By Sorunome, 8 years ago
This will explain you how to use the gamebuino save format, the gb.save interface. First, this will explain the simple usage and after that the advanced, more customizable usage with config-gamebuino.h
The savefile is structured in blocks. A block can hold a number or a buffer. By default the savefile has 64 blocks.
Handling numbers is very easily done:
gb.save.set(0, 42); // saves 42 in block 0 gb.save.set(1, -1337); // saves -1337 in block 1 int i = gb.save.get(0); // fetches block 0, which is 42 int j = gb.save.get(1); // fetches block 0, which is -1337 gb.save.del(0); // deletes block 0
Numbers default to zero (configurable, see advanced usage)
Now, instead of storing a number in a block, you can also store a blob. By default the size of a blob is 32 bytes.
Well, what is a blob? A blob can be literetally anything! You can store strings, buffers, objects or just about anything you'd want to store.
gb.save.set(2, "Foxes are awesome!"); // stores the string "Foxes are awesome!" in block 2CustomObject obj; gb.save.set(3, obj); // stores obj
void* buffer = malloc(10); gb.save.set(4, buffer, 10); // stores a buffer of length 10
if these functions return true setting was possible, if they return false then something went wrong.
Now, how do you fetch those blobs?
char string[32]; gb.save.get(2, string); gb.display.print(string); // prints block 2 as string, so "Foxes are awesome!"CustomObject obj; gb.save.get(3, obj); // fetches the custom object
void* buf = malloc(10); gb.save.get(4, buf, 10); // fetches up to 10 bytes from block 4
if these blocks don't exist yet the buffer is filled with zeros (configurable, see advanced usage)
Please note that after setting it is enforced wether the block is an int or a blob. For example:
// this will error gb.save.set(0, 42); gb.save.set(0, "blah"); // error, block is an int!!// this will also error gb.save.set(0, 42); char name[10]; gb.save.get(0, name); // error, block is an int!
// this will work, though gb.save.set(0, 42); gb.save.del(0); // we delete the block gb.save.set(0, "Foxies!");
You can easily store floats / signed ints etc. as ints by casting them:
gb.save.set(0, (int32_t)3.14159); float pi = (float)gb.save.get(0);gb.save.set(1, (int32_t)true); bool stuff = (bool)gb.save.get(1);
The basic idea of advanced usage is to pre-define which block is an int and which one is a blob and to allow custom defaults. For this we need to create an array of the type SaveDefault, passing that then on to gb.save.config:
const SaveDefault savefileDefaults[] = {
{ /* data / },
{ / data */ },
// set the save defaults
gb.save.config(savefileDefaults);
Now, there are multiple different SaveDefault data things possible. The first argument is always the block number to configure, the second one which type that block must be (SAVETYPE_INT or SAVETYPE_BLOB). After that, it depends on if you use int or blob:
SAVETYPE_INT
As third argument you have to set the default value. Fourth one is always zero. So these all are valid SaveDefault data things:
{ 0, SAVETYPE_INT, 9999, 0 }
{ 1, SAVETYPE_INT, -42, 0 }SAVETYPE_BLOB
Blobs must have a third and optionally a fourth argument. With only three arguments the third one is the max length of the blob (fourth one must be zero again), with four arguments the third one is the default and the third one the max length. For the default data, you see below how that needs to be set.
The length of a blob can only be up to ~2^32 bytes*!
So these are valid blob constructors:
{ 2, SAVETYPE_BLOB, 20, 0 }
{ 3, SAVETYPE_BLOB, {.ptr="Fox"}, 20 }Ok, that was a lot to take in. So here is an example taking full use of all the features:
{ SAVE_PLAYERNAME, SAVETYPE_BLOB, {.ptr="Link"}, 20 },
{ SAVE_HEARTS, SAVETYPE_INT, 3, 0 },
{ SAVE_SOMEBUFFER, SAVETYPE_BLOB, 25, 0 },
// somewhere later in the code
char name[20];
gb.save.get(SAVE_PLAYERNAME, name);
gb.display.print(name); // prints "Link"
int hearts = gb.save.get(SAVE_HEARTS); // returns 3
I sure hope this helped you to understand how to use the save API to its full extend!
*: While a blob can be up to ~2^32 bytes large, the total payload may not exceed 2^32-1 bytes. Payload is all blob sizes added together. A blob is always four bytes larger than you set it, because it is prefixed with its size.
