by Summoner123 » Thu Aug 13, 2015 3:34 pm
EatMyBlitch wrote:i knew the problem and i thought i understood it. But i had no idea how to fix it.
Thank you so much.
BTW: it shows an error when i replace gb.display.fillRect with gb.display.fillCircle. even though it changes colour.
and 1 more question how do i make a ball hollow?
and how do i make the spawn points reset.
The error occurs because you don't have changed the parameter of function, to draw o circle you need the Xposition, Yposition and the radius of circle
gb.display.fillCircle(x, y, r);
in the example of my later post I used
gb.display.fillCircle(player_x, player_y, player_size/2);
If you want a circle and not a fillcircle you can change the fillcircle() to drawCircle().
Change the spawn point is very easy to, just change the position of the player and anemy after all titleScreen when it be call.
gb.titleScreen(F("unamed"));
player_x=0; //Move the player ball to left of screen
player_y=0; //Move the player ball to top of screen
ball_x=80; //Move the enemy ball to Right of screen
ball_y=0; //Move the enemy ball to top of screen
Summoner123
by EatMyBlitch » Thu Aug 13, 2015 3:53 pm
thanks again
.I suck at programming
now i need to just program that each time you touch the catch ball it gives you a point and i need to make it so that at 3,6,9,11,15 and so on a new killer ball comes.
EatMyBlitch
by EatMyBlitch » Thu Aug 13, 2015 5:22 pm
i got a score
EDIT : now it resets each time you die.
EatMyBlitch
by Skyrunner65 » Thu Aug 13, 2015 5:51 pm
Hey if you want, here's how you could do multiple balls:
1. create variables for each ball.
2. For each ball, do this:
gb.display.drawBitmap(VARIABLEX, VARIABLEY, ball)
3. Move as needed.
It's pretty simple.
Skyrunner65
by EatMyBlitch » Thu Aug 13, 2015 5:54 pm
Thanks i will try and implement it
i don't have a variable called ball and i don't know what to put in it.
EatMyBlitch
by Skyrunner65 » Thu Aug 13, 2015 7:05 pm
No, the "ball variable" is the name of the sprite you are using for the ball...
Skyrunner65
by EatMyBlitch » Thu Aug 13, 2015 7:06 pm
im not using a sprite.
can i make the catch ball bounce of the player?
Because then you can only get 1 point per hit instead of like 4.
BTW: the code i tried to run so that another ball will spawn at 3 points does not work. I tried this if(score/3 == int); so basically it checks if score:3 is an integer. (integer means a whole number like 1,10, 100, 50, 80. But not 1.4, 3.7, 6.3.). It says it expected a primary-expression.
here's my code.
//declare all the variables needed for the game :
int score = 0;
int catch_x = LCDWIDTH/2;
int catch_y = LCDHEIGHT/2;
int catch_vx = 3;
int catch_vy = 3;
int catch_size = 1;
int catch_r = 1;
int person_x = LCDWIDTH/3; //set the horizontal position to the middle of the screen
int person_y = LCDHEIGHT/6; //vertical position
int person_vx = 5; //horizontal velocity
int person_vy = 5; //vertical velocity
int person_size = 6; //the size of the ball in number of pixels
int ball_x = LCDWIDTH/5;
int ball_y = LCDHEIGHT/2;
int ball_vx = 2;
int ball_vy = 2;
int ball_size = 2;
int ball_r = 2;
void setup()
gb.titleScreen(F("Ball dodger"));
person_x=40; //Move the player ball to middle of screen
person_y=24; //Move the player ball to middle of screen
catch_x=0; //Move the catch ball to left of screen
catch_y=40; //Move the catch ball to top of screen
void loop()
gb.battery.show = false;
//Check if person touched a catch ball
if(gb.collideRectRect(person_x, person_y, person_size, person_size, catch_x, catch_y, catch_r, catch_r))
{ gb.sound.playOK();
score = score + 1;}
