by Duhjoker » Fri Sep 23, 2016 9:53 pm
ok I have a working library for my LCD, updated to include the teensys gfx file.
im trying to add the tile map and collision routines to my gfx file but I keep getting these errors that I cant figure out how to fix.
Arduino: 1.6.11 (Windows 7), TD: 1.30-beta3, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimize speed (overclock), US English"
In file included from C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/LCD_2000_7775.h:10:0,
from C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\examples\TFTGraph_Mega2560\TFTGraph_Mega2560.ino:20:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:120:24: error: non-member function 'int16_t height()' cannot have cv-qualifier
int16_t height(void) const;
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:121:23: error: non-member function 'int16_t width()' cannot have cv-qualifier
int16_t width(void) const;
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:123:29: error: non-member function 'uint8_t getRotation()' cannot have cv-qualifier
uint8_t getRotation(void) const;
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:127:69: error: 'virtual' outside class declaration
virtual uint16_t newColor(uint8_t red, uint8_t green, uint8_t blue);
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:174:28: error: non-member function 'int16_t getCursorX()' cannot have cv-qualifier
int16_t getCursorX(void) const:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h: In function 'int16_t getCursorX()':
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:175:3: error: only constructors take member initializers
int16_t getCursorY(void) const;
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:175:11: error: expected '(' before 'getCursorY'
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:175:11: error: expected '{' before 'getCursorY'
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:175:11: warning: no return statement in function returning non-void [-Wreturn-type]
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h: At global scope:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:175:33: error: expected constructor, destructor, or type conversion before ';' token
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:179:2: error: expected unqualified-id before 'protected'
protected:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:205:1: error: expected declaration before '}' token
Error compiling for board Teensy 3.2 / 3.1.
#ifdef __AVR__
#include <avr/pgmspace.h>
#elif defined(ESP8266)
#include <pgmspace.h>
#endif
#include "Adafruit_GFX.h"
#include "glcdfont.c"
// Many (but maybe not all) non-AVR board installs define macros
// for compatibility with existing PROGMEM-reading AVR code.
// Do our own checks and defines here for good measure...
#ifndef pgm_read_byte
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
#endif
#ifndef pgm_read_word
#define pgm_read_word(addr) (*(const unsigned short *)(addr))
#endif
#ifndef pgm_read_dword
#define pgm_read_dword(addr) (*(const unsigned long *)(addr))
#endif
// Pointers are a peculiar case...typically 16-bit on AVR boards,
// 32 bits elsewhere. Try to accommodate both...
#if !defined(__INT_MAX__) || (__INT_MAX__ > 0xFFFF)
#define pgm_read_pointer(addr) ((void *)pgm_read_dword(addr))
#else
#define pgm_read_pointer(addr) ((void *)pgm_read_word(addr))
#endif
#ifndef min
#define min(a,b) (((a) < (b)) ? (a) : (b))
#endif
#ifndef _swap_int16_t
#define _swap_int16_t(a, b) { int16_t t = a; a = b; b = t; }
#endif
Adafruit_GFX::Adafruit_GFX(int16_t w, int16_t h):
WIDTH(w), HEIGHT(h)
_width = WIDTH;
_height = HEIGHT;
rotation = 0;
cursor_y = cursor_x = 0;
textsize = 1;
textcolor = textbgcolor = 0xFFFF;
wrap = true;
_cp437 = false;
gfxFont = NULL;
// Draw a circle outline
void Adafruit_GFX::drawCircle(int16_t x0, int16_t y0, int16_t r,
uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t ddF_y = -2 * r;
int16_t x = 0;
int16_t y = r;
drawPixel(x0 , y0+r, color);
drawPixel(x0 , y0-r, color);
drawPixel(x0+r, y0 , color);
drawPixel(x0-r, y0 , color);
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
drawPixel(x0 + x, y0 + y, color);
drawPixel(x0 - x, y0 + y, color);
drawPixel(x0 + x, y0 - y, color);
drawPixel(x0 - x, y0 - y, color);
drawPixel(x0 + y, y0 + x, color);
drawPixel(x0 - y, y0 + x, color);
drawPixel(x0 + y, y0 - x, color);
drawPixel(x0 - y, y0 - x, color);
void Adafruit_GFX::drawCircleHelper( int16_t x0, int16_t y0,
int16_t r, uint8_t cornername, uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
if (cornername & 0x4) {
if (cornername & 0x2) {
if (cornername & 0x8) {
if (cornername & 0x1) {
void Adafruit_GFX::fillCircle(int16_t x0, int16_t y0, int16_t r,
uint16_t color) {
drawFastVLine(x0, y0-r, 2*r+1, color);
fillCircleHelper(x0, y0, r, 3, 0, color);
// Used to do circles and roundrects
void Adafruit_GFX::fillCircleHelper(int16_t x0, int16_t y0, int16_t r,
uint8_t cornername, int16_t delta, uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
drawFastVLine(x0+x, y0-y, 2*y+1+delta, color);
drawFastVLine(x0+y, y0-x, 2*x+1+delta, color);
drawFastVLine(x0-x, y0-y, 2*y+1+delta, color);
drawFastVLine(x0-y, y0-x, 2*x+1+delta, color);
// Bresenham's algorithm - thx wikpedia
void Adafruit_GFX::drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1,
uint16_t color) {
int16_t steep = abs(y1 - y0) > abs(x1 - x0);
if (steep) {
_swap_int16_t(x0, y0);
_swap_int16_t(x1, y1);
if (x0 > x1) {
_swap_int16_t(x0, x1);
_swap_int16_t(y0, y1);
int16_t dx, dy;
dx = x1 - x0;
dy = abs(y1 - y0);
int16_t err = dx / 2;
int16_t ystep;
if (y0 < y1) {
ystep = 1;
} else {
ystep = -1;
for (; x0<=x1; x0++) {
if (steep) {
drawPixel(y0, x0, color);
} else {
drawPixel(x0, y0, color);
err -= dy;
if (err < 0) {
y0 += ystep;
err += dx;
// Draw a rectangle
void Adafruit_GFX::drawRect(int16_t x, int16_t y, int16_t w, int16_t h,
uint16_t color) {
drawFastHLine(x, y, w, color);
drawFastHLine(x, y+h-1, w, color);
drawFastVLine(x, y, h, color);
drawFastVLine(x+w-1, y, h, color);
void Adafruit_GFX::drawFastVLine(int16_t x, int16_t y,
int16_t h, uint16_t color) {
// Update in subclasses if desired!
