[WIP] Run - An Endless Runner
Posted: Fri Jun 26, 2015 9:07 pm
Hello !
This is my current project, called 'Run'. It's an endless runner in the same style of Canabalt or Jetpack Joyride. The goal is to make the highest score possible without dyeing. You gain point by surviving, and you can gain more by staying in the air long enough and catching bonuses. For that, you can jump multiple times, and you regain your jumps by landing of catching a bonus. Finally, the speed of the game increase the more you stay alive.
The game feature randomly generated levels, an almost functional high score system (I have to implement the renaming of the player) and a small particle engine for special effects.
What need to be done :
Gif :
Bitbucket :
https://bitbucket.org/valdenthoranar/run
(WARNING : Play at your own risk, I don't have tested the game on the real hardware yet)
Hope you'll like !
- Renaming your highscore
- Testing the game on a real device (I only have access to Simbuino for the testing, and the speed seems to slow, so I will adjust that as soon as I receive my Gamebuino )
- Add a splash screen
- Improve the menu (Only PLAY works at the moment, and I think you can't leave properly the game)
Gif :
Bitbucket :
Hope you'll like !
