Salmon Run - The Shoal Arcade
1.2.0
By STUDIOCRAFTapps, 7 years ago
NEW! (2019 Updates) Play the game online with a bigger resolution here: Gamejolt Page
NEW! PC/MAC/LINUX Builds for those who don't have a Gamebuino yet or those who want a more fluid experience!
French translation bellow
WARNING: DO NOT INSTALL THE GAME WITH THE DOWNLOAD BUTTON ABOVE, USE THE ONE BELLOW
ATTENTION: N'INSTALLEZ PAS LE JEU AVEC LE BOUTTON TÉLÉCHARGER EN HAUT, UTILISEZ PLUTÔT LE BOUTTON CI-DESSOUS
Download Gamebuino Version
PLAY ONLINE VERSION
SALMON RUN BY THE SHOAL ARCADE
Based on the engine of Splatoon META.
The second game of the Shoal Arcade collection for the Gamebuino. Salmon run is a single player campaign (a bit to much) inspired from the lore and game-play of Splatoon 2 Salmon Run.
Story
~The time is ticking
Seas are rising.
The fury is approaching.~
"It is claimed that the Salmonid's increased aggression is tied up somehow to the gravitational shifts due to the planet's celestial course, but there is still much that is unclear. But this time, the Salmonid rush that once took many cities from the pre-medieval time, a time where there were no such as long range ink weapons, is stronger than ever due to unknown reason, so much so that modern technologies are having a bad time resisting to the never ending fury."
To help out your city, you were sent by Grizzco Inc, a corporation known for their collection of power eggs, now helping Inkopolis to defend its citizens. Your mission is complex and risky: establish multiple Grizzco Power-canons and protect it from the waves of Salmonids. Be careful, the seas are rising and to stop it, you need to block the enemy.
Gameplay
By splating Salmonids, you obtains Power Eggs. These are the things you need to build your cannon and end the mission. It's not that easy, splating to much of them could rise their anger and make them stronger. This is not all, there are also Salmonids boss, a much stronger and harder to beat Salmonid that, if defeated, will drop Golden Eggs and scare the Salmonids, lowering their anger. Deposit these eggs one by one into the basket. They will be handy once all the mission are completed. You need a certain amount of them to finish the mission, so make sure to keep track of that.
There's in total in the whole game 7 missions. Each mission have a second harder version of itself. All of the missions are located in procedurally generated maps. The final mission require a certain amount of golden acquired during the journey to be unlocked.
NOTES
More info about The Shoal Arcade
Salmon Run is only playable by downloading the Shoal Arcade Gamebuino folder (included when dowloding the game). This folder includes some content that allows all the Shoal Arcade games to be played. This folder also includes previous games like Splatoon Meta and the Shoal Editor that allows to reset the games. The previous Splatoon Meta save files can be safely putted into the new folder.
Change log 1.1.0
  • Fixed some spawning zone bugs
  • There's now spawn lights to indicate where to stand to summons salmonids
  • Fixed the salmonid locator. You can now see where they are.
Q&A
Why can't I shoot ink!
To shoot ink, hold A and aim with the arrows. You must have some ink left in your ink tank to shoot (In the bottom right corner). Recharge your ink thank by swimming in your own in with the down arrow. You don't have any ink left in your ink thank and there's not any near you? I have something for you! By holding A, you can ink the ground under you!
The tide is pretty high now and I can't find any golden egg, where could I find some?
Not enough golden egg to complete the mission? Find 10 extra power egg (the orange ones) and they will get exchanged for 1 golden egg. You could also find some egg drops if you're lucky. They usually drop 2 golden egg.
I think I've finished the game and I would like to start over.
Open the Shoal Editor file in the Shoal Arcade menu, select Salmon Run, New game and here you go!
The map randomizer gave me some real mess, how change the current map?
Pause the game with the menu button, select mark map as and then broken. It should be different once you exit and re-enter the level.
SALMON RUN PAR THE SHOAL ARCADE
Basé sur le moteur de jeu de Splatoon META.
Le second jeux de la collection Shoal Arcade pout la Gamebuino. Salmon run est une capagne à un joueur qui s'est (un petit peu trop) inspiré de l'histoire et du game-play du mode de jeu Salmon Run de Splatoon 2.
Histoire
~Le temps file
Les mers montes.