drawLine(x, y, x, y+h-1, color);
void Adafruit_GFX::drawFastHLine(int16_t x, int16_t y,
int16_t w, uint16_t color) {
drawLine(x, y, x+w-1, y, color);
void Adafruit_GFX::fillRect(int16_t x, int16_t y, int16_t w, int16_t h,
uint16_t color) {
for (int16_t i=x; i<x+w; i++) {
drawFastVLine(i, y, h, color);
void Adafruit_GFX::fillScreen(uint16_t color) {
fillRect(0, 0, _width, _height, color);
// Draw a rounded rectangle
void Adafruit_GFX::drawRoundRect(int16_t x, int16_t y, int16_t w,
int16_t h, int16_t r, uint16_t color) {
// smarter version
drawFastHLine(x+r , y , w-2*r, color); // Top
drawFastHLine(x+r , y+h-1, w-2*r, color); // Bottom
drawFastVLine(x , y+r , h-2*r, color); // Left
drawFastVLine(x+w-1, y+r , h-2*r, color); // Right
// draw four corners
drawCircleHelper(x+r , y+r , r, 1, color);
drawCircleHelper(x+w-r-1, y+r , r, 2, color);
drawCircleHelper(x+w-r-1, y+h-r-1, r, 4, color);
drawCircleHelper(x+r , y+h-r-1, r, 8, color);
// Fill a rounded rectangle
void Adafruit_GFX::fillRoundRect(int16_t x, int16_t y, int16_t w,
// smarter version
fillRect(x+r, y, w-2*r, h, color);
fillCircleHelper(x+w-r-1, y+r, r, 1, h-2*r-1, color);
fillCircleHelper(x+r , y+r, r, 2, h-2*r-1, color);
// Draw a triangle
void Adafruit_GFX::drawTriangle(int16_t x0, int16_t y0,
int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color) {
drawLine(x0, y0, x1, y1, color);
drawLine(x1, y1, x2, y2, color);
drawLine(x2, y2, x0, y0, color);
// Fill a triangle
void Adafruit_GFX::fillTriangle(int16_t x0, int16_t y0,
int16_t a, b, y, last;
// Sort coordinates by Y order (y2 >= y1 >= y0)
if (y0 > y1) {
_swap_int16_t(y0, y1); _swap_int16_t(x0, x1);
if (y1 > y2) {
_swap_int16_t(y2, y1); _swap_int16_t(x2, x1);
if (y0 > y1) {
if(y0 == y2) { // Handle awkward all-on-same-line case as its own thing
a = b = x0;
if(x1 < a) a = x1;
else if(x1 > b) b = x1;
if(x2 < a) a = x2;
else if(x2 > b) b = x2;
drawFastHLine(a, y0, b-a+1, color);
return;
int16_t
dx01 = x1 - x0,
dy01 = y1 - y0,
dx02 = x2 - x0,
dy02 = y2 - y0,
dx12 = x2 - x1,
dy12 = y2 - y1;
int32_t
sa = 0,
sb = 0;
// For upper part of triangle, find scanline crossings for segments
// 0-1 and 0-2. If y1=y2 (flat-bottomed triangle), the scanline y1
// is included here (and second loop will be skipped, avoiding a /0
// error there), otherwise scanline y1 is skipped here and handled
// in the second loop...which also avoids a /0 error here if y0=y1
// (flat-topped triangle).
if(y1 == y2) last = y1; // Include y1 scanline
else last = y1-1; // Skip it
for(y=y0; y<=last; y++) {
a = x0 + sa / dy01;
b = x0 + sb / dy02;
sa += dx01;
sb += dx02;
/* longhand:
a = x0 + (x1 - x0) * (y - y0) / (y1 - y0);
b = x0 + (x2 - x0) * (y - y0) / (y2 - y0);
if(a > b) _swap_int16_t(a,b);
drawFastHLine(a, y, b-a+1, color);
// For lower part of triangle, find scanline crossings for segments
// 0-2 and 1-2. This loop is skipped if y1=y2.
sa = dx12 * (y - y1);
sb = dx02 * (y - y0);
for(; y<=y2; y++) {
a = x1 + sa / dy12;
b = x0 + sb / dy02;
sa += dx12;
sb += dx02;
/* longhand:
a = x1 + (x2 - x1) * (y - y1) / (y2 - y1);
// Draw a 1-bit image (bitmap) at the specified (x,y) position from the
// provided bitmap buffer (must be PROGMEM memory) using the specified
// foreground color (unset bits are transparent).
void Adafruit_GFX::drawBitmap(int16_t x, int16_t y,
const uint8_t *bitmap, int16_t w, int16_t h, uint16_t color) {
int16_t i, j, byteWidth = (w + 7) / 8;
uint8_t byte;
for(j=0; j<h; j++) {
for(i=0; i<w; i++) {
if(i & 7) byte <<= 1;
else byte = pgm_read_byte(bitmap + j * byteWidth + i / 8);
if(byte & 0x80) drawPixel(x+i, y+j, color);
// foreground (for set bits) and background (for clear bits) colors.
const uint8_t *bitmap, int16_t w, int16_t h, uint16_t color, uint16_t bg) {
uint8_t byte;
for(i=0; i<w; i++ ) {
else drawPixel(x+i, y+j, bg);
// drawBitmap() variant for RAM-resident (not PROGMEM) bitmaps.
uint8_t byte;
else byte = bitmap[j * byteWidth + i / 8];
// drawBitmap() variant w/background for RAM-resident (not PROGMEM) bitmaps.
uint8_t byte;
//Draw XBitMap Files (*.xbm), exported from GIMP,
//Usage: Export from GIMP to *.xbm, rename *.xbm to *.c and open in editor.
//C Array can be directly used with this function
void Adafruit_GFX::drawXBitmap(int16_t x, int16_t y,
uint8_t byte;
if(i & 7) byte >>= 1;
if(byte & 0x01) drawPixel(x+i, y+j, color);
void Display::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet) {
drawTilemap(x, y, tilemap, spritesheet, 0, 0, LCD_2000_7775_TFTWIDTH, LCD_2000_7775_TFTHEIGHT);
void Display::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh) {
uint8_t tilemap_width = pgm_read_byte(tilemap);
uint8_t tilemap_height = pgm_read_byte(tilemap + 1);
uint8_t tile_width = pgm_read_byte(tilemap + 2);
uint8_t tile_height = pgm_read_byte(tilemap + 3);
uint8_t ddw = dw + dx;
uint8_t ddh = dh + dy;
uint8_t maxDdx = (dw - x + tile_width - 1) / tile_width;
uint8_t maxDdy = (dh - y + tile_height - 1) / tile_height;
if (tilemap_width < maxDdx) {
maxDdx = tilemap_width;
maxDdy = tilemap_height;
int8_t startDdx = (-x) / tile_width;
int8_t startDdy = (-y) / tile_height;
if (startDdx < 0) {
startDdx = 0;
if (startDdy < 0) {
startDdy = 0;
if (flagcollision)numcolision = 0; //Line 735 - clear numcolision - ADD by Summoner123
for (uint8_t ddy = startDdy; ddy < maxDdy; ddy++) {
for (uint8_t ddx = startDdx; ddx < maxDdx; ddx++) {
int8_t drawX = ddx*tile_width + x + dx;
int8_t drawY = ddy*tile_height + y + dy;
uint8_t tile = pgm_read_byte(tilemap + ddy*tilemap_width + ddx);
drawBitmap(drawX, drawY, tile_width, tile_height, spritesheet[tile]);
if (flagcollision) {
solid[numcolision].x = drawX; //Save X coordinate - ADD by Summoner123
solid[numcolision].y = drawY; //Save Y coordinate - ADD by Summoner123
solid[numcolision].spritecol = spritesheet[tile]; //Save Sprite of tile - ADD by Summoner123
numcolision++; //Increment numcolision - ADD by Summoner123
drawBitmap(drawX, drawY, tile_width, tile_height, spritesheet[tile], dx, dy, dw, dh);
#if ARDUINO >= 100
size_t Adafruit_GFX::write(uint8_t c) {
#else
void Adafruit_GFX::write(uint8_t c) {
#endif
if(!gfxFont) { // 'Classic' built-in font
if(c == '\n') {
cursor_y += textsize*8;
cursor_x = 0;
} else if(c == '\r') {
// skip em
} else {
if(wrap && ((cursor_x + textsize * 6) >= _width)) { // Heading off edge?
cursor_x = 0; // Reset x to zero
cursor_y += textsize * 8; // Advance y one line
drawChar(cursor_x, cursor_y, c, textcolor, textbgcolor, textsize);
cursor_x += textsize * 6;
} else { // Custom font
if(c == '\n') {
cursor_x = 0;
cursor_y += (int16_t)textsize *
(uint8_t)pgm_read_byte(&gfxFont->yAdvance);
} else if(c != '\r') {
uint8_t first = pgm_read_byte(&gfxFont->first);
if((c >= first) && (c <= (uint8_t)pgm_read_byte(&gfxFont->last))) {
uint8_t c2 = c - pgm_read_byte(&gfxFont->first);
GFXglyph *glyph = &(((GFXglyph *)pgm_read_pointer(&gfxFont->glyph))[c2]);
uint8_t w = pgm_read_byte(&glyph->width),
h = pgm_read_byte(&glyph->height);
if((w > 0) && (h > 0)) { // Is there an associated bitmap?