//Check if person touched a enemy ball
if(gb.collideRectRect(person_x, person_y, person_size, person_size, ball_x, ball_y, ball_size, ball_size))
//If touched, send a message with 40 frames of duration (20 frames = 1 Second so 40 frames = 2 second)
{gb.popup(F("you died!"),20);
// make a sound play
gb.sound.playCancel();
//Go to the title Screen
score = 0; //Resets score
person_x=40; //Move the player ball to left of screen
person_y=24; //Move the player ball to top of screen
if(score/3 == int);
//a new ball gets spawned
person_x = person_x + person_vx; //increase the horizontal position by the ball's velocity
person_x = person_x - person_vx;
person_y = person_y + person_vy;
person_y = person_y - person_vy;
if(person_x < 0){
//bring it back in the screen
person_x = 0;
//if the person is touching the right side
if((person_x + person_size) > LCDWIDTH){
person_x = LCDWIDTH - person_size;
//if the person is touching the top side
if(person_y < 0){
person_y = 0;
//if the person is touching the down side
if((person_y + person_size) > LCDHEIGHT){
person_y = LCDHEIGHT - person_size;
//draw the person on the screen
gb.display.drawRect(person_x, person_y, person_size, person_size);
//the catch ball starts here
//add the speed of the catch ball to its position
catch_x = catch_x + catch_vx;
catch_y = catch_y + catch_vy;
//check that the catch ball is not going out of the screen
//if the catch ball is touching the left side of the screen
if(catch_x < 0){
//change the direction of the horizontal speed
catch_vx = -catch_vx;
//play a preset "tick" sound when the catch ball hits the border
gb.sound.playTick();
//if the ball is touching the right side
if((catch_x + catch_size) > LCDWIDTH){
//if the ball is touching the top side
if(catch_y < 0){
catch_vy = -catch_vy;
//if the ball is touching the down side
if((catch_y + catch_size) > LCDHEIGHT){
//draw the ball on the screen
gb.display.fillCircle(catch_x, catch_y, catch_r);
//the enemy ball starts here
//add the speed of the ball to its position
ball_x = ball_x + ball_vx;
ball_y = ball_y + ball_vy;
//check that the ball is not going out of the screen
//if the ball is touching the left side of the screen
if(ball_x < 0){
ball_vx = -ball_vx;
//play a preset "tick" sound when the ball hits the border
if((ball_x + ball_size) > LCDWIDTH){
ball_vx = -ball_vx;
if(ball_y < 0){
ball_vy = -ball_vy;
if((ball_y + ball_size) > LCDHEIGHT){
ball_vy = -ball_vy;
gb.display.fillCircle(ball_x, ball_y, ball_r);
//the score starts here
gb.display.fontSize = 1;
gb.display.cursorX = 0;
gb.display.cursorY = 0;
gb.display.print(score);
EatMyBlitch
by EatMyBlitch » Sat Oct 17, 2015 1:38 pm
Dammit i just lost the game!!!
BTW:can somebody please provide some lines of code. So that the catch ball bounces of the player and only gives 1 point.
Nevermind did it myself
if(gb.collideRectRect(person_x, person_y, person_size, person_size, catch_x, catch_y, catch_size, catch_size))
score = score + 1;}
now the only thing i need to add is that every three times you score another killer ball comes in.
EatMyBlitch
by EatMyBlitch » Sat Apr 30, 2016 10:52 am
Will nobody help me with the new kill ball each time you get 3 points thing?
*CRIES*
EatMyBlitch
by superfreaky » Sat Apr 30, 2016 5:59 pm
EatMyBlitch wrote:Will nobody help me with the new kill ball each time you get 3 points thing?
*CRIES*
Well maybe they want you to try for yourself first. After all, the best way to learn is through figuring out after long thought, and showing through example next.
superfreaky
Users browsing this forum: No registered users and 97 guests
