Gamebuino GPS problems
Postby maesoser » Tue Aug 19, 2014 10:20 am
I've recovered a GPS module form an old hexacopter. I've tried to make a simple GPS sketch to the gamebuino but I've a problem that I cannot solve...All the values are 0, even when I know that the GPS module is transmitting GPS locations (lat, lon)
I'm using TinyGPS+ and SoftwareSerial library.
The serial connection is initialized with
SoftwareSerial ss(RX_PIN, TX_PIN);
where
#define RX_PIN  A4
#define TX_PIN  A5
The GPS is an U-BLOX NEO-6M mounted on a board called GY-GPS6MV2. It has been tested on a computer by using a Serial-To-Usb chip and a logic level converter (cause the module works at 3.3v)
The GPS and the Gamebuino are connected using one of the I2C ports of the Gamebuino, the port closest to the C button which has this pinout
GND VCC A4 CLK
I have connected the A4 pin to the TX pin on the GPS board.
I've sniffed the communication between TX and A4 and it contains usual NMEA sentences with latitude and longitude (That is, with the location correctly fixed)
This is the code. It's very straight-forward cause I'm only showing the date collected by the Tinygps++ library. That's why I think that the problem is that I'm not correctly using this library. Do you know what I'm doing wrong?
https://github.com/maesoser/Gamebuino_GPS
maesoser
Re: Gamebuino GPS problems
Postby Myndale » Tue Aug 19, 2014 10:51 am
I think the problem is on this line:
gps.encode(ss.read());
The ss.read() method returns a single character and gps.encode also accepts a single character, but gps.location won't contain valid data until you've read an entire NMEA line. Check for when gps.encode() returns true and only process the data then.
Sometimes all you need is a fresh set of eyes! :)
Postby maesoser » Tue Aug 19, 2014 3:30 pm
Oh, that makes sense!! Thanks!
But I've the gps.encode(ss.read()) inside the loop so there should be a moment in which this function should return "true" and updates the values (lat, lon, etc...) ¿no?
Despite of that I have tried to change gps.encode() ...
I've written:
loop(){
if(gb.update)){
if(gps.encode(ss.read())){
//stuff
But then the sketch freezes more time than the time needed to send 74 chars at 9600 (That is the maximum length of an NMEA sentence I think)
I've also do a while like
loop(){
while(!gps.enccode(ss.read())){
gb.display.println("Retrieving data");
//stuff
But it also works either...
maesoser
Postby maesoser » Fri Aug 29, 2014 12:43 pm
If someone was wondering what happens with this problem (or someone has problems with serial communications) here it is the solution:
http://gamebuino.com/forum/viewtopic.php?f=11&t=1057&p=4692#p4692
Thanks for the support!!
maesoser