int16_t xo = (int8_t)pgm_read_byte(&glyph->xOffset); // sic
if(wrap && ((cursor_x + textsize * (xo + w)) >= _width)) {
// Drawing character would go off right edge; wrap to new line
cursor_x = 0;
cursor_x += pgm_read_byte(&glyph->xAdvance) * (int16_t)textsize;
#if ARDUINO >= 100
return 1;
#endif
// Draw a character
void Adafruit_GFX::drawChar(int16_t x, int16_t y, unsigned char c,
uint16_t color, uint16_t bg, uint8_t size) {
if((x >= _width) || // Clip right
(y >= _height) || // Clip bottom
((x + 6 * size - 1) < 0) || // Clip left
((y + 8 * size - 1) < 0)) // Clip top
return;
if(!_cp437 && (c >= 176)) c++; // Handle 'classic' charset behavior
for(int8_t i=0; i<6; i++ ) {
uint8_t line;
if(i < 5) line = pgm_read_byte(font+(c*5)+i);
else line = 0x0;
for(int8_t j=0; j<8; j++, line >>= 1) {
if(line & 0x1) {
if(size == 1) drawPixel(x+i, y+j, color);
else fillRect(x+(i*size), y+(j*size), size, size, color);
} else if(bg != color) {
if(size == 1) drawPixel(x+i, y+j, bg);
else fillRect(x+i*size, y+j*size, size, size, bg);
// Character is assumed previously filtered by write() to eliminate
// newlines, returns, non-printable characters, etc. Calling drawChar()
// directly with 'bad' characters of font may cause mayhem!
c -= pgm_read_byte(&gfxFont->first);
GFXglyph *glyph = &(((GFXglyph *)pgm_read_pointer(&gfxFont->glyph))[c]);
uint8_t *bitmap = (uint8_t *)pgm_read_pointer(&gfxFont->bitmap);
uint16_t bo = pgm_read_word(&glyph->bitmapOffset);
h = pgm_read_byte(&glyph->height),
xa = pgm_read_byte(&glyph->xAdvance);
int8_t xo = pgm_read_byte(&glyph->xOffset),
yo = pgm_read_byte(&glyph->yOffset);
uint8_t xx, yy, bits, bit = 0;
int16_t xo16, yo16;
if(size > 1) {
xo16 = xo;
yo16 = yo;
// Todo: Add character clipping here
// NOTE: THERE IS NO 'BACKGROUND' COLOR OPTION ON CUSTOM FONTS.
// THIS IS ON PURPOSE AND BY DESIGN. The background color feature
// has typically been used with the 'classic' font to overwrite old
// screen contents with new data. This ONLY works because the
// characters are a uniform size; it's not a sensible thing to do with
// proportionally-spaced fonts with glyphs of varying sizes (and that
// may overlap). To replace previously-drawn text when using a custom
// font, use the getTextBounds() function to determine the smallest
// rectangle encompassing a string, erase the area with fillRect(),
// then draw new text. This WILL infortunately 'blink' the text, but
// is unavoidable. Drawing 'background' pixels will NOT fix this,
// only creates a new set of problems. Have an idea to work around
// this (a canvas object type for MCUs that can afford the RAM and
// displays supporting setAddrWindow() and pushColors()), but haven't
// implemented this yet.
for(yy=0; yy<h; yy++) {
for(xx=0; xx<w; xx++) {
if(!(bit++ & 7)) {
bits = pgm_read_byte(&bitmap[bo++]);
if(bits & 0x80) {
if(size == 1) {
drawPixel(x+xo+xx, y+yo+yy, color);
} else {
fillRect(x+(xo16+xx)*size, y+(yo16+yy)*size, size, size, color);
bits <<= 1;
} // End classic vs custom font
void Adafruit_GFX::setCursor(int16_t x, int16_t y) {
cursor_x = x;
cursor_y = y;
int16_t Adafruit_GFX::getCursorX(void) const {
return cursor_x;
int16_t Adafruit_GFX::getCursorY(void) const {
return cursor_y;
void Adafruit_GFX::setTextSize(uint8_t s) {
textsize = (s > 0) ? s : 1;
void Adafruit_GFX::setTextColor(uint16_t c) {
// For 'transparent' background, we'll set the bg
// to the same as fg instead of using a flag
textcolor = textbgcolor = c;
void Adafruit_GFX::setTextColor(uint16_t c, uint16_t b) {
textcolor = c;
textbgcolor = b;
void Adafruit_GFX::setTextWrap(boolean w) {
wrap = w;
uint8_t Adafruit_GFX::getRotation(void) const {
return rotation;
void Adafruit_GFX::setRotation(uint8_t x) {
rotation = (x & 3);
switch(rotation) {
case 0:
case 2:
_width = WIDTH;
_height = HEIGHT;
break;
case 1:
case 3:
_width = HEIGHT;
_height = WIDTH;
break;
// Enable (or disable) Code Page 437-compatible charset.
// There was an error in glcdfont.c for the longest time -- one character
// (#176, the 'light shade' block) was missing -- this threw off the index
// of every character that followed it. But a TON of code has been written
// with the erroneous character indices. By default, the library uses the
// original 'wrong' behavior and old sketches will still work. Pass 'true'
// to this function to use correct CP437 character values in your code.
void Adafruit_GFX::cp437(boolean x) {
_cp437 = x;
void Adafruit_GFX::setFont(const GFXfont *f) {
if(f) { // Font struct pointer passed in?
if(!gfxFont) { // And no current font struct?
// Switching from classic to new font behavior.
// Move cursor pos down 6 pixels so it's on baseline.
cursor_y += 6;
} else if(gfxFont) { // NULL passed. Current font struct defined?
// Switching from new to classic font behavior.
// Move cursor pos up 6 pixels so it's at top-left of char.
cursor_y -= 6;
gfxFont = (GFXfont *)f;
// Pass string and a cursor position, returns UL corner and W,H.
