Page 1 of 1
Gamebuino restting on SD Card read
PostPosted: Thu May 19, 2016 1:57 am
by MechanicalPen
One of my two Gamebuinos is acting up!
When I try turning on the misbehaving Gamebuino, it plays the startup sound then either freeze on 'reading sd card', resets up to three times before freezeing on 'reading sd card', or freezes on 'reading sd card' AND the backlight turns off. Startign it up without an SD card in the slots has it say "Insert SD & restart" as normal. It behaves this way for both of the SD cards I have.
Any ideas?
Re: Gamebuino restting on SD Card read
PostPosted: Thu May 19, 2016 2:44 am
by superfreaky
I think it may be related to battery... When is the last time you used it?
PostPosted: Thu May 19, 2016 8:46 am
by Sorunome
Try charging the gamebuino and try inserting the sd card while it is turned on
PostPosted: Thu May 19, 2016 9:49 pm
by MechanicalPen
I charged up the battery. Now it no longer resets but still stays on the "Reading SD card..." screen.
PostPosted: Tue Mar 14, 2017 9:00 pm
by MechanicalPen
I reformatted the SD card and held 'C' on boot. It's working okay now. The backlight and screen seem to flicker whenever there it reads the SD card. But it works well enough to do two player testing.
