by EatMyBlitch » Fri Aug 07, 2015 10:36 am
Hello everyone,
In Arduino ERW 1.0.5 every time i try and load an example to my gamebuino it says:
Gamebuino does not name a type.
and allot of:
gb was not declared in this scope ,
and LCDWIDTH was not declared in this scope
the same with all the other LCD dimensions.
I have this problem with every single example.
EatMyBlitch on Fri Aug 07, 2015 10:50 am, edited 1 time in total.
EatMyBlitch
by Sorunome » Fri Aug 07, 2015 10:39 am
Did you make sure this are your first three lines?
Did you make sure you have all the library files copied over correctly?
Do you have as board selected "Gamebuino" ?
by EatMyBlitch » Fri Aug 07, 2015 10:43 am
those are my first 3 lines but i cant seem to find Gamebuino in the board list.
EatMyBlitch
by EatMyBlitch » Fri Aug 07, 2015 10:46 am
i did it wil test out now
EatMyBlitch
by EatMyBlitch » Fri Aug 07, 2015 10:48 am
thanks alot sorunome
EatMyBlitch
by Sorunome » Fri Aug 07, 2015 10:48 am
No problem!
Mind editing the first post to add "[solved]" in front of the title so that others know it is solved?
by EatMyBlitch » Fri Aug 07, 2015 10:49 am
ok will do
EatMyBlitch
Users browsing this forum: No registered users and 70 guests
