Page 1 of 1
Gamebuino battery data
Posted:
Sun Jul 27, 2014 9:57 am
by inversesandwich
I've published the data captured by the batterylogger sketch to an interactive graph!
Click here to view it. I might post more in the future to see if battery performance changes.
Re: Gamebuino battery data
Posted:
Fri Dec 23, 2016 10:00 pm
by gamebox13
I've tried to compile this sketch and run, but had some problem with output txt file. On gamebuino it runs without errors, txt file created but on PC it not opens, because it is corrupt (says filesize is not ok). After chkdsk the file is empty. Tried many times, runs about 9 hours before battery discharge or 10 min and got same result with corrupt file.
Posted:
Sat Dec 24, 2016 10:22 am
by Sorunome
Which SD library do you use?
Posted:
Sat Dec 24, 2016 4:12 pm
by gamebox13
This sketch was in gamebuino's examples and uses tinyfat.
Posted:
Sat Dec 24, 2016 10:58 pm
by Sorunome
Yeah, somehow that one doesn't work anymore for writing files, only for reading them. IIRC SdFat works fine for reading&writing files, so use that one instead
Posted:
Tue Jan 03, 2017 9:49 am
by gamebox13
I made script, which plot voltage's graph on screen. There are max,min voltage and time. It has 512 size of array and can storage about 17 hours graph with every 2 minutes records.
- PC250295.JPG (236.13 KiB) Viewed 12648 times
unsigned int tm=0;
int i;
int t;
unsigned long x,y,xt,yt;
unsigned int bmax;
unsigned int bmin;
unsigned int bat;
unsigned int data[512]={};
gb.titleScreen(F("Battery Monitor"));
gb.backlight.set(0);
gb.display.clear();
gb.battery.show = false;
gb.display.textWrap = false;
data[0]=int(gb.battery.voltage);
//reset();
t++;
if (t>=1200*2){
t=0;
if (tm<511){
tm++;
bat=gb.battery.voltage;
data[tm]=bat;
bmin=4500;
bmax=0;
for (i=0; i<tm; i++)
if (data[i]<bmin) bmin=data[i];
if (data[i]>bmax) bmax=data[i];
if((gb.frameCount%20) == 0){
gb.display.clear();
xt=0;
yt=0;
x=1+i*83/(tm);
y=int(long(47)*(bmax-data[i])/(bmax-bmin));
gb.display.drawLine(xt,yt, x,y);
xt=x;
yt=y;
gb.display.drawFastVLine(0,0,48);
gb.display.drawFastHLine(0,47,84);
gb.display.cursorX = 40;
gb.display.cursorY = 41;
gb.display.print(tm*2);
gb.display.println(F("min"));
gb.display.cursorX = 60;
gb.display.cursorY = 0;
gb.display.print(bmax);
gb.display.println(F("mV"));
gb.display.cursorX = 2;
gb.display.print(bmin);
if (gb.battery.level<=1) gb.sound.playTick();
