If you have to stick with 15*13 px grid, I'm fine with it. Even if some icons are not so recognizable, since there is the name in the header, it's great.
Btw the blinking square is fine enough.
class tinyFAT
public:
_master_boot_record MBR;
_boot_sector BS;
_directory_entry DE;
_current_file currFile;
unsigned long firstDirSector;
byte buffer[512];
class tinyFAT
public:
_boot_sector BS;
byte *buffer;
Sorunome wrote:@Jonnection: literately every single time i tried file.writeLn no matter what it contained.
#include <tinyFAT.h> //requires the tinyFAT library. You can download it here : http://www.henningkarlsen.com/electronics/library.php?id=37
#include <avr/pgmspace.h>
byte res;
file.initFAT();
gb.display.print(F("Deleting old file...\n"));
gb.display.update();
if(file.exists("test.txt")){
file.delFile("test.txt");
file.create("test.txt");
res=file.openFile("test.txt", FILEMODE_TEXT_WRITE);
if(res==NO_ERROR){
gb.display.print(F("Writing to file...\n"));
file.writeLn("Hello World!");
file.closeFile();
gb.display.print(F("Done writing to file!\n"));
}else{
gb.display.print(F("Error opening file!\n"));
while(true); // infinite pause
