by capmmm » Wed Aug 20, 2014 9:29 am
So, I encountered my files getting corrupted. Re-flashed and re-loaded the bootloader and the games. But now when I turn it on it goes to a file list, from the bootloader all the way to tile map. I can still play the games fine, just would like it to be back to normal. Is there any specific sequence that I went wrong with?
capmmm
by rodot » Wed Aug 20, 2014 9:40 am
What programmer did you use to burn the bootloader? Which version of it?
Where did you take the .HEX files from?
I'm not sure what is the "normal" behavior you expect? You mean that in you case it flashes the LOADER.HEX each time on startup even if you don't press 'C' ?
Users browsing this forum: No registered users and 79 guests
