Loading bitmaps from SD
Re: Loading bitmaps from SD
Postby Duhjoker » Wed Dec 07, 2016 4:05 am
Glad you joined mougino. This is a nice piece of code here. As far as libraries I've been using summoner123's library since it had an easy tilemap function. I am actually using it for a color display and I was hoping to keep the library as easy which is why I like your code.
I can almost simply put it into my display.h and .cpp files and call it in sketch. Just needs a lil tweaking.
for instance.... I need this bit of code written so I can use the draw from command to create tilemaps easily and cheaply.
//GAMEBUINO
void Display::drawBitmap(int8_t x, int8_t y, int8_t w, int8_t h, const uint8_t *bitmap, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh, uint16_t color) {
   dw += dx;
   dh += dy;
   int8_t largest = 0;
   int8_t largesty = 0;
   for (j = 0; j < h; j++) {
      for (i = 0; i < w; i++) {
            int8_t drawX = x + i;
            int8_t drawY = y + j;
            if (drawX >= dx && drawX < dw && drawY >= dy && drawY < dh) {
               drawPixel(x, y, color);
so I can use it with these
void Display::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint16_t color) {
   drawTilemap(x, y, tilemap, spritesheet, 0, 0, LCDWIDTH, LCDHEIGHT, color);
void Display::drawTilemap(int x, int y, const uint8_t *tilemap, const uint8_t **spritesheet, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh, uint16_t color) {
   uint8_t tilemap_width = pgm_read_byte(tilemap);
   uint8_t tilemap_height = pgm_read_byte(tilemap + 1);
   uint8_t tile_width = pgm_read_byte(tilemap + 2);
   uint8_t tile_height = pgm_read_byte(tilemap + 3);
   uint8_t ddw = dw + dx;
   uint8_t ddh = dh + dy;
   uint8_t maxDdx = (dw - x + tile_width - 1) / tile_width;
   uint8_t maxDdy = (dh - y + tile_height - 1) / tile_height;
   if (tilemap_width < maxDdx) {
      maxDdx = tilemap_width;
      maxDdy = tilemap_height;
   int8_t startDdx = (-x) / tile_width;
   int8_t startDdy = (-y) / tile_height;
   if (startDdx < 0) {
      startDdx = 0;
   if (startDdy < 0) {
      startDdy = 0;
   if (flagcollision)numcolision = 0;                                 //Line 735 - clear numcolision - ADD by Summoner123
   for (uint8_t ddy = startDdy; ddy < maxDdy; ddy++) {
      for (uint8_t ddx = startDdx; ddx < maxDdx; ddx++) {
         int8_t drawX = ddx*tile_width + x + dx;
         int8_t drawY = ddy*tile_height + y + dy;
         uint8_t tile = pgm_read_byte(tilemap + ddy*tilemap_width + ddx);
            drawBitmap1(drawX, drawY, spritesheet[tile], tile_width, tile_height, color);
            if (flagcollision) {
               solid[numcolision].x = drawX;                     //Save X coordinate      - ADD by Summoner123
               solid[numcolision].y = drawY;                     //Save Y coordinate      - ADD by Summoner123
               solid[numcolision].spritecol = spritesheet[tile]; //Save Sprite of tile    - ADD by Summoner123
               numcolision++;                                    //Increment numcolision  - ADD by Summoner123
            drawBitmap(drawX, drawY, tile_width, tile_height, spritesheet[tile], dx, dy, dw, dh, color);
ive only created a couple simple functions so I don't know how to proceed.
thank you also sutchig as adding those includes fixed the tx rx problem.but...........
now im having problems with the teensy 3.2`s print.h file which defines BYTE as 0, don't know what to do about that either. it wont compile because of byte in the pff.h file
I'm also getting a dstatus does not name a type in diskio #28:1
On the DrawBitMapfromSD example it has two draw bit map commands the drawbitmapfromSD and function and another that's says draw inverted color bitmap from SRAM. Am I to understand that the actual drawbitmapfromSD function uses the drawBitMap from sram function in order to actually put it together and draw the bitmap from the data retrieved from the drawbitmapfromSD function? If that made any since at all.
Edit: ok I'm having problems with both byte in the petitfatfs integer.h and teensy's print.h with the define byte 0. I've tried a couple things like undefinining it and marking it out but I'm pretty marking it out in print.h is not going to work And I'm still having trouble with the RX TX stuff. Error still points to loop_until_byte_is_set specifically the variable spif,
Postby Duhjoker » Thu Dec 08, 2016 7:00 am
Ok so I tried mouginos Gamebuino library but I still get the byte errors which is due to my teensy 3.2's print.h file.
But I'm still getting errors about spif not being declared in the TX and RX's loop_until_byte_is_set command. I keep looking through the petitfatfs library but I can't find any reference to the command.
edit::: to use the petitfatfs with your teensy you will have to add a simple modification in the petitfatfs.h file....
#ifdef BYTE
#undef BYTE
#endif
I will have to make a note of this in my libraries display file since its to do with a display command.
Edit:::: progress!!!! Thanks to KurtE for this fix to use the petitfatfs the RX TX lines should be written like so........
byte rx() {return SPI.transfer(0xff);}
void tx(byte d) {SPI.transfer(d);}
Previous
Users browsing this forum: No registered users and 64 guests