void Adafruit_GFX::getTextBounds(char *str, int16_t x, int16_t y,
int16_t *x1, int16_t *y1, uint16_t *w, uint16_t *h) {
uint8_t c; // Current character
*x1 = x;
*y1 = y;
*w = *h = 0;
if(gfxFont) {
GFXglyph *glyph;
uint8_t first = pgm_read_byte(&gfxFont->first),
last = pgm_read_byte(&gfxFont->last),
gw, gh, xa;
int8_t xo, yo;
int16_t minx = _width, miny = _height, maxx = -1, maxy = -1,
gx1, gy1, gx2, gy2, ts = (int16_t)textsize,
ya = ts * (uint8_t)pgm_read_byte(&gfxFont->yAdvance);
while((c = *str++)) {
if(c != '\n') { // Not a newline
if(c != '\r') { // Not a carriage return, is normal char
if((c >= first) && (c <= last)) { // Char present in current font
c -= first;
gw = pgm_read_byte(&glyph->width);
gh = pgm_read_byte(&glyph->height);
xo = pgm_read_byte(&glyph->xOffset);
if(wrap && ((x + (((int16_t)xo + gw) * ts)) >= _width)) {
// Line wrap
x = 0; // Reset x to 0
y += ya; // Advance y by 1 line
gx1 = x + xo * ts;
gy1 = y + yo * ts;
gx2 = gx1 + gw * ts - 1;
gy2 = gy1 + gh * ts - 1;
if(gx1 < minx) minx = gx1;
if(gy1 < miny) miny = gy1;
if(gx2 > maxx) maxx = gx2;
if(gy2 > maxy) maxy = gy2;
x += xa * ts;
} // Carriage return = do nothing
} else { // Newline
x = 0; // Reset x
// End of string
*x1 = minx;
*y1 = miny;
if(maxx >= minx) *w = maxx - minx + 1;
if(maxy >= miny) *h = maxy - miny + 1;
} else { // Default font
uint16_t lineWidth = 0, maxWidth = 0; // Width of current, all lines
if(wrap && ((x + textsize * 6) >= _width)) {
y += textsize * 8; // Advance y by 1 line
if(lineWidth > maxWidth) maxWidth = lineWidth; // Save widest line
lineWidth = textsize * 6; // First char on new line
} else { // No line wrap, just keep incrementing X
lineWidth += textsize * 6; // Includes interchar x gap
} else { // Newline
lineWidth = 0; // Reset lineWidth for new line
// End of string
if(lineWidth) y += textsize * 8; // Add height of last (or only) line
*w = maxWidth - 1; // Don't include last interchar x gap
*h = y - *y1;
// Same as above, but for PROGMEM strings
void Adafruit_GFX::getTextBounds(const __FlashStringHelper *str,
int16_t x, int16_t y, int16_t *x1, int16_t *y1, uint16_t *w, uint16_t *h) {
uint8_t *s = (uint8_t *)str, c;
*x1 = x;
*y1 = y;
*w = *h = 0;
if(gfxFont) {
GFXglyph *glyph;
gw, gh, xa;
int8_t xo, yo;
while((c = pgm_read_byte(s++))) {
c -= first;
// Line wrap
gx1 = x + xo * ts;
gy1 = y + yo * ts;
x += xa * ts;
} else { // Newline
x = 0; // Reset x
// End of string
*x1 = minx;
*y1 = miny;
} else { // Newline
// End of string
*h = y - *y1;
// Return the size of the display (per current rotation)
int16_t Adafruit_GFX::width(void) const {
return _width;
int16_t Adafruit_GFX::height(void) const {
return _height;
void Adafruit_GFX::invertDisplay(boolean i) {
// Do nothing, must be subclassed if supported by hardware
//added by duhjoker lines lcd-gfx og
uint16_t Adafruit_GFX::newColor(uint8_t r, uint8_t g, uint8_t b)
return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
void Adafruit_GFX::background(uint8_t red, uint8_t green, uint8_t blue)
background(newColor(red, green, blue));
void Adafruit_GFX::background(color c) {
fillScreen(c);
void Adafruit_GFX::stroke(uint8_t red, uint8_t green, uint8_t blue)
stroke(newColor(red, green, blue));
void Adafruit_GFX::stroke(color c)
useStroke = true;
strokeColor = c;
setTextColor(c);
void Adafruit_GFX::noStroke()
useStroke = false;
void Adafruit_GFX::noFill() {
useFill = false;
void Adafruit_GFX::fill(uint8_t red, uint8_t green, uint8_t blue)
fill(newColor(red, green, blue));
void Adafruit_GFX::fill(color c)
useFill = true;
fillColor = c;
void Adafruit_GFX::text(const char * text, int16_t x, int16_t y)
if (!useStroke)
return;
setTextWrap(false);
setTextColor(strokeColor);
setCursor(x, y);
print(text);
void Adafruit_GFX::textWrap(const char * text, int16_t x, int16_t y)
if (!useStroke)
return;
setTextWrap(true);
setCursor(x, y);
print(text);
void Adafruit_GFX::textSize(uint8_t size)
setTextSize(size);
void Adafruit_GFX::point(int16_t x, int16_t y)
if (!useStroke)
return;
drawPixel(x, y, strokeColor);
void Adafruit_GFX::line(int16_t x1, int16_t y1, int16_t x2, int16_t y2)
if (!useStroke)
return;
if (x1 == x2) {
if (y1 < y2)
drawFastVLine(x1, y1, y2 - y1, strokeColor);
else
drawFastVLine(x1, y2, y1 - y2, strokeColor);
else if (y1 == y2) {
if (x1 < x2)
drawFastHLine(x1, y1, x2 - x1, strokeColor);
else
drawFastHLine(x2, y1, x1 - x2, strokeColor);
else {
drawLine(x1, y1, x2, y2, strokeColor);
void Adafruit_GFX::rect(int16_t x, int16_t y, int16_t width, int16_t height)
if (useFill) {
fillRect(x, y, width, height, fillColor);
if (useStroke) {
drawRect(x, y, width, height, strokeColor);
void Adafruit_GFX::rect(int16_t x, int16_t y, int16_t width, int16_t height, int16_t radius)
if (radius == 0) {
rect(x, y, width, height);
if (useFill) {
fillRoundRect(x, y, width, height, radius, fillColor);
if (useStroke) {
drawRoundRect(x, y, width, height, radius, strokeColor);
void Adafruit_GFX::circle(int16_t x, int16_t y, int16_t r)
if (r == 0)
return;
if (useFill) {
fillCircle(x, y, r, fillColor);
if (useStroke) {
drawCircle(x, y, r, strokeColor);
void Adafruit_GFX::triangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2, int16_t x3, int16_t y3)
if (useFill) {
fillTriangle(x1, y1, x2, y2, x3, y3, fillColor);
if (useStroke) {
drawTriangle(x1, y1, x2, y2, x3, y3, strokeColor);
// code for the GFX button UI element
Adafruit_GFX_Button::Adafruit_GFX_Button(void) {
_gfx = 0;
void Adafruit_GFX_Button::initButton(
Adafruit_GFX *gfx, int16_t x, int16_t y, uint8_t w, uint8_t h,
uint16_t outline, uint16_t fill, uint16_t textcolor,
char *label, uint8_t textsize)
_x = x;
_y = y;
_w = w;
_h = h;
_outlinecolor = outline;
_fillcolor = fill;
_textcolor = textcolor;
_textsize = textsize;
_gfx = gfx;
strncpy(_label, label, 9);
_label[9] = 0;
void Adafruit_GFX_Button::drawButton(boolean inverted) {
uint16_t fill, outline, text;
if(!inverted) {
fill = _fillcolor;
outline = _outlinecolor;
text = _textcolor;
} else {
fill = _textcolor;
text = _fillcolor;
_gfx->fillRoundRect(_x - (_w/2), _y - (_h/2), _w, _h, min(_w,_h)/4, fill);
_gfx->drawRoundRect(_x - (_w/2), _y - (_h/2), _w, _h, min(_w,_h)/4, outline);
_gfx->setCursor(_x - strlen(_label)*3*_textsize, _y-4*_textsize);
_gfx->setTextColor(text);
_gfx->setTextSize(_textsize);
_gfx->print(_label);
boolean Adafruit_GFX_Button::contains(int16_t x, int16_t y) {
if ((x < (_x - _w/2)) || (x > (_x + _w/2))) return false;
if ((y < (_y - _h/2)) || (y > (_y + _h/2))) return false;
return true;
void Adafruit_GFX_Button::press(boolean p) {
laststate = currstate;
currstate = p;
boolean Adafruit_GFX_Button::isPressed() { return currstate; }
boolean Adafruit_GFX_Button::justPressed() { return (currstate && !laststate); }
boolean Adafruit_GFX_Button::justReleased() { return (!currstate && laststate); }
// GFXcanvas1 and GFXcanvas16 (currently a WIP, don't get too comfy with the
// implementation) provide 1- and 16-bit offscreen canvases, the address of
// which can be passed to drawBitmap() or pushColors() (the latter appears
// to only be in Adafruit_TFTLCD at this time). This is here mostly to
// help with the recently-added proportionally-spaced fonts; adds a way to
// refresh a section of the screen without a massive flickering clear-and-
// redraw...but maybe you'll find other uses too. VERY RAM-intensive, since
// the buffer is in MCU memory and not the display driver...GXFcanvas1 might
// be minimally useful on an Uno-class board, but this and GFXcanvas16 are
// much more likely to require at least a Mega or various recent ARM-type
// boards (recomment, as the text+bitmap draw can be pokey). GFXcanvas1
// requires 1 bit per pixel (rounded up to nearest byte per scanline),
// GFXcanvas16 requires 2 bytes per pixel (no scanline pad).
// NOT EXTENSIVELY TESTED YET. MAY CONTAIN WORST BUGS KNOWN TO HUMANKIND.
