by zerosimms » Fri Jul 25, 2014 8:07 pm
Hey all.
I'm after a bit of help...
I'm using the gb.display.fillRect and drawRect methods and need some advice on how to create the simplest collision detection. I actually want my objects to pass through each other but detect the fact they have collided. Any pointers would be appreciated
Cheers
zerosimms
by adekto » Fri Jul 25, 2014 8:27 pm
box collision would be a way to go
so easiest way is to write a function like this but u can use other ways as well
bool pointCheck(int pointX, int pointY,int boxX, int BoxY, int boxW, int boxH){
//check if point is inside box
if(pointX > boxX && pointX < boxX+boxW &&
pointY > boxY && pointY < boxY+boxH)
return true;
return false;
this sued work by just calling it, dont forget it will return a boolean.
u can edit this code slightly to do box to box check but i let u figure that out yourself
hope this helps
adekto
by zerosimms » Fri Jul 25, 2014 8:33 pm
Fantastic!
Thank you for that, makes sense I guess... Now lets see if I can put it into practice
zerosimms
by msevilgenius » Fri Jul 25, 2014 9:52 pm
Just a heads up, there are a couple of functions in the library for collisions: gb.collidePointRect and gb.collideRectRect, the last two functions in
Gamebuino.cppThough they don't appear to be documented on the wiki for some reason.
msevilgenius
by Tiash » Fri Jul 25, 2014 11:17 pm
That is another method, for test collisions between rectangles:
int isRectCollision(int x1, int y1, int w1, int h1, int x2, int y2, int w2, int h2) {
//rect1: start point (x1,y1) with height=h1 and width=w1
//rect2: start point (x2,y2) with height=h2 and width=w2
return !( x2 > x1+w1 ||
x2+w2 < x1 ||
y2 > y1+h1 ||
y2+h2 < y1 );
Tiash
by rodot » Sat Jul 26, 2014 7:51 am
Very nice method, I'm gonna update the library with yours as min was buggy and slow.
by zerosimms » Sat Jul 26, 2014 9:19 am
Thank you guy's. @msevilgenius that's really handy to know, this is the issue I have with the Arduino IDE and Processing, neither of them give you clues to methods that exist
zerosimms
by rodot » Sat Jul 26, 2014 9:31 am
I didn't put the collision detection in the documentation because I was not sure if I would eventually include them or not. Also my rectangle-rectangle collision was not good.
by adekto » Sat Jul 26, 2014 2:38 pm
zerosimms wrote:Thank you guy's. @msevilgenius that's really handy to know, this is the issue I have with the Arduino IDE and Processing, neither of them give you clues to methods that exist
yep totally agree, we need a better editor idk if netbeans can solve it, i use sublime text usually
adekto
by inversesandwich » Sat Jul 26, 2014 11:43 pm
adekto wrote:zerosimms wrote:Thank you guy's. @msevilgenius that's really handy to know, this is the issue I have with the Arduino IDE and Processing, neither of them give you clues to methods that exist
I love sublime text and the stino plugin! MariaMole (
http://dalpix.com/mariamole) is a great IDE though, and I've only just realised that they've released a Ubuntu version of it. Yay!
inversesandwich