La fureur approche.~
"On prétend que l'agression accrue des salmonidés est liée aux changements gravitationnels dus au cours céleste de la planète, mais il reste encore beaucoup de tout ça à clarifier. Mais cette fois-ci, la ruée vers les salmonidés qui a, jadis, envahi de nombreuses villes avant l’époque médiévale, une époque où il n’y avait pas d’armes à longue portée, est plus forte que jamais pour des raisons inconnues, à tel point que les nouvelles technologies ont un mauvais temps à essayer de résister à la fureur sans fin"
Pour aider votre ville, vous avez été envoyé par Grizzco Inc, une société connue pour sa collection d'œufs de puissance, aidant maintenant Inkopolis à défendre ses citoyens. Votre mission est complexe et risquée: établissez plusieurs Canons Grizzco Power et protégez-le des vagues de salmonidés. Mais attention, la mer monte et pour l'arrêter, il faut bloquer l'ennemi.
Gameplay
En éclaboussant des salmonidés, vous obtenez des œufs de puissance. Ce sont la ressource dont vous avez besoin pour construire votre canon et mettre fin à la mission. Ce n'est pas si facile, éclabousser trop de salmonidés pourrait augmenter leur colère et les rendre plus forts. Ce n'est pas tout, il y a aussi les boss des salmonidés, un salmonidé beaucoup plus fort et plus difficile à combattre qui, une fois vaincu, laissera tomber des œufs dorées et effreyera les salmonidés, réduisant leur colère. Déposez ces oeufs un par un dans le panier. Ils seront utiles une fois la mission terminée. Vous devez en avoir un certain nombre pour terminer la mission, alors assurez-vous d'en garder une trace.
Il y a un totale de 7 mission différente dans le jeu. Chaqunes d'elles ont une version plus difficile d'elle même. Elles sont aussi toute générées aléatoirements. La mission finale requiere un certain nombre d'oeufs dorées pour être débloquée.
NOTES
Plus d'info sur The Shoal Arcade
Salmon Run est seulement jouable en téléchargent le dossier de l'arcade (inclus en téléchargent le jeu). Ce dossier inclus du contenu qui permet de faire fonctionner tout les jeux de l'arcade. Ce dossier inclus aussi les autres jeux de l'arcade comme Splatoon Meta et l'Éditeur de sauvegardes de l'arcade. Les anciens fichier de sauvegardes de Salmon Run peuvents être utiliser directement dans le dossier de l'Arcade.
Additions en 1.1.0
  • Fixer la position d'apparition des salmonoïdes
  • Nouveau: Lampe d'apparition des salmonoïdes, qui indique où se tenir pour attirer les salmonoïdes
  • Fixer l'indicateur de salmonoïdes qui révèle leurs positions
FAQ
Pourquoi ne puis-je pas encrer les ennemies et le sol?
Vous devez appuyez sur A et visez avec les flèches pour tirer. Vous devez aussi avoir de l'encre dans votre réservoire d'encre (Dans le coin en bas à droite). Recharger le en nageant dans votre encre avec la flèche du bas. Il n'y a pas d'encre dans votre réservoire ni proche de vous pour recharger? Appuyez sur A pour en faire apparaître en dessous de vous.
La marée est pas mal haute et je ne trouve pas d'oeufs dorés. Où puis-je en trouver?
Pas assez d'oeufs dorés? Obtiens 10 oeufs de puissance de surplus (ceux en orange) et ils s'échangerons pour 1 oeuf doré. Vous pouvez aussi trouvez des boîtes d'oeufs si vous êtes chanceux. Il donnent normallement 2 oeuf doré.
J'ai fini le jeu et je veux recommencer
Ouvrer le fichier Shoal Editor dans le menu Shoal Arcade et choisisser Salmon Run et puis New game et voilà!
Le générateur de niveau aléatoire m'a donné de la grosse merde, je fais quoi pour changer de niveau?
Appuyez sur pause avec le boutton de menu et marquez la carte en tant que broken. Elle devrait être différente en relancer le niveau.
MORE / PLUS
Discord: https://discord.gg/RwWGNpS
Music by / Musique du jeux par: Loeder
PC/MAC port coming soon
Port du jeu sur PC/MAC prévus dans pas long.
OBSELETE DOWNLOADS
DOWNLOAD MAC BUILD
DOWNLOAD WINDOWS INSTALLER
DOWNLOAD WINDOWS ZIP
(Use the Windows Zip Build when you don't have the administrative permissions)
DOWNLOAD LINUX BUILD
