On the getting started section of the wiki it says I need to put the following text at the start of the file boards.txt:
gamebuino.name=Gamebuino
gamebuino.upload.tool=avrdude
gamebuino.upload.protocol=arduino
gamebuino.upload.maximum_size=30592
gamebuino.upload.speed=115200
gamebuino.bootloader.low_fuses=0xff
gamebuino.bootloader.high_fuses=0xda
gamebuino.bootloader.extended_fuses=0x05
gamebuino.bootloader.path=gamebuino_boot
gamebuino.bootloader.file=gamebuino_boot.hex
gamebuino.bootloader.unlock_bits=0x3F
gamebuino.bootloader.lock_bits=0x0F
gamebuino.build.mcu=atmega328p
gamebuino.build.f_cpu=16000000L
gamebuino.build.core=arduino
gamebuino.build.variant=standard
Although the problem is If I add the text and save it using notepad it says "Access denied". When I attempt the same thing in notepad++ it says to check if the file is open in another program (which its not).
Any help is appreciated.
Thanks very much,
Mike