GFXcanvas1::GFXcanvas1(uint16_t w, uint16_t h) : Adafruit_GFX(w, h) {
uint16_t bytes = ((w + 7) / 8) * h;
if((buffer = (uint8_t *)malloc(bytes))) {
memset(buffer, 0, bytes);
GFXcanvas1::~GFXcanvas1(void) {
if(buffer) free(buffer);
uint8_t* GFXcanvas1::getBuffer(void) {
return buffer;
void GFXcanvas1::drawPixel(int16_t x, int16_t y, uint16_t color) {
// Bitmask tables of 0x80>>X and ~(0x80>>X), because X>>Y is slow on AVR
static const uint8_t PROGMEM
GFXsetBit[] = { 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01 },
GFXclrBit[] = { 0x7F, 0xBF, 0xDF, 0xEF, 0xF7, 0xFB, 0xFD, 0xFE };
if(buffer) {
if((x < 0) || (y < 0) || (x >= _width) || (y >= _height)) return;
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
break;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
break;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
break;
uint8_t *ptr = &buffer[(x / 8) + y * ((WIDTH + 7) / 8)];
if(color) *ptr |= pgm_read_byte(&GFXsetBit[x & 7]);
else *ptr &= pgm_read_byte(&GFXclrBit[x & 7]);
void GFXcanvas1::fillScreen(uint16_t color) {
if(buffer) {
uint16_t bytes = ((WIDTH + 7) / 8) * HEIGHT;
memset(buffer, color ? 0xFF : 0x00, bytes);
GFXcanvas16::GFXcanvas16(uint16_t w, uint16_t h) : Adafruit_GFX(w, h) {
uint16_t bytes = w * h * 2;
if((buffer = (uint16_t *)malloc(bytes))) {
GFXcanvas16::~GFXcanvas16(void) {
uint16_t* GFXcanvas16::getBuffer(void) {
return buffer;
void GFXcanvas16::drawPixel(int16_t x, int16_t y, uint16_t color) {
if(buffer) {
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
break;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
break;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
break;
buffer[x + y * WIDTH] = color;
void GFXcanvas16::fillScreen(uint16_t color) {
if(buffer) {
uint8_t hi = color >> 8, lo = color & 0xFF;
if(hi == lo) {
memset(buffer, lo, WIDTH * HEIGHT * 2);
} else {
uint16_t i, pixels = WIDTH * HEIGHT;
for(i=0; i<pixels; i++) buffer[i] = color;
by Duhjoker » Fri Sep 23, 2016 9:55 pm
heres the .h file
#ifndef _ADAFRUIT_GFX_H
#define _ADAFRUIT_GFX_H
#if ARDUINO >= 100
#include "Arduino.h"
#include "Print.h"
#else
#include "WProgram.h"
#endif
#include "gfxfont.h"
#define LCD_2000_7775_TFTWIDTH 176
#define LCD_2000_7775_TFTHEIGHT 220
typedef uint16_t color; //added by duhjoker from lcd_gfx og
class Adafruit_GFX : public Print {
public:
Adafruit_GFX(int16_t w, int16_t h); // Constructor
// This MUST be defined by the subclass:
virtual void drawPixel(int16_t x, int16_t y, uint16_t color) = 0;
// These MAY be overridden by the subclass to provide device-specific
// optimized code. Otherwise 'generic' versions are used.
virtual void
drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color),
drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color),
drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color),
drawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color),
fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color),
fillScreen(uint16_t color),
invertDisplay(boolean i);
// These exist only with Adafruit_GFX (no subclass overrides)
void
drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color),
drawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername,
uint16_t color),
fillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color),
fillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername,
int16_t delta, uint16_t color),
drawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1,
int16_t x2, int16_t y2, uint16_t color),
fillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1,
drawRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h,
int16_t radius, uint16_t color),
fillRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h,
drawBitmap(int16_t x, int16_t y, const uint8_t *bitmap,
int16_t w, int16_t h, uint16_t color, uint16_t bg),
drawBitmap(int16_t x, int16_t y, uint8_t *bitmap,
drawXBitmap(int16_t x, int16_t y, const uint8_t *bitmap,
drawChar(int16_t x, int16_t y, unsigned char c, uint16_t color,
uint16_t bg, uint8_t size),
setCursor(int16_t x, int16_t y),
setTextColor(uint16_t c),
setTextColor(uint16_t c, uint16_t bg),
setTextSize(uint8_t s),
setTextWrap(boolean w),
setRotation(uint8_t r),
cp437(boolean x=true),
setFont(const GFXfont *f = NULL),
getTextBounds(char *string, int16_t x, int16_t y,
int16_t *x1, int16_t *y1, uint16_t *w, uint16_t *h),
getTextBounds(const __FlashStringHelper *s, int16_t x, int16_t y,
int16_t *x1, int16_t *y1, uint16_t *w, uint16_t *h);
void drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet);
void drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh);
//#if ARDUINO >= 100
virtual size_t write(uint8_t);
//#else
// virtual void write(uint8_t);
//#endif
boolean persistence; //disable clean() at each frame if true
boolean textWrap; // If set, 'wrap' text at right edge of
uint8_t fontSize;
int8_t cursorX, cursorY;
byte contrast;
byte frameCount;
typedef struct { //line 171 "Public Variables - ADD by Summoner123
int x; //X coordinate - ADD by Summoner123
int y; //Y coordinate - ADD by Summoner123
const byte *spritecol; //Sprite of object - ADD by Summoner123
}object;
object solid[60]; // Matriz were saved a Sprite, X and Y cordinates of all tiles on the screen - ADD by Summoner123
byte numcolision = 0; //count of solid objects indacat how many tiles drawed on the screen - ADD by Summoner123
bool flagcollision = true;
private:
int8_t sclk, din, dc, cs, rst;
volatile uint8_t *mosiport, *clkport, *csport, *dcport;
uint8_t mosipinmask, clkpinmask, cspinmask, dcpinmask;
uint8_t *font;
uint8_t color, bgcolor;
// added by duhjoker from lcd_gfx oglines 91 to 143 mainly garbage but would not compile example with out
void
// http://processing.org/reference/background_.html
background(uint8_t red, uint8_t green, uint8_t blue),
background(color c),
// http://processing.org/reference/fill_.html
fill(uint8_t red, uint8_t green, uint8_t blue),
fill(color c),
// http://processing.org/reference/noFill_.html
noFill(),
// http://processing.org/reference/stroke_.html
stroke(uint8_t red, uint8_t green, uint8_t blue),
stroke(color c),
// http://processing.org/reference/noStroke_.html
noStroke(),
text(const char * text, int16_t x, int16_t y),
textWrap(const char * text, int16_t x, int16_t y),
textSize(uint8_t size);
// similar to ellipse() in Processing, but with
// a single radius.
// http://processing.org/reference/ellipse_.html
void circle(int16_t x, int16_t y, int16_t r);
void point(int16_t x, int16_t y);
void line(int16_t x1, int16_t y1, int16_t x2, int16_t y2);
void quad(int16_t x1, int16_t y1, int16_t x2, int16_t y2, int16_t x3, int16_t y3, int16_t x4, int16_t y4);
void rect(int16_t x, int16_t y, int16_t width, int16_t height);
void rect(int16_t x, int16_t y, int16_t width, int16_t height, int16_t radius);
void triangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2, int16_t x3, int16_t y3);
/* TODO
void rectMode(RectMode mode);
void pushStyle();
void popStyle();
// get current cursor position (get rotation safe maximum values, using: width() for x, height() for y)
// end duhjoker lcd_gfx
protected:
const int16_t
WIDTH, HEIGHT; // This is the 'raw' display w/h - never changes
int16_t
_width, _height, // Display w/h as modified by current rotation
cursor_x, cursor_y;
uint16_t
textcolor, textbgcolor;
uint8_t
textsize,
rotation;
boolean
wrap, // If set, 'wrap' text at right edge of display
_cp437; // If set, use correct CP437 charset (default is off)
GFXfont
*gfxFont;
* Processing-style graphics state
color strokeColor;
bool useStroke;
color fillColor;
bool useFill;
class Adafruit_GFX_Button {
public:
Adafruit_GFX_Button(void);
void initButton(Adafruit_GFX *gfx, int16_t x, int16_t y,
uint8_t w, uint8_t h, uint16_t outline, uint16_t fill,
uint16_t textcolor, char *label, uint8_t textsize);
void drawButton(boolean inverted = false);
boolean contains(int16_t x, int16_t y);
void press(boolean p);
boolean isPressed();
boolean justPressed();
boolean justReleased();
private:
Adafruit_GFX *_gfx;
int16_t _x, _y;
uint16_t _w, _h;
uint8_t _textsize;
uint16_t _outlinecolor, _fillcolor, _textcolor;
char _label[10];
boolean currstate, laststate;
class GFXcanvas1 : public Adafruit_GFX {
public:
GFXcanvas1(uint16_t w, uint16_t h);
~GFXcanvas1(void);
void drawPixel(int16_t x, int16_t y, uint16_t color),
fillScreen(uint16_t color);
uint8_t *getBuffer(void);
private:
uint8_t *buffer;
class GFXcanvas16 : public Adafruit_GFX {
GFXcanvas16(uint16_t w, uint16_t h);
~GFXcanvas16(void);
uint16_t *getBuffer(void);
private:
uint16_t *buffer;
#endif // _ADAFRUIT_GFX_H
by jonnection » Sat Sep 24, 2016 12:32 am
The message you are getting means that your function called "height" is declared in a way that is reserved for members only.
