Hello, I made this tool to learn how to read music notes.
music notes.gif (9.26 KiB) Viewed 18797 times
Functions: - 4 notes on a musical stave with their names, (left/right and up/down to modify) - Press A to switch Treble Key (clef de SOL) and Bass key (clef de FA) - Press B to hide/unhide the notes names - Press A+B to randomize the musical notes - Hold LEFT 2 sec to switch US/FR musical notes (eg. C = DO, D= RE, E=MI...)
Nice ! That's a detail, but would it be possible to hide/unhide additional lines? Are we able to ear the real sound? Are you going to dev the equivalent for rythm?
Hello frakasss thank's for your reply, i didn't implement the sound but i would be a good idea i don't understand what additional lines we could hide/unhide could you explain that ?? and an equivalent for rythm would be nice too
Hey! Looking at screenshots in the first post: A normal stave is composed by 5 lines. Additional lines under this stave should appear only for notes under the stave.
As an example, the 'do' has one line going through the note. You should only display this additional line. The 'la' under the stave need 2 additional lines. Then you can display 2 lines.
Does this explanation make sense? If not, I'll try to send some pictures!
Hello frakasss, Yes the additional lines over or under the notes appears only when at least 1 note of the stave is under or over the regular stave. i made a little video presentation of the program here showing all the functions:
