grey, hehe
It is running in an interrupt, thus loop() is still called all the time.
[s]I'll release the source once i clean it a bit out, I'm having an issue with inline assembly mentioned here: viewtopic.php?f=8&t=3040#p8673 [/s] (come on, no stroke tag?!?!)
Have the source here:
Please keep in mind that it is my first AVR program with asm and my second AVR program altogether, so if you see any obvious optimization mistakes, please tell me! Actually any peephole optimizations are welcome, hehe.
Also I didn't put a lot of effort into the moving square parts. The frontBuf and backBuf are pre-filled with the gradient, if you just use the moving squares you wouldn't have to pre-fill them.
// Gamebuino full-screen four-level-grey-scale rendering demo - by Sorunome ( http://www.sorunome.de )
// The interrupt wrapper and LCD initilizer are based off of http://gamebuino.com/wiki/index.php?title=Grey-scale_rendering
#include <TimerOne.h>
// how often to update the screen, 42 seems to be the magic number to minimize flicker
#define FRAME_RATE 42
#define PIN_SCE   A1
#define PIN_RESET A0
#define PIN_DC    A2
#define PIN_SDIN  11
#define PIN_SCLK  13
#define PIN_BACKLIGHT 5
#define PORT_SCLK PORTB
#define SCLK_BIT 5
#define PORT_SDIN PORTB
#define SDIN_BIT 3
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
#define LCD_CMD   0
// the interrupt will need both buffers, frontBuf and backBuf to update the LCD
// the following table will get you the result for each pixel:
// frontBuf | backBuf | Result
//     0    |    0    | white
//     0    |    1    | light grey
//     1    |    0    | dark grey
//     1    |    1    | black
byte frontBuf[LCD_X*LCD_Y/8] = {
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
byte backBuf[LCD_X*LCD_Y/8] = {
void LcdClear(void) {
  for (int index = 0; index < LCD_X * LCD_Y / 8; index++)
    LcdWrite(LCD_D, 0x00);
void LcdInitialise(void) {
  pinMode(PIN_SCE,   OUTPUT);
  pinMode(PIN_RESET, OUTPUT);
  pinMode(PIN_DC,    OUTPUT);
  pinMode(PIN_SDIN,  OUTPUT);
  pinMode(PIN_SCLK,  OUTPUT);
  digitalWrite(PIN_RESET, LOW);
  digitalWrite(PIN_RESET, HIGH);
  LcdWrite( LCD_CMD, 0x21 );  // LCD Extended Commands.
  LcdWrite( LCD_CMD, 0xB9 );  // Set LCD Vop (Contrast). //B1
  LcdWrite( LCD_CMD, 0x04 );  // Set Temp coefficent. //0x04
  LcdWrite( LCD_CMD, 0x14 );  // LCD bias mode 1:48. //0x13
  LcdWrite( LCD_CMD, 0x0C );  // LCD in normal mode. 0x0d for inverse
  LcdWrite(LCD_C, 0x20);
  LcdWrite(LCD_C, 0x0C);
void LcdWrite(byte dc, byte data) {
  digitalWrite(PIN_DC, dc);
  digitalWrite(PIN_SCE, LOW);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
  digitalWrite(PIN_SCE, HIGH);
byte rotFlag = -2;
void callback() {
  digitalWrite(PIN_DC, LCD_D);
  // X - front buffer
  // Y - back buffer
  // Z - cycle pointer
  asm volatile(
    "ldi R18,219\n\t"
    "clc\n\t"
    "inc %[rotFlagReg]\n\t"
    "breq doneWithInitOffset\n\t"
    "rol R18\n\t"
    "mov R20,%[rotFlagReg]\n\t"
    "inc R20\n\t"
    "rol R18\n\t"
    "ldi %[rotFlagReg],-2\n"
"doneWithInitOffset:\n\t"
    //this is where the jumps go
    //R18 together with the carry flag is the "9-bit" register for the mask, it works well as the loop doesn't modify carry
    "ldi R21,84\n"
    "Loop_Outer:\n\t"
      "ldi R22,6\n"
      "Loop_Inner:\n\t"
          "ld R16,Y+\n\t"
          "ld R17,X+\n\t"
          "ror R18\n\t"
          "eor R16,R17\n\t"
          "and R16,R18\n\t"
          "eor R16,R17\n\t"
          // now ouptut R16 to the screen start
          "SBRC R16,7\n\t"
          "rjmp BitSkip0_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip0_2\n"
        "BitSkip0_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip0_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,6\n\t"
          "rjmp BitSkip1_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip1_2\n"
