by DLBB » Tue Aug 30, 2016 4:44 am
Hi.
Thanks for this kewl GB thingy! I like to port the screen from Nokia display to SSD1325 oled. I have a working lib for the ssd and the initialisation is like the one from the Nokia display.
Question: what does
if(gb.update()){ //update everything
mean? What's behind
and updates everything (display, sound, batter monitor, etc.) at a fixed frequency (20 times per second by default)
Does it draw all the stuff on the screen again? Bitmap bg, sprites etc. p. p.? Or what in detail does it do?
And what's this Nokia display routine doing:
void Display::update(void) {
frameCount ++;
uint8_t col, maxcol, p;
for (p = 0; p < 6; p++) {
command(PCD8544_SETYADDR | p);
// start at the beginning of the row
col = 0;
maxcol = LCDWIDTH_NOROT - 1;
command(PCD8544_SETXADDR | col);
digitalWrite(dc, HIGH);
if (cs > 0)
digitalWrite(cs, LOW);
for (; col <= maxcol; col++) {
SPI.transfer(_displayBuffer[(LCDWIDTH_NOROT * p) + col]);
if (cs > 0)
digitalWrite(cs, HIGH);
command(PCD8544_SETYADDR); // no idea why this is necessary but it is to finish the last byte?
Thank you for information.
DLBB
by Sorunome » Tue Aug 30, 2016 9:35 am
Hey there! gb.update(); is responsible for updating the battery, the backlichgt, the pressed buttons, the shound, popups, sending the buffer to the screen (if set clearing it again) and handling your program to have a static frame-rate. For more in-detail stuff you might want to check the source
here.
The routine you linked is gb.display.update(), right? That routine takes the graphbuffer and sends it off to the screen so that the screen actually displays what was in the graph buffer before calling that function.
by DLBB » Sun Sep 04, 2016 10:12 am
Hi Sorunome.
Thank's for the info. I started the port now...
Can someone tell me what base was used for the Gamebuino display.cpp and display.h? Does it use the base core of Adafruit_PCD8544.cpp and Adafruit_PCD8544.h out of the
https://github.com/adafruit/Adafruit-PC ... CD-library - repo? I mean functions like drawPixel() for example?
I have some essential problems to port this display.cpp to a / to the SSD1325 functions and declarations... It's
(EDIT: very!!!) hard to find a starting point.
DLBB
by DLBB » Sun Sep 04, 2016 12:40 pm
Hi.
In display.cpp file in the function
Display::update(...)
there's a
in it. Is SPI using the pins I declared in setup.c for MOSI, clock etc.? Or must I use the standard SPI pins of the A328p (MOSI and SCK)?
DLBB
by DLBB » Tue Sep 06, 2016 5:30 am
Ok. There's something like a picture on oled.
I connected the hardware SPI pins of the 328p to the oled.
This means I'm on the right track.
Way to go...
- Attachments
- IMG_20160906_072959.jpg (230.32 KiB) Viewed 24789 times
DLBB
by DLBB » Sat Sep 17, 2016 12:34 pm
Another step?
I could change the Adafruit lib for SSD1325 (128x64) to 104(102)x80.
https://www.youtube.com/watch?v=9ATfVfpdzncNow I should beginn to port this running stuff to GD framework...
DLBB
