Help fixing drawbitmap function
Posted: Mon Dec 12, 2016 5:13 am
ok guys im closer to finishing the drawbitmapfromsd functions. but of course I still need help straightening up thcode a lil. the problem lies in the drawpixel command at the end of the drawbitmapA function which was included in mouginos sample code.
ive tried all kinds of stuff like adding or removing brackets but I cannot get the code to declare the drawpixel in the scope.
can someone show how to fix these please?!!!
// Draw inverted-color bitmap from SRAM char array
void drawBitmapA(byte x, byte y, char *bitmap, uint16_t color) { // where bitmap[] is the char array containing bitmap data
byte w = bitmap[0];
byte h = bitmap[1];
byte i, j, byteNum, bitNum, byteWidth = (w + 7) >> 3;
for (i = 0; i < w; i++) {
byteNum = i / 8; bitNum = i % 8;
for (j = 0; j < h; j++) {
if (!((bitmap[2 + j*byteWidth + byteNum]) & (B10000000 >> bitNum))) {
drawPixel(x + i, y + j, color);
// Draw inverted-color bitmaps from SRAM for use with tilemap duhjoker
void drawBitmapB(byte x, byte y, char *bitmap, uint8_t dx, uint8_t dy, uint8_t dw, uint8_t dh, uint16_t color) { // where bitmap[] is the char array containing bitmap data
byte w = bitmap[0];
byte h = bitmap[1];
dw += dx;
dh += dy;
for (i = 0; i<w; i++) {
for (j = 0; j<h; j++) {
int8_t drawX = x + i;
int8_t drawY = y + j;
if (drawX >= dx && drawX < dw && drawY >= dy && drawY < dh) {
drawPixel(x, y, color);
// Draw bitmap from SD at position x0, y0
int drawBitmapFromSd(byte x0, byte y0, char *bitmap, uint16_t color) { // where bitmap[] is the name of the bitmap file on SD
char buf[13]; // max 2 bytes for W/H + 11 bytes of data to cover the 84 pixel width of the Gamebuino screen
// 1. open bitmap file
// open real bitmap on SD
(pf_open(bitmap)); return BMP_NO_FILE;
// 2a. read information from bitmap header > identifier
readNCharsAt(2, 0, buf); // BMP.wIdentifier
buf[2] = NULL;
if (strcmp(buf, "BM")) return BMP_NOT_WBM;
// 2b. read information from bitmap header > bpp, compression and data size
readNCharsAt(10, 28, buf); // BMP.wBitsPerPixel + BMP.dwCompression + BMP.dwDataSize
if (WORD(buf, 0) != 1) return BMP_NOT_1BPP; // not a 1bpp bitmap
if (LONG(buf, 2)) return BMP_ERR_CMP; // not an UNcompressed bitmap
word datasize = WORD(buf, 6);
// 2c. read information from bitmap header > data offset
readNCharsAt(4, 10, buf); // BMP.dwDataOffset
word offset = WORD(buf, 0);
// 2d. read information from bitmap header > dimensions
readNCharsAt(8, 18, buf); // BMP.dwWidth + BMP.dwHeight
byte w = (byte)buf[0];
if (w>LCDWIDTH) return BMP_TOO_BIG;
byte h = (byte)buf[4];
byte datalen = datasize / h;
// 3. read and draw bitmap data
buf[0] = w; buf[1] = 1; // get bitmap data line by line
for (byte y = 0; y<h; y++) {
readNCharsAt(datalen, offset + y*datalen, buf + 2);
drawBitmapA(x0, y0 + (h - 1) - y, buf, color); // and draw it!
return BMP_OK;
Arduino: 1.6.11 (Windows 7), TD: 1.30-beta3, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz optimize speed, US English"
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp: In member function 'void Display::drawBitmap(int8_t, int8_t, int8_t, int8_t, const uint8_t*, uint8_t, uint8_t, uint8_t, uint8_t, uint16_t)':
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp:709:9: warning: unused variable 'largest' [-Wunused-variable]
int8_t largest = 0;
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp:710:9: warning: unused variable 'largesty' [-Wunused-variable]
int8_t largesty = 0;
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp: In function 'void drawBitmapA(byte, byte, char*, uint16_t)':
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp:734:34: error: 'drawPixel' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp: In function 'void drawBitmapB(byte, byte, char*, uint8_t, uint8_t, uint8_t, uint8_t, uint16_t)':
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp:755:27: error: 'drawPixel' was not declared in this scope
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp: In function 'int drawBitmapFromSd(byte, byte, char*, uint16_t)':
C:\Users\duhjoker\Documents\Arduino\libraries\gamebuinoAPcolorSD\DisplayRGB.cpp:770:9: warning: converting to non-pointer type 'char' from NULL [-Wconversion-null]
buf[2] = NULL;
Error compiling for board Teensy 3.2 / 3.1.