No, I am not joking.
The const at the end of the function declaration refers to a "hidden" parameter called "this" that all class member functions receive automatically. However, your "height" function is declared OUTSIDE of a class and therefore he declaration is invalid.
If you check the line above the error you see a };
That actually closes your class before you get to the height function - functions below that are no longer members of the class. I don't think thats what you intended, so I think you have a simple typing error there.
by Duhjoker » Sat Sep 24, 2016 9:10 am
ok so I ended up starting over a few hours ago on account that forgot to add notation so I couldn't remember what I added and what not. Its a lot cleaner now but I noted everything I added to the file and iwas quite thorough.
it took me a minute to figure out that I needed to remove the const in those two now that error is gone. im still getting this error now......
from C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\examples\TFTDisplayText_UNO\TFTDisplayText_UNO.ino:19:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:167:2: error: expected unqualified-id before 'protected'
protected:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src/utility/Adafruit_GFX.h:193:1: error: expected declaration before '}' token
I know its a rookie mistake but after looking it up, I still don't know wether to add a ; or { or what. the commands above. or what do about the protected error
#if ARDUINO >= 100
#include "Print.h"
#else
#endif
//#include <SPI.h> //ADDED BY duhjoker for gamebuino
#define LCD_2000_7775_TFTWIDTH 176 //For width below
#define LCD_2000_7775_TFTHEIGHT 220 //for height below
public:
virtual void
void
uint16_t color),
void drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet); //summoner123
void drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh); //summoner123
#if ARDUINO >= 100 //GFX
virtual size_t write(uint8_t); //GFX //gamebuino
#else //GFX
virtual void write(uint8_t); //GFX
#endif //GFX
boolean persistence; //disable clean() at each frame if true //summoner123
boolean textWrap; // If set, 'wrap' text at right edge of //summoner123
uint8_t fontSize; //summoner123
int8_t cursorX, cursorY; //summoner123
byte contrast; //summoner123
byte frameCount; //summoner123
private: //summoner123
int8_t sclk, din, dc, cs, rst; //summoner123
volatile uint8_t *mosiport, *clkport, *csport, *dcport; //summoner123
uint8_t mosipinmask, clkpinmask, cspinmask, dcpinmask; //summoner123
uint8_t *font; //summoner123
uint8_t color, bgcolor; //summoner123
int16_t height(void) const; //GFX
int16_t width(void) const; //GFX
//}; //END SUMMONER123
void
fill(color c),
noFill(),
stroke(color c),
noStroke(),
// a single radius.
/* TODO
void pushStyle();
void popStyle();
int16_t getCursorX(void);// const;
int16_t getCursorY(void);// const;
protected:
const int16_t
int16_t
cursor_x, cursor_y;
uint16_t
uint8_t
textsize,
rotation;
boolean
GFXfont
*gfxFont;
color strokeColor;
bool useStroke;
color fillColor;
bool useFill;
public:
private:
Adafruit_GFX *_gfx;
int16_t _x, _y;
uint16_t _w, _h;
uint8_t _textsize;
char _label[10];
public:
~GFXcanvas1(void);
private:
uint8_t *buffer;
~GFXcanvas16(void);
private:
uint16_t *buffer;
#ifdef __AVR__
#endif
#endif
#endif
#endif
#else
#endif
#ifndef min
#endif
#endif
WIDTH(w), HEIGHT(h)
_width = WIDTH;
_height = HEIGHT;
rotation = 0;
textsize = 1;
wrap = true;
_cp437 = false;
gfxFont = NULL;
uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
uint16_t color) {
if (steep) {
if (x0 > x1) {
int16_t dx, dy;
dx = x1 - x0;
dy = abs(y1 - y0);
int16_t ystep;
if (y0 < y1) {
ystep = 1;
} else {
ystep = -1;
if (steep) {
} else {
err -= dy;
if (err < 0) {
y0 += ystep;
err += dx;
// Draw a rectangle
uint16_t color) {
uint16_t color) {
// smarter version
// smarter version
// Draw a triangle
// Fill a triangle
if (y0 > y1) {
if (y1 > y2) {
if (y0 > y1) {
a = b = x0;
if(x1 < a) a = x1;
if(x2 < a) a = x2;
return;
int16_t
dx01 = x1 - x0,
dy01 = y1 - y0,
dx02 = x2 - x0,
dy02 = y2 - y0,
dx12 = x2 - x1,
dy12 = y2 - y1;
int32_t
sa = 0,
sb = 0;
a = x0 + sa / dy01;
b = x0 + sb / dy02;
sa += dx01;
sb += dx02;
/* longhand:
for(; y<=y2; y++) {
a = x1 + sa / dy12;
b = x0 + sb / dy02;
sa += dx12;
sb += dx02;
/* longhand:
uint8_t byte;
uint8_t byte;
uint8_t byte;
uint8_t byte;
uint8_t byte;
void Display::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet) { //summoner123
drawTilemap(x, y, tilemap, spritesheet, 0, 0, LCD_2000_7775_TFTWIDTH, LCD_2000_7775_TFTHEIGHT); //Changed width and height to match this software duhjoker //summoner123
void Display::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh) { //summoner123
uint8_t tilemap_width = pgm_read_byte(tilemap); //summoner123
uint8_t tilemap_height = pgm_read_byte(tilemap + 1); //summoner123
uint8_t tile_width = pgm_read_byte(tilemap + 2); //summoner123
uint8_t tile_height = pgm_read_byte(tilemap + 3); //summoner123
tilemap += 4; // now the first tiyleis at tilemap //summoner123
uint8_t ddw = dw + dx; //summoner123
uint8_t ddh = dh + dy; //summoner123
uint8_t maxDdx = (dw - x + tile_width - 1) / tile_width; //summoner123
uint8_t maxDdy = (dh - y + tile_height - 1) / tile_height; //summoner123
if (tilemap_width < maxDdx) { //summoner123
maxDdx = tilemap_width; //summoner123
} //summoner123
if (tilemap_height < maxDdy) { //summoner123
maxDdy = tilemap_height; //summoner123
} //summoner123
int8_t startDdx = (-x) / tile_width; //summoner123
int8_t startDdy = (-y) / tile_height; //summoner123
if (startDdx < 0) { //summoner123
startDdx = 0; //summoner123
} //summoner123
if (startDdy < 0) { //summoner123
startDdy = 0; //summoner123
} //summoner123
if (flagcollision)numcolision = 0; //summoner123 //Line 735 - clear numcolision - ADD by Summoner123
for (uint8_t ddy = startDdy; ddy < maxDdy; ddy++) { //summoner123
for (uint8_t ddx = startDdx; ddx < maxDdx; ddx++) { //summoner123
int8_t drawX = ddx*tile_width + x + dx; //summoner123
int8_t drawY = ddy*tile_height + y + dy; //summoner123
uint8_t tile = pgm_read_byte(tilemap + ddy*tilemap_width + ddx); //summoner123
if (drawX >= dx && drawY >= dy && drawX <= (ddw - tile_width) && drawY <= (ddh - tile_height)) { //summoner123
drawBitmap(drawX, drawY, tile_width, tile_height, spritesheet[tile]); //summoner123
if (flagcollision) { //summoner123
} //summoner123
} //summoner123
else { // we need to draw a partial bitmap //summoner123
drawBitmap(drawX, drawY, tile_width, tile_height, spritesheet[tile], dx, dy, dw, dh); //summoner123
} // End summoner123
#if ARDUINO >= 100
#else
#endif
if(c == '\n') {
cursor_x = 0;
// skip em
} else {
if(c == '\n') {
cursor_x = 0;
cursor_x = 0;
#if ARDUINO >= 100
return 1;
#endif
// Draw a character
return;
uint8_t line;
else line = 0x0;
if(line & 0x1) {
int16_t xo16, yo16;
if(size > 1) {
xo16 = xo;
yo16 = yo;
if(!(bit++ & 7)) {
if(bits & 0x80) {
if(size == 1) {
} else {
bits <<= 1;
cursor_x = x;
cursor_y = y;
return cursor_x;
return cursor_y;
textcolor = c;
textbgcolor = b;
wrap = w;
return rotation;
rotation = (x & 3);
switch(rotation) {
case 0:
case 2:
_width = WIDTH;
_height = HEIGHT;
break;
case 1:
case 3:
_width = HEIGHT;
_height = WIDTH;
break;
_cp437 = x;
cursor_y += 6;
cursor_y -= 6;
*x1 = x;
*y1 = y;
*w = *h = 0;
if(gfxFont) {
GFXglyph *glyph;
gw, gh, xa;
int8_t xo, yo;
c -= first;
// Line wrap
gx1 = x + xo * ts;
gy1 = y + yo * ts;
x += xa * ts;
} else { // Newline
x = 0; // Reset x
// End of string
*x1 = minx;
*y1 = miny;
} else { // Newline
// End of string
*h = y - *y1;
*x1 = x;
*y1 = y;
*w = *h = 0;
if(gfxFont) {
GFXglyph *glyph;
gw, gh, xa;
int8_t xo, yo;
c -= first;
// Line wrap
gx1 = x + xo * ts;
gy1 = y + yo * ts;
x += xa * ts;
} else { // Newline
