Post a reply
Re: Errors with ')' and ';'
Tue Jan 10, 2017 11:48 pm
Dude, I want this shiny chance program! That is really cool. I just got my shiny charm on Sun. So that'd be helpful
Wed Jan 11, 2017 9:04 pm
IPaulasaurus wrote:Dude, I want this shiny chance program! That is really cool. I just got my shiny charm on Sun. So that'd be helpful
Yeah haha You caught what I was using it for! Problem is, the rates are so messed up with the method that I definitely don't have the ability to code in a counter. After it exceeds 255, the odds reset back to standard. One problem in coding this is that the probability would be 71/1365 or whatever the rate is with charm and no SOS boost. I'm not sure how I would code this, so after reaching over 255 more accurate results I would just reset the chain :/
Wed Jan 11, 2017 9:07 pm
Sorunome wrote:I'm sorry it took so long to reply. I'm a bit confused right now as to what you are mean, would you mind posting your entire code that you are running currently?
Sure, one problem is that I recently purchased a new computer, and didn't want to do a memory transfer for I had a TON of stuff on my previous computer that was just taking up space. I have yet to transfer my Coding/programming stuff over, and once I do I can put it here right away. Sorry for the inconvenience, and thanks again for willing to help!
Thu Jan 12, 2017 3:52 pm
Alright, this is the code I am running as of now.
Code:
//importe the Gamebuino library
//declare all the variables needed for the game :
int chain = 1;
float chance = 0;
int fchain = 1;
  // show the start menu
  gb.titleScreen(F("Shiny Probability"));
  //random values
  pinMode(chain, OUTPUT);
void reCalcChance() {
  if (chain <= 69) {
    chance = chain / 4096.0;
  if (chain >= 70) {
    chance = chain / 1024.0;
  if (chain >= 256) {
    chain = 1;
  if (gb.update()) {
    //prints Chain length on the screen
    if (gb.buttons.pressed(BTN_A)) {
      chain = chain ++;
      fchain = fchain ++;
      reCalcChance();
    if (gb.buttons.pressed(BTN_B)) {
      chain = chain --;
      fchain = fchain --;
      reCalcChance();
    gb.display.print(F("Chain Length:"));
    gb.display.println(fchain);
    gb.display.print(F("Chance of Shiny:"));
    gb.display.println(chance*100);
Hope this helps. I haven't tried it in a while but I'm sure it hasn't changed haha
Thu Jan 12, 2017 4:38 pm
You have to do just "chain++;" or "chain--;", NOT "chain = chain++;"
Thu Jan 12, 2017 7:37 pm
Sorunome wrote:You have to do just "chain++;" or "chain--;", NOT "chain = chain++;"
Works like a charm! Thanks a ton man! Is there a way that I can make it display the "chance" below the line that it says chance of shiny?
What I mean is:
Code:
is what I'm using now and it reads on the screen like
Chain Length: x
Chance of Shiny: 0.0x
would changing the code to:
Code:
    gb.display.print(chance*100);
Would it read as:
Chain Length: x
Chance of Shiny:
0.0x
Thanks again for all the help! I'm glad to see it working and its all thanks to you!
Thu Jan 12, 2017 8:46 pm
Yeah, the difference between println and print is that println will add a linebreak after printing your text.
So what you'll want is:
Code:
    gb.display.println(F("Chance of Shiny:"));
EDIT: You can also add a linebreak with \n, so that you do like
Code:
    gb.display.print(F("Chance of Shiny:\n"));
Fri Jan 13, 2017 4:01 pm
Sorunome wrote:Yeah, the difference between println and print is that println will add a linebreak after printing your text.
Code:
Code:
Once again, it works great! I couldn't get the first variation you typed to work, but the \n worked fine! And did you say there was no way to make it show more than two zeroes past the decimal, and the only way to get farther down the line was doing *100? If that is the only way to do it then it is done! Otherwise, I would like to see if it can read as 0.0002348 or whatever the odds would be.
Sun Jan 15, 2017 5:34 pm
You could always just manually display your stuff, like
Code:
gb.display.print(chance * 100); // displays stuff before the comma and two decimals
gb.display.print(((uint32_t)(chance * 1000000)) % 100); // display next two decimals
gb.display.print(((uint32_t)(chance * 100000000)) % 100); // display next two decimals
I think. The code is untested
Mon Jan 16, 2017 2:31 pm
Sorunome wrote:You could always just manually display your stuff, like
Code:
Works like a charm! All done then I think. Thanks a ton Sorunome, you were a huge help!
Post a reply
