[SOLVED] Blank screen error
Posted: Sun Feb 15, 2015 12:45 am
I seem to be running into a recurring problem with my programs, and not just mine. This is the code for the game I wrote, but I get a blank screen with nothing on it..
A problem could easily hide in this program, but even something as simple as this little program doesn't load right:
While writing this, I even tested one of the examples, and that failed to do much of anything.
It seems like all the code that fails me is code that was compiled via the arduino IDE, so maybe there is a problem with the way i'm doing it..
Any ideas, problems in the code, or possible fixes? All help is greatly appreciated.
static unsigned char PROGMEM logo[]=
40,12,
B00111100, B00110000, B11000011, B11000000, B11110000,
B11000011, B00110000, B11001100, B00110011, B00001100,
B11000011, B00110000, B11001100, B00000011, B00000000,
B11111100, B00110000, B11001100, B11000011, B00110000,
B00111100, B00001111, B00000011, B11000000, B11110000,
static unsigned char PROGMEM player[]=
8,8,
B00111100,
B01000010,
B10100101,
B10000001,
B10100101,
B10011001,
B01000010,
B00111100,
static unsigned char PROGMEM item2[]=
8,8,
B01111110,
B11000011,
B10100101,
B10011001,
B10011001,
B10100101,
B11000011,
B01111110,
static unsigned char PROGMEM item1[]=
8,8,
B01111110,
B10000001,
B10111101,
B10111101,
B10111101,
B10111101,
B10000001,
B01111110,
int score = 0; // score
int item1_quantity = 0;
int item2_quantity = 0;
int player_x = LCDWIDTH/2; //set the horizontal position to the middle of the screen
int player_y = LCDHEIGHT/2; //vertical position
int player_vx = 1; //horizontal velocity
int player_vy = 1; //vertical velocity
int player_size = 8; //the size of the player in number of pixels
int item1_size = 6; //SE
int item1_x = 30; //initial X position of item1
int item1_y = 10; //initial Y position of item1
int item2_size = 8; //SE
int item2_x = 40; //initial X position of item2
int item2_y = 2; //initial Y position of item2
//display the main menu:
gb.titleScreen(F("Work In Progress"), logo);
//item1 system
if(gb.collideBitmapBitmap( player_x, player_y, player, item1_x, item1_y, item1)){
item1_x = random(0, LCDWIDTH - item1_size);
item1_y = random(0, LCDHEIGHT - item1_size);
score += 1;
item1_quantity += 1;
gb.sound.playOK();
//item2 system
if(gb.collideBitmapBitmap( player_x, player_y, player, item2_x, item2_y, item2)){
item2_x = random(0, LCDWIDTH - item2_size);
item2_y = random(0, LCDHEIGHT - item2_size);
score -= 3;
item2_quantity += 1;
gb.sound.playCancel();
//move the player using the buttons
if(gb.buttons.repeat(BTN_RIGHT,2)){ //every 2 frames when the right button is held down
player_x = player_x + player_vx; //increase the horizontal position by the player's velocity
if(gb.buttons.repeat(BTN_LEFT,2)){
player_x = player_x - player_vx;
if(gb.buttons.repeat(BTN_DOWN,2)){
player_y = player_y + player_vy;
if(gb.buttons.repeat(BTN_UP,2)){
player_y = player_y - player_vy;
//speed selection
gb.sound.playTick();
player_vx = 5;
player_vy = 5;
player_vx = 2;
player_vy = 2;
//check that the player is not going out of the screen\
//if the player is touching the left side of the screen
if( player_x < 0){
//bring it back in the screen
player_x = 0;
//if the player is touching the right side
if(( player_x + player_size) > LCDWIDTH){
player_x = LCDWIDTH - player_size;
//if the player is touching the top side
if( player_y < 0){
player_y = 0;
//if the player is touching the down side
if(( player_y + player_size) > LCDHEIGHT){
player_y = LCDHEIGHT - player_size;
//draw the player on the screen
gb.display.print("$ ");
gb.display.println(score);
gb.display.drawBitmap(player_x, player_y, player);
gb.display.drawBitmap(item1_x,item1_y,item1);
gb.display.drawBitmap(item2_x,item2_y,item2);
#include <SPI.h> //imports the SPI library
#include <Gamebuino.h> //imports the Gamebuino library
Gamebuino gb; //creates a Gamebuino object named gb
static unsigned char PROGMEM sprite[]=
8,6,
B10101010,
B01010101,
B10101010,
B01010101,
B10101010,
B01010101,
gb.titleScreen(F("It Works!"));
//the main loop
gb.display.drawBitmap(8,6,sprite);