x = 0; // Reset x
// End of string
*x1 = minx;
*y1 = miny;
} else { // Newline
// End of string
*h = y - *y1;
return _width;
return _height;
fillScreen(c);
useStroke = true;
strokeColor = c;
setTextColor(c);
useStroke = false;
useFill = false;
useFill = true;
fillColor = c;
if (!useStroke)
return;
setTextWrap(false);
setCursor(x, y);
print(text);
if (!useStroke)
return;
setTextWrap(true);
setCursor(x, y);
print(text);
setTextSize(size);
if (!useStroke)
return;
if (!useStroke)
return;
if (x1 == x2) {
if (y1 < y2)
else
if (x1 < x2)
else
else {
if (useFill) {
if (useStroke) {
if (radius == 0) {
if (useFill) {
if (useStroke) {
if (r == 0)
return;
if (useFill) {
if (useStroke) {
if (useFill) {
if (useStroke) {
_gfx = 0;
_x = x;
_y = y;
_w = w;
_h = h;
_fillcolor = fill;
_gfx = gfx;
_label[9] = 0;
if(!inverted) {
fill = _fillcolor;
text = _textcolor;
} else {
fill = _textcolor;
text = _fillcolor;
return true;
currstate = p;
return buffer;
if(buffer) {
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
break;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
break;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
break;
if(buffer) {
return buffer;
if(buffer) {
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
break;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
break;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
break;
if(buffer) {
if(hi == lo) {
} else {
by jonnection » Sat Sep 24, 2016 11:23 am
You still have the same problem, but in a different place now. Its on the line below the "virtual uint16_t newColor"
}; // HEY DUHJOKER, YOUR CLASS ENDS HERE (<--- meaning the "};") . WHATS BELOW THIS IS NOT INSIDE THE CLASS ANYMORE
void
Now, I keep telling you you need to attack this thing in stages. You seem unsure about how C++ classes are declared and you need to clear that up first. You're going to have to understand them, because there are virtual functions and all sorts of advanced things in the Adafruit library, and they are a real bitch to get to compile if you do not understand the basics of how classes work.
On the other hand I admire your fearless "hands-on" way of learning
My advice is to try to make some C++ classes of your own by yourself just to learn the syntax. Otherwise you'll be going around in circles. And this is said in the most friendly tone possible. For example, check out
http://www.cplusplus.com/doc/tutorial/classes/
by Duhjoker » Sat Sep 24, 2016 8:28 pm
Fear is the mind killer, lol. I've always been a hands on learner. Taking things in stages is excellent advice. My first several tries of getting the teensy's GFX to work with the LCD code were disasters cause I hept trying to add too much at one time. Once I started doing things one at a time i got better results.
Admittedly there's a lot more for me to learn and a ton of reading I need to do. Bracket placement has been my worst enemy in this though. Not knowing what to include in a class and what goes in another etc.
by Duhjoker » Sun Sep 25, 2016 6:19 am
Ive had some luck today with tilemap routine in the gfx files. I did some moving around with some stuff and now im not getting .h problems. so now I need to get the .cpp file fixed. I fixed a few things but im having a problem I had once before but I cant think of how I fixed it. maybe some one could give a few hints?
heres the errors
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawTilemap(int, int, const uint8_t*, const uint8_t**, uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:464:6: error: 'flagcollision' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:464:20: error: 'numcolision' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:472:72: error: no matching function for call to 'Adafruit_GFX::drawBitmap(int8_t&, int8_t&, uint8_t&, uint8_t&, const uint8_t*&)'
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:472:72: note: candidates are:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:352:6: note: void Adafruit_GFX::drawBitmap(int16_t, int16_t, const uint8_t*, int16_t, int16_t, uint16_t)
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:352:6: note: candidate expects 6 arguments, 5 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:370:6: note: void Adafruit_GFX::drawBitmap(int16_t, int16_t, const uint8_t*, int16_t, int16_t, uint16_t, uint16_t)
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:370:6: note: candidate expects 7 arguments, 5 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:387:6: note: void Adafruit_GFX::drawBitmap(int16_t, int16_t, uint8_t*, int16_t, int16_t, uint16_t)
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:387:6: note: candidate expects 6 arguments, 5 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:403:6: note: void Adafruit_GFX::drawBitmap(int16_t, int16_t, uint8_t*, int16_t, int16_t, uint16_t, uint16_t)
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:403:6: note: candidate expects 7 arguments, 5 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:474:9: error: 'flagcollision' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:475:6: error: 'solid' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:475:12: error: 'numcolision' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:482:88: error: no matching function for call to 'Adafruit_GFX::drawBitmap(int8_t&, int8_t&, uint8_t&, uint8_t&, const uint8_t*&, uint8_t&, uint8_t&, uint8_t&, uint8_t&)'
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:482:88: note: candidates are:
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:352:6: note: candidate expects 6 arguments, 9 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:370:6: note: candidate expects 7 arguments, 9 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:387:6: note: candidate expects 6 arguments, 9 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:403:6: note: candidate expects 7 arguments, 9 provided
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawChar(int16_t, int16_t, unsigned char, uint16_t, uint16_t, uint8_t)':
C:\Users\duhjoker\Documents\Arduino\libraries\LCD_2000_7775\src\utility\Adafruit_GFX.cpp:586:14: warning: unused variable 'xa' [-Wunused-variable]
the h file
#if ARDUINO >= 100
#include "Print.h"
#else
#endif
public:
// typedef uint16_t color; //added by duhjoker from lcd_gfx og
virtual void
void
uint16_t color),
void background(uint8_t red, uint8_t green, uint8_t blue); //moved from below
void background(color c); //moved from below
// http://processing.org/reference/fill_.html //moved from below
void fill(uint8_t red, uint8_t green, uint8_t blue); //moved from below
void fill(color c); //moved from below
// http://processing.org/reference/noFill_.html //moved from below
void noFill(); //moved from below
// http://processing.org/reference/stroke_.html //moved from below
void stroke(uint8_t red, uint8_t green, uint8_t blue); //moved from below
void stroke(color c); //moved from below
// http://processing.org/reference/noStroke_.html //moved from below
void noStroke(); //moved from below
void text(const char * text, int16_t x, int16_t y); //moved from below
//void textWrap(const char * text, int16_t x, int16_t y); //moved from below
void textSize(uint8_t size); //moved from below
#else //GFX
#endif //GFX
//uint8_t color, bgcolor; //summoner123 24th
//void need to delete
// void background(uint8_t red, uint8_t green, uint8_t blue);
// void background(color c);
// void fill(uint8_t red, uint8_t green, uint8_t blue);
// void fill(color c);
// void noFill();
// void stroke(uint8_t red, uint8_t green, uint8_t blue);
// void stroke(color c);
// void noStroke();
// void text(const char * text, int16_t x, int16_t y);
// void textSize(uint8_t size);
// a single radius.
