Myndale wrote:Ok, well we'll have to get regular uploads working first before trying to upload the bootloader. Any chance you can post a photo showing exactly how you've wired the two together?
Myndale wrote:You've got your cable connected backwards on the Gamebuino side. ICSP connectors typically have a small dot printed onto the PCB next to the upper-left/VCC pin. It's a bit difficult to see on your unit because of the white faceplate but on Gamebuino that dot appears at the bottom. By convention the coloured wire along the edge of your cable is VCC and should wind up on the same side of the connector as that dot.
DFX2KX wrote:That's how it's keyed....It doesn't want to fit the other way.
Myndale wrote:DFX2KX wrote:That's how it's keyed....It doesn't want to fit the other way.
Then change it round on the programmer side. And if you can't do that then try taking off the Gamebuino faceplate.
Barring that you'll need to get either a directionless cable or jumpers like I use.
Sketch uses 10,830 bytes (35%) of program storage space. Maximum is 30,592 bytes.
Global variables use 681 bytes of dynamic memory.
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cusbtiny -Uflash:w:C:\Users\Russell\AppData\Local\Temp\build1755459338182284897.tmp/a_Hello.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 3 2014 at 23:12:16
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 00 00]
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
DFX2KX wrote:Wait... Why exactly would they key it backwards on one end, exactly? O_o That doesn't even make any sense...
Myndale wrote:DFX2KX wrote:Wait... Why exactly would they key it backwards on one end, exactly? O_o That doesn't even make any sense...
I think you'll find it's effectively "upside-down" on the Gamebuino. I believe it wasn't Rodot's original intention to expose the ICSP port (luckily for us he changed his mind), he probably didn't pay too much attention to it during the PCB design phase. Normally it's not a problem, the programmers I've seen have used keyed cables but not a keyed socket on the programmer itself.
It's not like these cables are expensive or anything, if I were you I'd pull out an exacto knife. Problem solved!
Myndale wrote:Oops! Yeah, I forgot to mention, SD cards use the SPI bus and are low voltage as well, you might wanna remove it before uploading anything via the ICSP. If it's stopped working then try reformatting it.
But uploads are working now, right? If so then you should be good to go for burning the bootloader backon.
Arduino: 1.5.8 (Windows 7), Board: "Gamebuino"
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cusbtiny -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xda:m -Ulfuse:w:0xff:m
Using Port : usb
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
CMD: [ac 53 00 00] [ac 52 53 00]
avrdude: AVR device initialized and ready to accept instructions
Reading | CMD: [30 00 00 00] [00 30 00 1e]
CMD: [30 00 01 00] [00 30 00 95]
################CMD: [30 00 02 00] [00 30 00 0f]
################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: erasing chip
CMD: [ac 80 00 00] [00 ac 80 00]
CMD: [ac 53 00 00] [00 ac 53 00]
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | CMD: [58 00 00 00] [00 58 00 ff]
################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | CMD: [58 00 00 00] [00 58 00 ff]
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x05"
avrdude: writing efuse (1 bytes):
Writing | CMD: [50 08 00 00] [00 50 08 fd]
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0x05:
avrdude: load data efuse data from input file 0x05:
avrdude: input file 0x05 contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | CMD: [50 08 00 00] [00 50 08 fd]
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xda"
avrdude: writing hfuse (1 bytes):
Writing | CMD: [58 08 00 00] [00 58 08 da]
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xda:
avrdude: load data hfuse data from input file 0xda:
avrdude: input file 0xda contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | CMD: [58 08 00 00] [00 58 08 da]
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing lfuse (1 bytes):
Writing | CMD: [50 00 00 00] [00 50 00 ff]
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xff:
avrdude: load data lfuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | CMD: [50 00 00 00] [00 50 00 ff]
avrdude: 1 bytes of lfuse verified
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cusbtiny -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/gamebuino_boot.hex:i -Ulock:w:0x0F:m
Using Port : usb
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
CMD: [ac 53 00 00] [00 00 53 00]
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/gamebuino_boot.hex"
avrdude: can't open input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/gamebuino_boot.hex: No such file or directory
avrdude: read from file 'C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/gamebuino_boot.hex' failed
Error while burning bootloader.
enabled in File > Preferences.
