seperate sketches for seperate game aspects
Re: seperate sketches for seperate game aspects
Postby Sorunome » Sat Aug 20, 2016 1:20 pm
Oooooh, i think you forgot `extern Gamebuino gb;` (in the other files, that is) so that you can use gb.<stuff> in the other files!
Postby Duhjoker » Sat Aug 20, 2016 11:17 pm
Ok before I start driving myself nuts.......
Do I need the extern const byte sever_right[]; in the map.ino?
Do I need the extern const byte *spritesheet[]; in the player.ino?
Do I put both or one or the other in the Esmerelda.ino which has the void loop and setup?
Do I put the extern Gamebuino gb; in just the map.ino and the player.ino sketch?
Does the name of the loop matter for the player.ino and map.ino sketches?
My code is posted, have I got everything placed right in each sketch. Is something mixed up?
Please just take a look.
Postby Sorunome » Sun Aug 21, 2016 12:29 am
You basically need an "extern <whatever that variable definition was>" in the file in which you want to use said variable.
Skimming over your code it seems to me as if map.ino needs gb and player.ino needs gb, player_x, player_y, player_direction
I might have missed some, but yeah, you need an "extern <whatever the variable definition was>" in the file if that variable was actually decalred in a different file