/* TODO
void pushStyle();
void popStyle();
int16_t getCursorX(void);// const; duhjoker
int16_t getCursorY(void);// const; duhjoker
protected:
const int16_t
int16_t
cursor_x, cursor_y;
uint16_t
uint8_t
textsize,
rotation;
boolean
GFXfont
*gfxFont;
color strokeColor;
bool useStroke;
color fillColor;
bool useFill;
public:
private:
Adafruit_GFX *_gfx;
int16_t _x, _y;
uint16_t _w, _h;
uint8_t _textsize;
char _label[10];
public:
~GFXcanvas1(void);
private:
uint8_t *buffer;
~GFXcanvas16(void);
private:
uint16_t *buffer;
and the cpp
#ifdef __AVR__
#endif
#endif
#endif
#endif
#else
#endif
#ifndef min
#endif
#endif
WIDTH(w), HEIGHT(h)
_width = WIDTH;
_height = HEIGHT;
rotation = 0;
textsize = 1;
wrap = true;
_cp437 = false;
gfxFont = NULL;
uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
uint16_t color) {
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
int16_t y = r;
while (x<y) {
if (f >= 0) {
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
uint16_t color) {
if (steep) {
if (x0 > x1) {
int16_t dx, dy;
dx = x1 - x0;
dy = abs(y1 - y0);
int16_t ystep;
if (y0 < y1) {
ystep = 1;
} else {
ystep = -1;
if (steep) {
} else {
err -= dy;
if (err < 0) {
y0 += ystep;
err += dx;
// Draw a rectangle
uint16_t color) {
uint16_t color) {
// smarter version
// smarter version
// Draw a triangle
// Fill a triangle
if (y0 > y1) {
if (y1 > y2) {
if (y0 > y1) {
a = b = x0;
if(x1 < a) a = x1;
if(x2 < a) a = x2;
return;
int16_t
dx01 = x1 - x0,
dy01 = y1 - y0,
dx02 = x2 - x0,
dy02 = y2 - y0,
dx12 = x2 - x1,
dy12 = y2 - y1;
int32_t
sa = 0,
sb = 0;
a = x0 + sa / dy01;
b = x0 + sb / dy02;
sa += dx01;
sb += dx02;
/* longhand:
for(; y<=y2; y++) {
a = x1 + sa / dy12;
b = x0 + sb / dy02;
sa += dx12;
sb += dx02;
/* longhand:
uint8_t byte;
uint8_t byte;
uint8_t byte;
uint8_t byte;
uint8_t byte;
void Adafruit_GFX::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet) { //summoner123
void Adafruit_GFX::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh) { //summoner123
} //summoner123
} //summoner123
} //summoner123
} //summoner123
} //summoner123
} //summoner123
#if ARDUINO >= 100
#else
#endif
if(c == '\n') {
cursor_x = 0;
// skip em
} else {
if(c == '\n') {
cursor_x = 0;
cursor_x = 0;
#if ARDUINO >= 100
return 1;
#endif
// Draw a character
return;
uint8_t line;
else line = 0x0;
if(line & 0x1) {
int16_t xo16, yo16;
if(size > 1) {
xo16 = xo;
yo16 = yo;
if(!(bit++ & 7)) {
if(bits & 0x80) {
if(size == 1) {
} else {
bits <<= 1;
cursor_x = x;
cursor_y = y;
int16_t Adafruit_GFX::getCursorX(void){ //removed const
return cursor_x;
int16_t Adafruit_GFX::getCursorY(void){ //removed const
return cursor_y;
textcolor = c;
textbgcolor = b;
wrap = w;
return rotation;
rotation = (x & 3);
switch(rotation) {
case 0:
case 2:
_width = WIDTH;
_height = HEIGHT;
break;
case 1:
case 3:
_width = HEIGHT;
_height = WIDTH;
break;
_cp437 = x;
cursor_y += 6;
cursor_y -= 6;
*x1 = x;
*y1 = y;
*w = *h = 0;
if(gfxFont) {
GFXglyph *glyph;
gw, gh, xa;
int8_t xo, yo;
c -= first;
// Line wrap
gx1 = x + xo * ts;
gy1 = y + yo * ts;
x += xa * ts;
} else { // Newline
x = 0; // Reset x
// End of string
*x1 = minx;
*y1 = miny;
} else { // Newline
// End of string
*h = y - *y1;
*x1 = x;
*y1 = y;
*w = *h = 0;
if(gfxFont) {
GFXglyph *glyph;
gw, gh, xa;
int8_t xo, yo;
c -= first;
// Line wrap
gx1 = x + xo * ts;
gy1 = y + yo * ts;
x += xa * ts;
} else { // Newline
x = 0; // Reset x
// End of string
*x1 = minx;
*y1 = miny;
} else { // Newline
// End of string
*h = y - *y1;
return _width;
return _height;
fillScreen(c);
useStroke = true;
strokeColor = c;
setTextColor(c);
useStroke = false;
useFill = false;
useFill = true;
fillColor = c;
if (!useStroke)
return;
setTextWrap(false);
setCursor(x, y);
print(text);
//void Adafruit_GFX::textWrap(const char * text, int16_t x, int16_t y)
// if (!useStroke)
// return;
// setTextWrap(true);
// setTextColor(strokeColor);
// setCursor(x, y);
// print(text);
setTextSize(size);
if (!useStroke)
return;
if (!useStroke)
return;
if (x1 == x2) {
if (y1 < y2)
else
if (x1 < x2)
else
else {
if (useFill) {
if (useStroke) {
if (radius == 0) {
if (useFill) {
if (useStroke) {
if (r == 0)
return;
if (useFill) {
if (useStroke) {
if (useFill) {
if (useStroke) {
_gfx = 0;
_x = x;
_y = y;
_w = w;
_h = h;
_fillcolor = fill;
_gfx = gfx;
_label[9] = 0;
if(!inverted) {
fill = _fillcolor;
text = _textcolor;
} else {
fill = _textcolor;
text = _fillcolor;
return true;
currstate = p;
return buffer;
if(buffer) {
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
break;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
break;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
break;
if(buffer) {
return buffer;
if(buffer) {
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
break;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
break;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
break;
if(buffer) {
if(hi == lo) {
} else {
On the arguments and candidates? Why now. The code compiled before I added the tile map function. Why are they giving me errors now?
The collision error was fixed easily enough I had actually for got to declare the data.
by Duhjoker » Sun Sep 25, 2016 9:20 am
No relevant information
Duhjoker on Thu Oct 20, 2016 6:12 am, edited 1 time in total.
by Duhjoker » Wed Sep 28, 2016 6:10 am
I'm noticing in the display.h and .cpp files that there are four different functions in a row for but the reference only lists the arguments explanation of one of the draw bit map functions. What are the other arguments especially for the ones ending in bg?
by rodot » Wed Sep 28, 2016 6:46 am
As indicated in the reference the arguments in
italic are optional, so you can either use
gb.display.drawBitmap(x,y,bitmap,rotation,flip)
or just
gb.display.drawBitmap(x,y,bitmap)
