Modules, cases, buttons...
by adekto » Sun Sep 07, 2014 10:52 am
hi guy’s i have been thinking about improvements for the gamebuino platform
this is just all in concept and will probably not be made
here’s version 0.2 of what i call project bobcat:
128x64 white oled display 0.96inch
atmega644A-PU with 4kB ram and 64kB program memory
real time clock ic + cell battery
- bobcatv01.png (4.59 KiB) Viewed 8183 times
the red rectangle is where a small fresnel lens would be to increase screen readability
the rest of the components would stay the same unless people want more buttons or a bigger battery
currently the problem with this is the chip which is a none standard in arduino terms
adekto
by Matrix828 » Sun Sep 07, 2014 3:04 pm
I like this idea!
Wouldn't it be easier to run the RTC off the battery?
If it wont run off 3.7-4.2V then putting a diode to lower the voltage would work.
Chip w/ arduino bootloader"Sanguino" support for that Atmega644I think a more powerful surface mount chip would be more appealing in terms of power usage and size though.
EDIT: The chip used in the
MEGA is better than the one you've suggested, and is surface mount. (That one, or the 2560 are both good.)
Matrix828
by rodot » Sun Sep 07, 2014 3:52 pm
Matrix828 wrote:EDIT: The chip used in the MEGA is better than the one you've suggested, and is surface mount. (That one, or the 2560 are both good.)
Yep, it's way better, plus it's officially supported.
adekto wrote:the red rectangle is where a small fresnel lens would be to increase screen readability
I would rather directly use a larger screen.
That's the kind of hardware I think I would use if I would make a Gamebuino Mega, but it's gonna be pretty expensive, probably > 80€.
by adekto » Sun Sep 07, 2014 8:02 pm
yes i know about the mega but it would be to expensive these parts are far lower priced and are basically half the mega performance and prices ranging around 40 euro's
im also presenting the dip version since it would be easier for people to build it if they want
on the display side again i went for cheaper part and solving it with a lens. oled display's larger than 1.3" go up in price a bit to much for my taste
alternatively for large display is the ST7565 lcd which might be a better thing for the gb mega keeping the design of monochrome lcd display's
adekto
by rodot » Sun Sep 07, 2014 8:21 pm
I think the atmega328p is okay for the regular version of the Gamebuino, there is no need to update to 644 (which isn't officially arduino supported and more expensive). If you really need plenty of RAM then directly go for the atmega2560, I don't think the 644 is a step that worth it. Another way to go could be the cortex M0 or M3 but it's a completely different architecture, different software, different bootloader... different project.
For the screen of a virtual gamebuino Mega a 1.3" 128*64 monochrome amoled sounds like a good compromise: monochrome so it keeps the spirit (and the library/games compatibility) of the original Gamebuino, but amoled so there is no persistence and it looks good. Anyway, the Gamebuino Mega is not for this week, I haven't a chance to work on the extension modules yet. I should quit my school and my job to have more time for Gamebuino
by Matrix828 » Sun Sep 07, 2014 9:58 pm
I'm also in favour of a bigger screen vs a lens.
Gamebuino > school
Matrix828
by adekto » Mon Sep 08, 2014 12:00 pm
i wil brainstorm a bit more on this then
adekto
by DFX2KX » Fri Sep 12, 2014 1:30 pm
Yeah, I'd pondered what the GB would be like with an improved screen. The 5110 hurts my eyes to look at for too long.
As for power. If I where going to try and make a console along the same veins as the Gamebuino, I'd probably want to go color just for possibilities' sake, but that's just me. It is an interesting Idea, though.
DFX2KX
by rodot » Fri Sep 12, 2014 2:55 pm
Yeah, why not for a color screen after all. We shall see ^^
by TheTurnipKing » Sat Sep 13, 2014 7:27 am
I think a simple answer is "price". There aren't many displays with the same sort of low cost and ubiquity as a 5110 screen. I'd be happy to be proven wrong.
TheTurnipKing
