[Solved] Problem with .HEX Need help
Postby 2ant » Sun Jun 26, 2016 1:01 pm
Hi, i compile the hello example and it compile without errors, i then have this :
I take one of the .hex file and rename it in capitals HELLO.HEX
If i load it into Simbuino it crash Simbuino (the games from the "Gamebuino-Games-Compilation-master" folder worked fine").
If i put it on the microSd and in the Gamebuino it appear in the bottom of the menu but when i choose "play" it display the "loading game don't turn off" screen, after a few seconds the backlight shut down and after a few more seconds the screen goes blank. The rx,tx,power led stay on like with every working game but nothing happens.
Can anyone help me ?
2ant
Re: Problem with .HEX Need help
Postby clement » Sun Jun 26, 2016 5:36 pm
Can you share your code?
in my mind you are a fatal error in your sketch. (infinit loop, null pointer ,....)
clement
Postby 2ant » Mon Jun 27, 2016 3:07 am
  //display the main menu:
  gb.titleScreen(F("My first game"));
  gb.popup(F("Let's go!"), 100);
    gb.display.println(F("Hello World!"));
    //declare a variable named count of type integer :
    int count;
    //get the number of frames rendered and assign it to the "count" variable
    count = gb.frameCount;
    //prints the variable "count"
    gb.display.println(count);
I took the first example after installing the library and followed the "Make your own .HEX" method from the getting started page.
2ant
Postby 2ant » Mon Jun 27, 2016 3:44 am
I fixed my own mess, i did a fresh install of the arduino ide and the gamebuino lib on another computer and the .HEX worked on my Gamebuino. When i installed the gamebuino lib the first time i overwrote something and didn't pay enough attention.
Solution : keep your arduino lib folder updated and organized.
2ant
Users browsing this forum: No registered users and 19 guests
