by DFX2KX » Tue Jan 13, 2015 3:06 am
So, I've got a 'Deek-Robot' made TinyUSBISP programmer, standard 6 pin and ten pin layouts. It seems to have standard pinout, and pin one seems to match the the GB (it didn't fry the GB when I plugged it in, which is also a good sign)
However, I get
avrdude: Initilization failed, rc=-1
double check connections and try again, or use -F to override.
Overriding gives me a 0x0000 adress and tosses an error.
Any ideas? I bought the thing so I could finally update from my Indiegogo-era bootloader, and/or turn it into a permanant 3D printer controller. I didn't expect it to be this much work :\
DFX2KX
by Myndale » Tue Jan 13, 2015 3:34 am
First of all this is a little bit risky, the TinyUSBISP is a 5V programmer whereas Gamebuino is 3.3V. In practice you'll probably get away with it for uploading the bootloader but make sure you disconnect it before running any games...if you're over-driving Gamebuino and something tries to send something to the sound pin (e.g. the start-up beep) then you'll wind up applying 5V straight to the speaker and eventually destroy it. I speak from experience.
To track down the cause of the problem it would help to see the exact command line that your programmer software is sending to avrdude, assuming you can. I personally prefer to call it manually so I can see exactly what it thinks it's doing at every step, try something like this:
C:\arduino-1.0.5\hardware/tools/avr/bin/avrdude -CC:\arduino-1.0.5\hardware/tools/avr/etc/avrdude.conf -patmega328p -v -v -v -v -cavrisp -P\\.\COM18 -b19200 -Uflash:w:"YOUR_BOOTLOADER_FILE.HEX":i
The "-cavrisp" parameter is the programmer type, if the programmer isn't detected then try avrisp2, avrispmkII or avrispv2 (all with the "-c" prefix). Obviously you'll also need to change the COM port. Also keep in mind that the bootloader memory area is read-only, so any attempt to verify the write will fail, specify -V to disable that.
by DFX2KX » Tue Jan 13, 2015 6:39 am
Thanks for the help, Myndale, as for voltages, this one claims that it's yellow jumper is to go from 5v to variable voltage
hfuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0
0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net
/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
C:\Users\Russell>C:\Program Files (x86)\Arduino\hardware/tools/avr/bin/avrdude -
cavrisp -P\\.\COM18 -b19200 -Uflash:w:"gamebuino_boot.HEX":i
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\Russell>cd C:\Program Files (x86)\Arduino\hardware/tools/avr/bin/
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude.conf -patmega328p
-v -v -v -v -cavrisp -P\\.\COM18 -b19200 -Uflash:w:"gamebuino_boot.HEX":i
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>dir
Volume in drive C is Windows 7
Volume Serial Number is 389C-A9E8
Directory of C:\Program Files (x86)\Arduino\hardware\tools\avr\bin
05/21/2014 01:49 PM <DIR> .
05/21/2014 01:49 PM <DIR> ..
12/04/2008 02:35 PM 1,640,960 avarice.exe
12/04/2008 02:35 PM 598,016 avr-addr2line.exe
12/04/2008 02:35 PM 618,496 avr-ar.exe
12/04/2008 02:35 PM 792,576 avr-as.exe
12/04/2008 02:35 PM 216,064 avr-c++.exe
12/04/2008 02:35 PM 597,504 avr-c++filt.exe
12/04/2008 02:35 PM 214,016 avr-cpp.exe
12/04/2008 02:35 PM 216,064 avr-g++.exe
12/04/2008 02:35 PM 211,456 avr-gcc-4.3.2.exe
12/04/2008 02:35 PM 211,456 avr-gcc.exe
12/04/2008 01:42 PM 16,134 avr-gccbug
12/04/2008 02:35 PM 30,720 avr-gcov.exe
12/04/2008 02:35 PM 2,807,808 avr-gdb.exe
12/04/2008 02:35 PM 663,552 avr-gprof.exe
12/04/2008 02:35 PM 2,807,808 avr-insight.exe
12/04/2008 02:35 PM 1,038,336 avr-ld.exe
12/04/2008 11:28 AM 1,704 avr-man
12/04/2008 02:35 PM 609,280 avr-nm.exe
12/04/2008 02:35 PM 801,280 avr-objcopy.exe
12/04/2008 02:35 PM 869,888 avr-objdump.exe
12/04/2008 02:35 PM 618,496 avr-ranlib.exe
12/04/2008 02:35 PM 309,760 avr-readelf.exe
12/04/2008 02:35 PM 604,160 avr-size.exe
12/04/2008 02:35 PM 599,552 avr-strings.exe
12/04/2008 02:35 PM 801,280 avr-strip.exe
09/02/2011 12:40 PM 513,364 avrdude.exe
12/04/2008 02:35 PM 1,872,884 cygwin1.dll
11/10/2008 06:15 PM 5,248 giveio.sys
11/07/2008 11:02 PM 1,064 ice-gdb
11/07/2008 11:02 PM 51 ice-insight
11/10/2008 06:15 PM 755 install_giveio.bat
11/07/2008 09:04 PM 138,707 itcl32.dll
11/07/2008 09:04 PM 62,224 itk32.dll
11/07/2008 11:02 PM 264 kill-avarice
12/04/2008 02:35 PM 43,520 libusb0.dll
12/04/2008 02:35 PM 11,264 loaddrv.exe
11/10/2008 06:15 PM 229 remove_giveio.bat
12/04/2008 02:35 PM 192,000 simulavr-disp.exe
12/04/2008 02:35 PM 25,088 simulavr-vcd.exe
12/04/2008 02:35 PM 146,944 simulavr.exe
12/04/2008 02:35 PM 589,824 srec_cat.exe
12/04/2008 02:35 PM 460,288 srec_cmp.exe
12/04/2008 02:35 PM 460,288 srec_info.exe
11/07/2008 11:02 PM 225 start-avarice
11/10/2008 06:15 PM 172 status_giveio.bat
11/07/2008 09:04 PM 890,792 tcl84.dll
11/07/2008 09:04 PM 20,929 tclpip84.dll
12/04/2008 02:35 PM 12,288 tclsh84.exe
11/07/2008 09:04 PM 1,222,874 tk84.dll
12/04/2008 02:35 PM 13,312 wish84.exe
50 File(s) 24,580,964 bytes
2 Dir(s) 15,367,180,288 bytes free
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -CC:\arduino-1.0.5
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\arduino-1.0.5\hardware/tools/avr/
etc/avrdude.conf"
avrdude: can't open config file "C:\arduino-1.0.5\hardware/tools/avr/etc/avrdude
.conf": No such file or directory
avrdude: error reading system wide configuration file "C:\arduino-1.0.5\hardware
/tools/avr/etc/avrdude.conf"
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -CC:\Program Files
(x86)\Arduino\hardware/tools/avr/etc/avrdude.conf -patmega328p -v -v -v -v -cav
System wide configuration file is "C:\Program"
avrdude: can't open config file "C:\Program": No such file or directory
avrdude: error reading system wide configuration file "C:\Program"
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -CC:"\Program File
s (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf" -patmega328p -v -v -v -v -c
System wide configuration file is "C:\Program Files (x86)\Arduino\hardw
Using Port : \\.\COM18
Using Programmer : avrisp
Overriding Baud Rate : 19200
avrdude: ser_open(): can't open device "\\.\COM18": The system cannot find the f
ile specified.