        "BitSkip1_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip1_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,5\n\t"
          "rjmp BitSkip2_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip2_2\n"
        "BitSkip2_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip2_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,4\n\t"
          "rjmp BitSkip3_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip3_2\n"
        "BitSkip3_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip3_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,3\n\t"
          "rjmp BitSkip4_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip4_2\n"
        "BitSkip4_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip4_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,2\n\t"
          "rjmp BitSkip5_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip5_2\n"
        "BitSkip5_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip5_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,1\n\t"
          "rjmp BitSkip6_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip6_2\n"
        "BitSkip6_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip6_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          "SBRC R16,0\n\t"
          "rjmp BitSkip7_1\n\t"
          "cbi 5,3\n\t"
          "rjmp BitSkip7_2\n"
        "BitSkip7_1:\n\t"
          "sbi 5,3\n\t"
        "BitSkip7_2:\n\t"
          "sbi 5,5\n\t"
          "cbi 5,5\n\t"
          // now ouptut R16 to the screen end
          "dec R22\n\t"
          "breq InnerLoopExit\n\t"
          "jmp Loop_Inner\n"
        "InnerLoopExit:\n\t"
      "dec R21\n\t"
      "breq OuterLoopExit\n\t"
      "jmp Loop_Outer\n"
   "OuterLoopExit:\n\t"
  :[rotFlagReg] "+r" (rotFlag):"x" (backBuf),"y" (frontBuf):);
class Square {
  int x,y,xDir,yDir;
  byte c;
  public:
    Square(int gx,int gy,int gxDir,int gyDir,byte gc){
      x = gx;
      y = gy;
      xDir = gxDir;
      yDir = gyDir;
      c = gc;
    void update(){
      x += xDir;
      if(x < 0){
        xDir = 1;
        x = 0;
      }else if(x > LCD_X-8){
        xDir = -1;
        x = LCD_X-8;
      y += yDir;
      if(y < 0){
        yDir = 1;
        y = 0;
      }else if(y > LCD_Y-8){
        yDir = -1;
        y = LCD_Y-8;
      //now draw it
      switch(c){
        case 1:
          for(byte i = x;i < x+8;i++){
            for(byte j = y;j < y+8;j++){ // i;j
              frontBuf[i + (j / 8) * 84] |= _BV(j % 8);
          break;
        case 2:
              backBuf[i + (j / 8) * 84] |= _BV(j % 8);
          break;
        case 3:
          break;
Square *squares[6];
#define numSquares 6
void setup(void) {
  LcdInitialise();
  LcdClear();
  pinMode(PIN_BACKLIGHT, OUTPUT);
  digitalWrite(PIN_BACKLIGHT, HIGH);
  Timer1.initialize(1000000/FRAME_RATE);         // initialize timer1, and set a 1/2 second period
  Timer1.pwm(9, 512);                // setup pwm on pin 9, 50% duty cycle
  Timer1.attachInterrupt(callback);  // attaches callback() as a timer overflow interrupt
  squares[0] = new Square(10,10,-1,-1,1);
  squares[1] = new Square(50,5,1,-1,2);
  squares[2] = new Square(30,17,1,1,1);
  squares[3] = new Square(0,0,1,1,2);
  squares[4] = new Square(3,20,-1,1,3);
  squares[5] = new Square(42,21,-1,-1,2);
uint32_t nextFrameMillis;
#define timePerFrame 50
void loop(void) {
  // loop still gets called, and the LCD is being updated via an interrupt
  // so put your game code here and update the display buffers at whatever
  // frame rate you like
  if(((nextFrameMillis - millis()) > timePerFrame) && rotFlag==0) {
    nextFrameMillis = millis() + timePerFrame;
    memset(frontBuf, 0, LCD_X * LCD_Y / 8);
    memset(backBuf, 0, LCD_X * LCD_Y / 8);
    for(byte i = 0;i < numSquares;i++){
      squares[i]->update();
Re: Greyscale
Postby Drakker » Tue Mar 24, 2015 8:04 pm
The picture doesn't show. Says file not found.
