by naed » Thu Jun 02, 2016 1:32 pm
Hi all,
I just ordered my Gamebuino as encouragement to learn to code, so whilst waiting for it to ship I decided to try my hand at coding and running on an emulator... my first game is born
simple enough game that tries to get you to test your reflexes by matching the required number
int RandNumber;
int number = 0;
int state;
const byte numbers[] PROGMEM = {64,32,
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000010,B00000000,
B00000000,B00000000,B00000000,B00011111,B11100000,B00111111,B00000010,B00000000,
B00000000,B11100011,B11110000,B00110000,B00110000,B01111111,B10000010,B00000000,
B00000001,B11100111,B11111000,B00100000,B00010000,B01100001,B10000010,B10000000,
B00000011,B11100110,B00011000,B00100111,B10010000,B00000011,B10000011,B11000000,
B00000111,B01100110,B00011000,B00111100,B10010000,B00000111,B00000000,B10000000,
B00001110,B01100011,B11110000,B00000011,B10110000,B00001110,B00000000,B00000000,
B00001100,B01100011,B11110000,B00000010,B00100000,B00011100,B00000000,B00000000,
B00001111,B11110110,B00011000,B00000010,B00100000,B00111000,B00000000,B11110000,
B00001111,B11110110,B00011000,B00000011,B10110000,B01111111,B10000000,B10000000,
B00000000,B01100111,B11111000,B00111100,B10010000,B01111111,B10000000,B10000000,
B00000000,B01100011,B11110000,B00100111,B10010000,B00000000,B00000000,B11100000,
B00001110,B00000000,B00000000,B00100000,B00010000,B00000001,B11100000,B00010000,
B00010011,B00000000,B00000000,B00110000,B00110000,B00000000,B00100000,B00010000,
B00010101,B00000000,B10000000,B00011111,B11100000,B00000000,B01000000,B00010000,
B00010101,B00000001,B10000000,B00000000,B00000000,B00000000,B10000000,B11100000,
B00011001,B00000000,B10000000,B00000000,B00000000,B00000000,B10000000,B00000000,
B00001110,B00000000,B10000000,B00000000,B00000000,B00000000,B10000000,B00000000,
B00000000,B00000001,B11000000,B00000000,B00000000,B00000000,B00000000,B01110000,
B00000000,B00000000,B00000000,B00000000,B00000011,B11111110,B00000000,B10001000,
B00000000,B00000000,B00000000,B00111001,B11000010,B00100010,B11110111,B11010000,
B00111011,B10000000,B00000111,B01000110,B00100010,B10101010,B10001000,B10100000,
B00101110,B11111111,B11111101,B10101010,B10100010,B00100001,B10100010,B10110000,
B00100010,B10101000,B10001101,B10010010,B11100011,B10111101,B10111110,B10001000,
B00101000,B10101010,B00101100,B01011010,B10000000,B10100010,B11100011,B11111000,
B00101110,B10001011,B11101101,B01000110,B10000011,B10100000,B00000000,B00000000,
B00111011,B11111110,B00111100,B01111111,B10000010,B00100000,B00000000,B00000000,
B00000000,B00000000,B00000111,B10000000,B00000011,B11100000,B00000000,B00000000,
RandNumber = random(10,100);
gb.titleScreen(F(""), numbers);
gb.popup(F("Hold A to play"), 20);
/*void num(){
do{
gb.display.println(number);
number = number + 1; //test for number counter
} while(number < 50);
void restart_game() {
number = 0;
gb.display.println("Number Game"); //print hello world
gb.display.println("");
gb.display.println("Target number");
gb.display.println(RandNumber); // display a random number
//if button A is held then increase value by 1 and display value
if(gb.buttons.repeat(BTN_A,1)){
gb.display.println(number); //show increasing number
// if random number is the same as this value show win
if(RandNumber == number){
gb.display.println("Win!!");
else if(number <= RandNumber){
gb.display.println("Too low...");
else if(number >= RandNumber){
gb.display.println("Too High...");
gb.display.println("Match number to win"); //show text
gb.display.println("Press B to Restart"); //show text
// reset game code
if (gb.buttons.pressed(BTN_B)) { //Reset game by pressing B
number = 0; //This also regenerates a random number
gb.popup(F("reset"), 10);
if(gb.buttons.pressed(BTN_C)){ //exit to menu by pressing C
restart_game();
gb.titleScreen(F("Number game by NaeD"), numbers);
I can't figure out something that i'd like to add and was hoping to get some advice
1. how would I be able to start/stop the counter with a single button (i.e press A to start the counter then press A again to stop the counter)
I tried to add this to a while(1) function but the number only ever increases by one as the button is depressed
thanks in advance
(I've attached the HEX file of my game if anyone want to try it out)
- Attachments
- Numbergame.ino.zip
- (13.57 KiB) Downloaded 291 times
naed on Thu Jun 02, 2016 6:44 pm, edited 1 time in total.
naed
by clement » Thu Jun 02, 2016 4:00 pm
I modify code for count / stop count with a single button.
I hope this help you
int RandNumber;
int number = 0;
int state;
//add boolean value for check state
bool isActiveCounter;
//we dont count at start
isActiveCounter = false;
/*void num(){
do{
number = 0;
//number = number + 1;
//we inverse value of boolean
isActiveCounter = !isActiveCounter;
if(isActiveCounter == true){
//we incremente value
number++;
// reset game code
restart_game();
clement
by naed » Thu Jun 02, 2016 6:38 pm
Clement, thanks for your quick response, it certainly helped me learn a few things and helped me add some finishing touches to my first ever game.
Your help has given me a little boost to show that I will be able to learn this (maybe the hard way, but I can do it)
Here is my finished code to help anyone who wants to also learn how to do something similar
int RandNumber;
int number = 0;
int state;
gb.popup(F("Press A to start"), 20);
number = 0;
gb.display.println("Number Game by NaeD"); //print title
gb.display.println(F("Target number is"));
gb.display.cursorX = 67;
gb.display.cursorY = 12;
//if button A is pressed then start counter
number++;
//formatting and text to show increasing number
gb.display.println("Your number is ");
gb.display.cursorY = 24;
if(RandNumber == number & gb.buttons.pressed(BTN_A)){
gb.popup(F("You got it!"), 20);
else if(number <= RandNumber & gb.buttons.pressed(BTN_A) & number >= 10){
gb.popup(F("Too low..."), 20);
else if(number >= RandNumber & gb.buttons.pressed(BTN_A) & number >= 10){
gb.popup(F("Too high..."), 20);
gb.display.println(""); //show text
// reset game code
restart_game();
naed
Users browsing this forum: No registered users and 84 guests
