Incomplete workshop Workshop completed
Download and extract the pre-configured Arduino IDE
You need the Arduino IDE software to type your code and send it to the Gamebuino over the USB cable.
Good thing we cooked you a ready-to-use portable version! Simply download the right one according to your operating system and extract it.
Windows Linux 64-bit Mac
Do the (longer) manual setup instead
Then, decompress the file that you just downloaded. This step may take a moment or two; you can kill some time by up-voting a few creations ;)
Once the file is decompressed, open the folder and run "arduino".
And voilà! The software is ready to be used!
Compile and run your game
foud6280
NEW 1 month ago
Bonsoir
J'ai installé IDE Arduino OK
Puis  la carte SAMD OK
Mais impossible de trouver Gamebuino META : cf log ci dessous
J'ai réussi à installé la bibliothèque
Merci de votre aide car je suis bloqué
flashjaysan
NEW 1 month ago
Ce tutoriel est super. Cependant, les headers HTML choisis (h2) pour les titres des sections I Installer la carte, et II Installer la bibliothèque porte à confusion. Sauf erreur de ma part, ces sections concernent uniquement la méthode non portable (header h3). Mais on a l'impression qu'elles concernent les deux méthodes. Il faudrait donc réduire leur importance en leur attribuant des headers inférieurs à la méthode non portable : h4.
makerSquirrel
NEW 1 month ago
Hiho,
thanks a lot for the link! I hadn't read that article since my french is really bad (it was solely my second foreign language (after english) at school), but I will try to understand it.
cheers
