GENESIS : Space Exploration
Postby minecraftlog21 » Fri Jan 09, 2015 3:50 am
The game is called GENESIS as in new beginning ,This game will be a space exploration and survival.
The game will feature Big map or possibly endless map populated with galleys , planets , stares , black holes , Decays or ruins of past civilizations and current civilizations.
1/26/15
I'm not dead just havent posted may updates latley!
Well the game is going well you can fianly land on plates added a game state system and working on geting sound from a wav file with Muessigb.
1/16/15
So I am currently working out somthing with rodot to fix/repalce the broken unit.
Thanks for being so awsome rodot!
viewtopic.php?f=7&t=2966&p=7912#p7912
In other news I also swiched to linux :D and abandoned windows.
1/14/15
Deserter strikes!
So I finally open the package the came in the mail that had 2 of the gamebuinos I ordered, so I give one to a friend as a gift and then I noticed on mine the usb is a bit crooked but I continued doing what I was doing so after I Replaced the acyclic for the transparent orange that I also got.
After loading This game onto the included sd card to test it out on real hardware I had one final step , I had to charge it becose the battery was probable dead while being shipped and the USB port [b]Snapped[/b] right off I did not apply much force and also did put in the correct way I checked
[img]http://butterblocks.com/images/GameBuino/IMG_0465.JPG[/img]
[img]http://butterblocks.com/images/GameBuino/IMG_0467.JPG[/img]
1/13/15
So far The game is going well. Sorry for the short update.
1/9/15 Part 2 update.
So I have started programing for the Gamebuino on a emulator until it comes in the mail.
and I have Came across a problem with collision any ideas on whats wrong.
(This is the bug as you can see the ship goes threw the barrier up top.)
FIXED !
1/10/15
I have downloaded an emulator and started experimenting with it.
I am look for any one willing to help with developing this game :D
PM me if interested!
1/9/15
Update on a brain storming session that I had earlier today.
and I came up how I want the game to look.
(outer space)
(on a planet)
Do note that the images are fake.
Also I want the player to be able to take a planet and build on it like to build a chest by gathering wood and than placing down a chest in the planet, Not only simple things like chest traps,walls,tools and extra.
An another is for the player needing to be fed or if Its too cold (him or her) needing a space costume.
1/8/15
The game may also have trading between players using the link cables or the Black Light based Transfer demonstrated :
http://gamebuino.com/forum/viewtopic.php?f=12&t=995
I want this game to load recourse from the SD card so it could have a resource pack like system so user texture changes sound and possibly GUI layout.
Quick News:
I Currently trying to get my gamebuino fixed? (Shiping Damage)
If you have any suggestion please post it this Topic.
Last edited by minecraftlog21 on Tue Jan 27, 2015 4:20 am, edited 22 times in total.
minecraftlog21
Re: Space Exploration / RTS Like game
Postby Myndale » Fri Jan 09, 2015 6:53 am
If you've already done Arduino dev then you're pretty much there already. Gamebuino uses the regular Arduino IDE and adds it's own library and examples that will get you up and running almost immediately.
Also if you want to start development before your unit arrives then don't forget to check out the emulators (I developed Simbuino).
Postby quosa » Fri Jan 09, 2015 3:36 pm
I am working on a similar project. A Space delivery/ exploration mechanic .
If You like to Join or if you want to see my Code : PM or here.
Might be interessting for you.
quosa
Postby minecraftlog21 » Sat Jan 10, 2015 3:48 am
quosa wrote:I am working on a similar project. A Space delivery/ exploration mechanic .
I join if are ideas are similar so I don't have to sacrifice too much.
minecraftlog21