avrisp -P\\.\COM1 -b19200 -Uflash:w:"gamebuino_boot.HEX":i
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrispV2 -P\\.\COM1 -b19200 -Uflash:w:"gamebuino_boot.HEX":i
Using Programmer : avrispV2
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
W ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 36
00 0xff 0xff
Block Poll Page
Polled
W ReadBack
flash 65 6 128 0 yes 32768 128 256 4500 45
00 0xff 0xff
Block Poll Page
Polled
W ReadBack
lfuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
Block Poll Page
Polled
W ReadBack
00 0x00 0x00
Block Poll Page
Polled
W ReadBack
00 0x00 0x00
Block Poll Page
Polled
W ReadBack
00 0x00 0x00
Block Poll Page
Polled
W ReadBack
0 0x00 0x00
Block Poll Page
Polled
W ReadBack
0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP V2
Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
That's what it's doing.
DFX2KX
by Myndale » Tue Jan 13, 2015 10:05 am
Looks like it's not hearing anything back from the programmer. Can you confirm that COM1 is in fact the port that the programmer is using? If you run the Arduino IDE and select Tools -> Serial Port then it should appear in the list of ports but only when the programmer is plugged in. Could be a COM speed issue too, try removing the -b19200.
Have you successfully used this programmer to upload apps to regular Arduino boards? If so then the best way to get this working is to go to your Arduino IDE settings and turn on verbose input for uploads, then upload an app to the Arduino (BLINK will do) and it'll show you the exact commands it's sending to avrdude for your programmer.
by DFX2KX » Tue Jan 13, 2015 7:43 pm
It's definately com1
I tried to upgrade Arduino to the latest version (because I couldn't see the comport in 1.0.5), and in the process your command not gives a point entry error.
It also did something to the FTDI driver When I tried this.... Apparently, the new drivers disable bootleg FT323R chips. Which, given the board was made in China, apparently the GB has. I can't even upload sketches to the Gamebuino directly at this point, and reverting didn't fix it.. (Sigh) it's going back in the desk.... Thanks for the help Myndale. I didn't brick the GB, fortunately. I just can't program it either via Arduino or the programmer at this point.
DFX2KX
by Myndale » Tue Jan 13, 2015 8:59 pm
Oh, that problem again. I forgot you were out of the action for a bit, you probably missed the whole FTDI thing.
Not to worry, it's easy fixed. You can either install older drivers that work with the trashed FTDI chip or run an FTDI utility to restore the chip back to what it should be. Details on this thread here:
http://gamebuino.com/forum/viewtopic.php?f=7&t=1373
by DFX2KX » Tue Jan 13, 2015 10:02 pm
Myndale wrote:Oh, that problem again. I forgot you were out of the action for a bit, you probably missed the whole FTDI thing.
I discovered that too late.... :\ Mine's not coming up on a scan... I'll try the laptop quick
(Edit: hey, did the 'old version' trick and got it to come up on a scan then, now to fix the vendor ID...)
DFX2KX
by DFX2KX » Tue Jan 13, 2015 11:14 pm
Well, got the GB itself programming. now to return to my original problem..... Hey Myndale, think the connector/cord might be bad?
DFX2KX
by Myndale » Wed Jan 14, 2015 12:03 am
My money would be on bad avrdude params. Have you successfully use it on a regular Arduino and looked at what the IDE's verbose output is printing out?
by DFX2KX » Wed Jan 14, 2015 2:24 am
Don't have a regular one to test. (I wish!)
Here's verbose output from Arduino:
Build options changed, rebuilding all
Sketch uses 10,830 bytes (35%) of program storage space. Maximum is 30,592 bytes.
Global variables use 681 bytes of dynamic memory.
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cusbtiny -Uflash:w:C:\Users\Russell\AppData\Local\Temp\build6696380069767320306.tmp/a_Hello.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 3 2014 at 23:12:16
System wide configuration file is "C:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328P
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
CMD: [ac 53 00 00] [00 00 00 00]
this check.
The output does confirm that it's been found, and seems to be communicating with avrdude, but it seems to fail on the whole upload bit.
DFX2KX