I'm curious to see if it works any better than my attempt at shading (gray experiment thing), which works Ok on only 1 of my 5 displays (the slow, extra ghosting one that is unusable for fast games anyway).
Drakker
Re: Greyscale
Postby Marcus » Tue Mar 24, 2015 8:17 pm
Wow!
http://knowyourmeme.com/memes/shut-up-and-take-my-money
It's amazing what some of you squeeze out of the hardware. This would be so great for RPG sprites.
Next thing we know someone prints a color matrix and transforms each pixel into a color sub-pixel, resulting in a fancy 28x16 color screen :-)
3x3+b
Marcus
Re: Greyscale
Postby Sorunome » Tue Mar 24, 2015 8:22 pm
Drakker wrote:The picture doesn't show. Says file not found.
Weird, maybe your ISP blocks https://img.ourl.ca ?
IDK it is almost flickerless
Marcus wrote:Wow!
Thank you!
Re: Greyscale
Postby Drakker » Wed Mar 25, 2015 1:59 am
It's unlikely to be blocked as it was doing this at work, and now I'm home and it still isn't working. Though, magically, when I change the https to plain http it now works.
Well, you can work one extra shade in this picture. That's what I managed to get in my gray experiment thing, although without seeing it in action on a real Gamebuino it's hard to know how stable the gray is. Mine was wiggling a lot. ;)
Drakker
Re: Greyscale
Postby erico » Wed Mar 25, 2015 3:03 am
Nice! can´t wait to see it moving, how much it may or not flick!
The color matrix is also a funky idea.
Re: Greyscale
Postby jonnection » Wed Mar 25, 2015 10:19 am
Hi Sorunome
Looks like a very nice bit of code you got there. I really like it when people dig down to assembly / start from scratch to do their stuff, that is the way new possibilities are found. I believe we are nowhere near the max of what can be achieved.
What interrupt do you use to make your effect ? In the Gamebuino, timer 0 is needed for time functions, timer 1 is making the PWM for sound output, and timer 2 is used to modify the output of timer 1. So unless you hook the greyscale effect to timer 2 (it is possible but will interfere with sound) or modify timer 0 interrupt on Arduino library level, you can't really use an interrupt timer for the grey effect. Not saying it can't be done, just saying you run out of timers (unfortunately) on this device very fast.
Looking forward to seeing your code. Kudos for your test so far!
Re: Greyscale
Postby Sorunome » Wed Mar 25, 2015 10:25 am
Drakker wrote:It's unlikely to be blocked as it was doing this at work, and now I'm home and it still isn't working. Though, magically, when I change the https to plain http it now works.
I did not want to add another shade of grey to this implementation as I already max out storage, only using two bits per pixel, giving me only four states.
erico wrote:Nice! can´t wait to see it moving, how much it may or not flick!
The greyscale is very stable, in my past experience (I ported similar code I used for z80 calculators with a monochrome screen) also with movement, haven't tried it here yet, though
jonnection wrote:Hi Sorunome
I didn't use assembly from ground up, as I didn't want to have to care about interrupt handling etc. So I shamelessly used the code found here to set up the interrupts.
That would actually also make it easier for other non-asm programmers to use, i think
Re: Greyscale
Postby jonnection » Wed Mar 25, 2015 10:58 am
Don't worry. Everyone here is shamelessly using Myndale's code for pretty much everything. :D
Myndale's example is using Timer 1 (=the only 16-bit timer on atmega328). No sound output then. Unless you take the TVout.tone approach in which case you get only beeps (too long to get into detail).
But in any case. Grayscale on timer1 = no music. Myndale can correct me if I am wrong. Sorry to be the bearer of bad news.
Re: Greyscale
Postby Sorunome » Wed Mar 25, 2015 11:43 am
awe :( So maybe try some more asm dark magic to use other interrupt stuff so that sound is working, would that be, in theory, possible?
Also, here is a moving demo....i hate my camera.
EDIT: Added the source to the first post! wooo!
EDIT2: So I just tried to do it with double-buffering to prevent tearing but 2k ram aren't enough to support 4 screen buffers :(
((84*48)/8)*4 = 2016
That would leave only 32 bytes for the program, hehe
Next
Users browsing this forum: No registered users and 121 guests
