by yawn » Wed Dec 07, 2016 3:57 pm
Sorry for the harsh title but it sounded like an attention grabber...
I have read the wiki sound page multiple times and remain with no idea how to make sounds. Forum searches have yielded no useful results, I have found some examples but none with explanatory comments.
Would someone be kind enough to provide a small tutorial about how to create sounds?
yawn
by STUDIOCRAFTapps » Wed Dec 07, 2016 10:21 pm
It's pretty simple, first, you need to create and get sound data. Use
http://www.yodasvideoarcade.com/gamebuino.php%20FX-SYNTH. Mess around with this "game". When you're done and happy with the sound, save the sound. How to save the sound? Use this for example:
const int soundfx[8][8] = {
{1,27,90,2,7,7,3,7}, //jump <
{1,27,112,1,1,1,6,4}, // walljump <
{0,27,57,1,1,1,6,4}, // unlockdoor <
{0,9,57,1,6,8,7,8}, // land
{0,46,57,1,0,18,7,47}, // getkey <
{0,38,79,3,6,7,7,20}, // finish <
{0,30,68,3,0,0,7,5}, // click <
{0,30,55,1,7,0,7,15} //death <
All your sound will be saved this way. In FX-SYNTH, you can see the numbers, write them in the array this way: WAVEFORM, PITCH, PMD, PMT, VMD, VMT, VOL, LENGTH. If you want to play a sound, use this function
void sfx(int fxno, int channel) {
gb.sound.command(0, soundfx[fxno][6], 0, channel); // set volume
gb.sound.command(1, soundfx[fxno][0], 0, channel); // set waveform
gb.sound.command(2, soundfx[fxno][5], -soundfx[fxno][4], channel); // set volume slide
gb.sound.command(3, soundfx[fxno][3], soundfx[fxno][2] - 58, channel); // set pitch slide
gb.sound.playNote(soundfx[fxno][1], soundfx[fxno][7], channel); // play note
//WAVEFORM, PITCH, PMD, PMT, VMD, VMT, VOL, LENGTH
and call it this way:
sfx(/*The id of the sound, for exemple "jump" is 0, land is 3...*/, /*The channel need to be in the range of 0 to 3, if you haven't modify setting.c to change the NUM_CHANNEL, you can use only the first channel (0)*/);
'Hope it will work, if you don't understand something I have said (I normally speak french), please ask it.
STUDIOCRAFTapps
by yawn » Thu Dec 08, 2016 8:16 am
Thanks Studiocraft Apps,
I should have mentionned I have seen this technique and was about to try implementing sounds when I saw a forum post by rodot saying this method was not recommended. I would like to do it the proper way, and why not add music to my games but I simply don't get it.
yawn
by STUDIOCRAFTapps » Thu Dec 08, 2016 5:16 pm
The way i show you is present almost 1/3 of all the game. I've checked the Super-Crate-Buino's (a game by rodot) code and I've discovered this:
To store:
const uint16_t player_damage_sound[] PROGMEM = {0x0045, 0x564, 0x0000};
const uint16_t revolver_sound[] PROGMEM = {0x0045, 0x7049, 0x17C, 0x784D, 0x42C, 0x0000};
const uint16_t grenade_sound[] PROGMEM = {0x0045, 0x012C, 0x0000};
const uint16_t machiegun_sound[] PROGMEM = {0x0045, 0x140, 0x8141, 0x7849, 0x788D, 0x52C, 0x0000};
const uint16_t rocket_sound[] PROGMEM = {0x8045, 0x8001, 0x8889, 0x3C5C, 0x0000};
const uint16_t blast_sound[] PROGMEM = {0x0045, 0x7849, 0x784D, 0xA28, 0x0000};
const uint16_t power_up_sound[] PROGMEM = {0x0005, 0x140, 0x150, 0x15C, 0x170, 0x180, 0x16C, 0x154, 0x160, 0x174, 0x184, 0x14C, 0x15C, 0x168, 0x17C, 0x18C, 0x0000};
const uint16_t enemy_death_sound[] PROGMEM = {0x0045, 0x184, 0x0000};
const uint16_t jump_sound[] PROGMEM = {0x0005, 0x7049, 0x884D, 0x354, 0x0000};
const uint16_t enemy_felt_sound[] PROGMEM = {0x8005, 0x8001, 0x8849, 0xF20, 0x0000};
const uint16_t shotgun_sound[] PROGMEM = {0x0045, 0x7049, 0x334, 0x0000};
const uint16_t laser_sound[] PROGMEM = {0x0005, 0x784D, 0x7849, 0x670, 0x0000};
const unsigned int club_sound[] PROGMEM = {0x8005, 0x784D, 0x7849, 0x318, 0x0000};
and to play:
gb.playPattern(jumpSound, 1/*I don't know what i does...*/)
I don't understand how it work but it may help you...
STUDIOCRAFTapps
by yawn » Thu Dec 08, 2016 6:04 pm
Thanks, I might give it a try after all...
yawn
by Sorunome » Thu Dec 08, 2016 9:17 pm
As you (STUDIOCRAFTapps) said you didn't know what the one in gb.playPattern does:
the first parameter it takes is the song file its playing, the other one is to which channel to output, valid numbers are 0-3. This way you can play up to four of those pattern things at the same time!
EDIT: If you use a lot of channels you'll probably should increase NUM_CHANNELS in settings.c to be the number you need
by erico » Tue Dec 13, 2016 10:04 pm
You a module man?
You should check FreddyWild tracker then...
viewtopic.php?f=12&t=3435
by yawn » Wed Dec 14, 2016 8:57 am
Thanks, already downloaded it but unfortunately it won't install on my machine (maybe because I'm on win XP)
yawn
by STUDIOCRAFTapps » Thu Dec 15, 2016 12:11 am
With what did-you make that cool music, i'm working on a cool 3d game and i want to make my own music and GarageBand is very bad for that.
STUDIOCRAFTapps
Users browsing this forum: No registered users and 22 guests
