[Solved]
[Solved]
Postby minecraftlog21 » Sun Jan 11, 2015 4:01 am
I am developing a game for the gamebuino And I have ran into a Problem where one of collision detectors is not working.
(This is the bug as you can see the ship goes threw the barrier up top.)
int ShipXDisp = 15;
int ShipYDisp = 15;
int ShipXLoc = 0;
int ShipYLoc = 0;
int ShipFace = 0;
static byte PROGMEM Ship[] =
  7,7, //width and height
  B00010001,
  B00111001,
  B00111001,
  B00111001,
  B01111101,
  B11111111,
  B00111001,
  gb.titleScreen(F("Game"));
  if(gb.collideRectRect(ShipXDisp, ShipXDisp, 7, 7, 0, 0, 8, 48)){
    //ShipYDisp = ShipYDisp + 1;
    ShipXDisp = ShipXDisp + 1;
  if(gb.collideRectRect(1, 1, 83, 7, ShipXDisp, ShipXDisp, 7, 7)){
    gb.popup(F("Colide"),40);
  //  ShipXDisp = ShipXDisp + 1;
    gb.display.drawRect(0, 0, 8, 48);
    gb.display.drawRect(0, 0, 84, 8);
    if(gb.buttons.timeHeld(BTN_UP)){
      ShipYDisp = ShipYDisp - 1;
      ShipYLoc = ShipYLoc - 1;
      ShipFace = 0;
    if(gb.buttons.timeHeld(BTN_DOWN)){
      ShipYLoc = ShipYLoc + 1;
      ShipFace = 2;
     if(gb.buttons.timeHeld(BTN_LEFT)){
      ShipXDisp = ShipXDisp - 1;
      ShipXLoc = ShipXLoc - 1;
      ShipFace = 1;
     if(gb.buttons.timeHeld(BTN_RIGHT)){
      ShipXLoc = ShipXLoc + 1;
      ShipFace = 3;
    gb.display.fillCircle(15 - ShipXLoc, 20 - ShipYLoc, 5);
    gb.display.drawBitmap(ShipXDisp,ShipYDisp,Ship,ShipFace,0);
    gb.display.print(ShipXLoc);
    gb.display.print("_");
    gb.display.print(ShipYLoc);
    gb.display.print(" ");
    gb.display.print(ShipXDisp);
    gb.display.print(ShipYDisp);
Last edited by minecraftlog21 on Sun Jan 18, 2015 10:38 pm, edited 1 time in total.
minecraftlog21
Re: HELP : I can't get collision working
Postby Jamish » Sun Jan 11, 2015 8:39 am
Looks like the problem is that you were calling "ShipXDisp, ShipXDisp" instead of "ShipXDisp, ShipYDisp" in both of your collide calls.
Also, your gb.collideRectRect checks should go inside gb.update(), otherwise that code is getting called a LOT more than once per frame :)
Here's your fixed code:
int ShipXDisp = 15;
int ShipYDisp = 15;
int ShipXLoc = 0;
int ShipYLoc = 0;
int ShipFace = 0;
  B00010001,
  B00111001,
  B00111001,
  B00111001,
  B01111101,
  B11111111,
  B00111001,
    if(gb.collideRectRect(ShipXDisp, ShipYDisp, 7, 7, 0, 0, 8, 48)){
    if(gb.collideRectRect(1, 1, 83, 7, ShipXDisp, ShipYDisp, 7, 7)){
      ShipFace = 0;
      ShipFace = 2;
      ShipFace = 1;
      ShipFace = 3;
Jamish
Postby minecraftlog21 » Sun Jan 11, 2015 9:41 pm
Jamish wrote:Looks like the problem is that you were calling "ShipXDisp, ShipXDisp" instead of "ShipXDisp, ShipYDisp" in both of your collide calls.
Thanks for the fixed code shows how carful you need to be :D
minecraftlog21
Postby Jamish » Mon Jan 12, 2015 5:39 pm
minecraftlog21 wrote:Thanks for the fixed code shows how carful you need to be :D
Careful indeed. I make those kind of mistakes all the time, haha.
Jamish
