Sat Jan 31, 2015 10:58 pm
//declare all the variables needed for the game :
int ball_x = LCDWIDTH/2; //set the horizontal position to the middle of the screen
int ball_y = LCDHEIGHT/2; //vertical position
int ball_vx = 1; //horizontal velocity
int ball_vy = 1; //vertical velocity
int ball_size = 3;
static unsigned char PROGMEM carre[] =
8, 6,
B00000000,
B00111100,
B00100100,
B00100100,
B00111100,
B00000000,
int carre_x, carre_y;
// the setup
gb.titleScreen(F("Hard Cube"));
gb.popup(F("Test"),100);
skyNet();
drawcarre();
if(gb.collideRectRect(ball_x, ball_y, 7, 7, 0, 0, 8, 48)){
ball_x = ball_x + 1;
if(gb.collideRectRect(ball_x, ball_y, 0, 0, 63, 10, 2, 36)){
if(gb.collideRectRect(ball_x, ball_y, 0, 0, 30, 10, 2, 36)){
ball_x = ball_x - 1;
if(gb.collideRectRect(ball_x, ball_y, 0, 0, 30, 9, 35, 2)){
ball_y = ball_y - 1;
//move the ball using the buttons
if(gb.buttons.repeat(BTN_RIGHT,1)){ //every 2 frames when the right button is held down
ball_x = ball_x + ball_vx; //increase the horizontal position by the ball's velocity
//gb.sound.playTick(); //play a preset "tick" sound every time the button is pressed
ball_x = ball_x - ball_vx;
ball_y = ball_y + ball_vy;
ball_y = ball_y - ball_vy;
//bonus : play a preset sound when A and B are pressed
gb.sound.playOK();
gb.sound.playCancel();
//check that the ball is not going out of the screen
//if the ball is touching the left side of the screen
if(ball_x < 0){
//bring it back in the screen
ball_x = 0;
//if the ball is touching the right side
if((ball_x + ball_size) > LCDWIDTH){
ball_x = LCDWIDTH - ball_size;
//if the ball is touching the top side
if(ball_y < 0){
ball_y = 0;
//if the ball is touching the down side
if((ball_y + ball_size) > LCDHEIGHT){
ball_y = LCDHEIGHT - ball_size;
//gb draw
gb.display.fillRect(ball_x, ball_y, ball_size, ball_size);
gb.display.print(ball_x);
gb.display.print("_");
gb.display.print(ball_y);
gb.display.drawRect(33, 12, 32, 36);
gb.display.drawRect(0, 0, 8, 48);
gb.display.drawRect(7, 0, 77, 48);
// dessine carre
void drawcarre()
gb.display.drawBitmap(carre_x,carre_y,carre);
// posotion des variables !(il sont ignore)!//
void initGame()
carre_x = 18;
carre_y = 0;
ball_x = 18;
ball_y = 38;
boolean IsAller = true;
void skyNet()
if (IsAller)
//droite
carre_y = carre_y +1;
else
//gauche
carre_y = carre_y -1;
//depasse la taille de l'ecran fait demis tour
if(carre_y>42)
//is aller est un boolean qui peut prendre deux valeur true ou false
IsAller = false;
// dessous zero fait demis tour
if(carre_y<=0)
IsAller = true;
Sun Feb 01, 2015 8:05 am
// the setup
initGame(); //appel de la fonction déclarée plus bas
Mon Feb 02, 2015 10:14 pm
Sun Feb 08, 2015 3:58 pm
