Can't turn on
Can't turn on
Postby Tobi » Sat Mar 28, 2015 3:57 pm
I think my Gamebuino is broken :(
I can't turn it on. I have loaded the battery a few hours. But if I want to turn the Gamebuino without USB connection on: Nothing happens.
If I connect is with USB and I turn the GB on, the lights are flickering. Sometimes I see the menu with some pixels. But then it is flickering again and the screen is blank.
What can I do? I see that the on/off Button was on, before I load the battery again. Perhaps the battery is broken? (I have nothing here to solder for e.g. a new battery).
Thanks from Germany! :)
Tobi
Re: Can't turn on
Postby Sorunome » Sat Mar 28, 2015 4:43 pm
Hi, do you hear a startup sound of any kind?
Re: Can't turn on
Postby Tobi » Sat Mar 28, 2015 10:31 pm
No, nothing :(
Tobi
Re: Can't turn on
Postby Sorunome » Sat Mar 28, 2015 10:56 pm
Have you tried holding down C for some time while turning it on and then leaving it in the on position for like a min or so?
Re: Can't turn on
Postby Tobi » Sat Mar 28, 2015 11:30 pm
Yes and if I turn Gamebuiono on, the power led is not on, too :/
Tobi
Re: Can't turn on
Postby rodot » Sun Mar 29, 2015 8:35 am
Hey,
I'm sorry to hear you have trouble with you Gamebuino. It stopped working for no apparent reason ? Can you check the battery voltage with a voltmeter ? Does it turn on when it's plugged in ?
Re: Can't turn on
Postby Tobi » Sun Mar 29, 2015 8:39 pm
Hey rodot, don't worry! :)
I don't used the Gamebuino for a few month. Now I want to play some new games. Want to turn it on, nothing happens. At the first time I was thinking the battery is empty. But I have loaded it some hours :/
When I plugged the USB cable in and turn the GB on, the screen and battery led is flickering.
But ... what can I do now?
Tobi
Re: Can't turn on
Postby rodot » Mon Mar 30, 2015 6:31 pm
Can you check the battery voltage ? Please answer me through the online shop so we can find a solution. I want to make sure each Gamebuinian has a nice experience with his/her console :)
Re: Can't turn on
Postby Tobi » Wed Apr 01, 2015 10:22 am
Thanks! :) I have sent you a mail.
Tobi
Re: Can't turn on
Postby Some » Sun May 24, 2015 2:54 pm
Hello ! I sent a message few days ago by the contact page in the shop becauseI have the exact same issue. I still have no answer so I give a try in the forum ;)
Can you help me to find a solution ?
Some
Users browsing this forum: No registered users and 61 guests
