by rodot » Mon Dec 15, 2014 7:41 pm
I got your message, thanks.
I will look into that "mail delivery failed" issue. It might come from the shop that tries to send me an email to
noreply@gamebuino.com from your email address.
by ziirish » Thu Jan 08, 2015 8:50 pm
Just a little update to let you know the new Gamebuino works like a charm!
Thanks every one and particularly rodot.
[190491.738667] usb 1-3: new full-speed USB device number 27 using xhci_hcd
[190492.253596] usb 1-3: New USB device found, idVendor=0403, idProduct=6001
[190492.253603] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[190492.253606] usb 1-3: Product: FT232R USB UART
[190492.253609] usb 1-3: Manufacturer: FTDI
[190492.253612] usb 1-3: SerialNumber: A92LTVBZ
[190493.337627] usbcore: registered new interface driver usbserial
[190493.337670] usbcore: registered new interface driver usbserial_generic
[190493.337705] usbserial: USB Serial support registered for generic
[190493.339713] usbcore: registered new interface driver ftdi_sio
[190493.339759] usbserial: USB Serial support registered for FTDI USB Serial Device
[190493.339898] ftdi_sio 1-3:1.0: FTDI USB Serial Device converter detected
[190493.339977] usb 1-3: Detected FT232RL
[190493.339982] usb 1-3: Number of endpoints 2
[190493.339987] usb 1-3: Endpoint 1 MaxPacketSize 64
[190493.339991] usb 1-3: Endpoint 2 MaxPacketSize 64
[190493.339995] usb 1-3: Setting MaxPacketSize 64
[190493.340644] usb 1-3: FTDI USB Serial Device converter now attached to ttyUSB0
ziirish
by rodot » Fri Jan 09, 2015 7:19 am
Good to hear! I came from a defective FT232RL chip, I changed it and the problem was gone. I made sure that all the FTDI chips are sourced from official sources like mouser or digikey to avoid counterfeit/defective units so it shouldn't happen again.
by LizardKing » Sat Mar 14, 2015 11:10 am
I have a similar problem, my computer won't recognise my gamebuino.
The led light that says the gamebuino is charging is on, so is the power led.
So it's not the same problem.
Any ideas?
Thanks !
LizardKing
by rodot » Mon Mar 16, 2015 6:29 am
Hey,
Did you check the
Driver confusion topic? Do you have a PID of 0000 in the device's properties ?
by LizardKing » Wed Apr 01, 2015 8:03 pm
Sorry for the late reply
It's a PID
I'm now reading throug the driver confusion topic, I hope that will solve it.
Thanks
LizardKing
by LizardKing » Wed Apr 01, 2015 8:31 pm
It didn't solve my problem...
I didn't even manage to instal octopus box.
I don't have a tab 'other devices' with 'FT232R USB UART' or something similar in it. So I'm stuck at the first step..
LizardKing
by rodot » Thu Apr 02, 2015 5:19 pm
Why do you say it doesn't recognize your Gamebuino, as it correctly shows "COM3" ? Aren't you allowed to select in the Arduino IDE ?
by LizardKing » Fri Apr 03, 2015 4:54 pm
Never mind me.
I didn't know I could only access the gambuino through the Arduino software.
I thougt it would work like a usb drive.
Problem solved
Sorry for your time
And thanks!
LizardKing
Users browsing this forum: No registered users and 76 guests
