by jackB » Wed Jul 23, 2014 7:40 pm
I can not compile the bootloader with the makefile
it reports the following errors:
- Error.png (22.74 KiB) Viewed 7224 times
jackB
by Myndale » Thu Aug 07, 2014 11:16 am
first of all make sure you're in the correct Gamebuino folder. The output that you've posted shows you're in a folder called PocketBOY, have you renamed it?
Next, it looks like your build process is failing because you have the Borland make utility in your path. The Gamebuino folder has a batch file called build.bat with this as the first line:
set PATH=%PATH%;C:\arduino-1.0.5\hardware\tools\avr\utils\bin
First of all you'll need to change the path to the location of your arduino folder. Next, you should probably move it to the front so that it gets chosen before everything else, i.e.:
set PATH=C:\arduino-1.0.5\hardware\tools\avr\utils\bin;%PATH%
Let me know if you continue to have any problems.
by treflip » Thu Aug 07, 2014 2:07 pm
I also can't compile the bootloader using the makefile. I posted it
here but didn't get an answer.
I did like you said and changed the directories in the bat file and makefile but I still get the following error:
makefile:51 *** missing separator. Stop.
the line 51 contains: .PHONY: all
not sure what separator it's looking for... :{
Thanks!
treflip
by jackB » Sat Aug 09, 2014 12:50 pm
I solved the problem
Thanks
jackB
by rodot » Sat Aug 09, 2014 12:58 pm
Could you please tell us how, just in case someone has the same problem?
by spunky » Thu Mar 03, 2016 11:34 am
- bootloader error.png (45.67 KiB) Viewed 6866 times
HHi all can some one send me working bootloader source files with empty path so i just put in my path and compile,or tell me how to do it,ive tryed all above but it says somthing about avrdude overlaping or somthing
spunky
by spunky » Thu Mar 03, 2016 11:49 am
- bootloader error.png (103.26 KiB) Viewed 6866 times
then i change a few things but says it cant find the file etc,that is correct path i copy path from exsplora window whe3n in the exact folder it should find the file it wants
spunky
by spunky » Thu Mar 03, 2016 1:39 pm
@jackb how did you solver bootloader issue
spunky
